Projects turning a sedan into a coupe 1930
Discussion in 'Traditional Hot Rods' started by sigfurniture, Dec 7, 2020.
  1. A 2 B
    A 2 B
    from SW Ontario
    It all boils down to personal preferences when determining the final configurations. A build like this affords an abundance of artistic license for sure just like any other hot rod.
    If you look at the model chart you will notice that there is not one that has a front fender extended forward more than the stock tire. You can stand a straight edge up plumb in front of the tire and not touch the fender. Not sure if the fender position would accentuate the "long nose" or not.
    sigfurniture and The37Kid like this.
  2. sloppy jalopies
    sloppy jalopies
    wd 57,
    that murray cowl is up for trade, it will take a Montreal steak at the Gridiron to pull it from my hands !
  3. 343w
    343w
    And just like that he made a coupe out of a sedan, great work!
  4. inaford30
    inaford30
    Murray Phantom coupe! Like to know length of interior over stock ford coupe
    Sent from my SM-J7008 using The H.A.M.B. mobile app
    sigfurniture, 343w and loudbang like this.
  5. sigfurniture
    sigfurniture
    Sorry for my absence again folks, had a bunch of different stuff to do for different clients (colour change on an old Land rover.. Paint strip on a splity beetle. And a sculpture for a vineyard in south of France!). All good fun. The client for the rod has bought a space to show his cars so will probably be slowing the pace a bit for a while. Thanks for all the positive vibes.. Always good to recieve.
    The projection at the rear of the car is a part that was on the sedan.. The client wanted it on.. It makes it a bit different.. Trying to make it look quirky and therefore original.. The interior is longer than original I think.. I'll measure next time I'm there. Still plenty to do.. The front axle should be arriving soon. Cheers for now **
    brEad and loudbang like this.
  6. sigfurniture
    sigfurniture
    Length from windscreen to rear gl*** 53 inches 135cm
    inaford30 and loudbang like this.
  7. sigfurniture
    sigfurniture
  8. 32 hudson
    32 hudson
    Looks pretty good with the fenders. That a good comment from an open wheel hot rod preference guy as my self.
  9. 32 hudson
    32 hudson
    I just read trough the whole thread. This a great build love the creativity, vision and use of what ever is available for parts . Learning a lot of new information also . Well done Sig. Subscribed and folowing.
  10. mtb1981
    mtb1981
    The metal work here is incredible.
    sigfurniture, inaford30 and loudbang like this.
  11. sigfurniture
    sigfurniture
    Hey ho.. Back on the cars after furniture and sculpture jobs.. Actually quite missed it so started welding up the rear of the b-side.. And tidying everything up.. Also now it's moved slightly so I get to see what it looks like with the wings on from the rear.. I like it looks like a moustache a bit.... IMG_20210518_194820.jpg IMG_20210518_182929.jpg
    unforgiven, Jrs50, Blues4U and 9 others like this.
  12. brEad
    brEad
    Car is really looking good!
    sigfurniture and loudbang like this.
  13. sigfurniture
    sigfurniture
    Front axle kit arrived.. Well most of it.. For no apparent reason we're missing the inner disc bearings.. The pitman arm.. And some other stuff.. They sent the wishbone rear adapter instead of the 4 bar setup one.. A little bit frustrating.. But at least I can tie down the exact position of the wheels to set up the front wings etc.. And it's nice to see the nose taking shape.. IMG_20210528_183848.jpg
    simplestone, Jrs50, ottoman and 6 others like this.
  14. sloppy jalopies
    sloppy jalopies
    mikie likes it !
    sigfurniture likes this.
  15. sigfurniture
    sigfurniture
    Hello.. Back on board with the coupe and firing on all cylinders for a few days.. Sorting out the hood moldings.. The light brackets.. The fender supports and the running boards and that skirt part that I can't remember the name of! Betwen door and running boards.. The engine will go off to the mechanic soon so getting all the stuff positioned ASAP.. Quite pleased.. It seems to gel together as a thing at the moment.. See what you think... IMG_20210714_190201.jpg IMG_20210714_190142.jpg IMG_20210714_185841.jpg IMG_20210714_185817.jpg IMG_20210714_153248.jpg
    unforgiven, Xman, attitudor and 8 others like this.
  16. Squablow
    Squablow
    "Aprons" is the word you're looking for, for those fillers. Looks good!
  17. chev34ute
    chev34ute
    I notice you have been having trouble with working out the depth of the splash aprons. The easiest thing to do would be to get some cardboard and trace it around a stock Model A valance panel and cut it out. This would give you a pattern from which you would be able to transfer onto a sheet of metal.
    You would then trace the pattern around the metal and cut it out. This is one I made up for my model A tourer a couple of years ago.
    The bending process is surprisingly easy. You build a wooden box out if heavy duty timber the length of the valance panel and you then get a length of thick walled pipe the same length. You position the sheetmetal directly over the box and push the pipe down onto the sheet metal forcing the sheetmetal inside of the box.
    The pipe gives you the desired contour and the box keeps the sides balanced.
    3C616A7A-0F42-4031-B6A0-2206776610B1.jpeg 00129572-FF60-43A0-B4E2-78DCF71EB85F.jpeg
    A 2 B, brEad, loudbang and 3 others like this.
  18. sloppy jalopies
    sloppy jalopies
    yup... looking like a hotrod !
  19. Atwater Mike
    Atwater Mike
    Quite impressive, your forming of panels just 'out of the air'! Pure artistry.
    Your 'forming' of the female sculpting is also quite amazing, the one in the last pics have captured the perfection of my wife! Great work, Sig...
  20. sigfurniture
    sigfurniture
    Thanks guys **.. Got the other side sorted and the rear fender slightly widened to mesh with the body.. They were too twisted before and looked odd withe the front fenders IMG_20210715_183730.jpg IMG_20210715_184305.jpg IMG_20210715_184024.jpg
  21. sigfurniture
    sigfurniture
    The big truck headlamps arrived.. Will need work but I like the a lot... IMG_20210718_105039.jpg
  22. attitudor
    attitudor
    from Finland
    Any updates? Interesting to see, I’m also turning a Sedan into a Coupe.
