Technical Your opinion on a camshaft
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Apr 8, 2021.
  1. SS Pete
    SS Pete
    Lloyd, 283/097 is the way to go. Compe***ion Products has one listed in the newest catalog. (Howards cam). use polylocks also. I checked Northern Auto, you should be getting Sealed Power pistons in the kit. most shops can bore a block to size if they know the brand. NHRA guys run in the elevens with 1.72 power pack heads. beat the **** out of it and have fun Pete..
  2. hotrodjack33
    hotrodjack33
    I used to use mustache wax...but the wife kept sliding off...:p
  3. 1957 270 HP 283 Duntov cam.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    My opinion is this, If you put a lumpy camshaft and a tunnel ram on a small cube engine you are going to have a car with very little bottom end power and it will be difficult to drive on the street....
  5. Atwater Mike
    Atwater Mike
    <<My opinion is this, If you put a lumpy camshaft and a tunnel ram on a small cube engine you are going to have a car with very little bottom end power and it will be difficult to drive on the street....>>
    Hear, hear! Right on....I've re-cammed more SBCs with tunnel rams than anything else, (Many errors on camshafts by neophyte customers, but the tunnel SBCs topped the list)
    This is the understatement, and should be stated in capital letters.
  6. Roothawg
    Roothawg
    Comp Cams ground me one.
    mad mikey and loudbang like this.
  7. Tickety Boo
    Tickety Boo
    from Wisconsin
    The 1st engine that was in Tickety Boo was a 327 with 492 double hump heads, Weiand single 4 tunnel ram, it went through the lights on the 1/4 big end at 7400 rpm with a best E.T. of 11.97.
    Really learned how to tune for weather changes on the single 4 tunnel ram.
    Drove it on Branch river road a few times and if that engine wasn't over 5000 rpm it was what Dale Earnhart described as "like stepping on a Mushroom" :rolleyes:
    mad mikey, loudbang and Moriarity like this.
  8. cvstl
    cvstl
    from StL MO
    I went with Comp XE262H on my 0.060 over 283 w/ powerpack heads. Same cam worked really well in a 307.... Still a week or so out from firing it and probably a couple months from going down the road, so we will see.
    guthriesmith likes this.
  9. Stock Racer
    Stock Racer
    Looks like you've had plenty of help already but I'll throw my hat in the ring. Call the cam manufacturer of your choice and tell them what you have. They have great software that will help with cam choice. Those old cams will probably work fine but most manufacturer's have much better grinds these days. I use Bullet Cams. They just ground me a cam for a fairly stock 327/300 hp type engine. Its a solid lifter flat tappet with 235 duration intake, 240 exhaust at .050 lift. As for the tunnel ram...probably not the best choice but they look cool!
  10. Stock Racer
    Stock Racer
    And on the head gasket...if you're down in the hole a bit, check out a Fel-pro 1094.
  11. 1957partsman
    1957partsman
    from colo.
    My 56' had 283(std bore but set up loose including rods & mains) with 60's PP heads @ 9.5cr, corvette 2x4 intake with WCFB's, re curved 081 dist. with pertronx module, 097 cam, 4.11 posi, Muncie 4 and it ran very hard and reliably for 18 years. Loved that power combo and sound. Should have never sold it! My mistake!!
    Sent from my SM-T720 using The H.A.M.B. mobile app
    1Nimrod, Tickety Boo and olscrounger like this.
  12. southcross2631
    southcross2631
    You want a good sounding hard charging small cube cam ,Look at Isky's stock eliminator cams. The stage 1 won't be as hard on springs. They are .390-.410 lift with lots of duration and a short center line.
    We ran them in our stock lift rules round track stuff. We used the Compe***ion Products Z28 valve spring upgrade.
    The motor's have a crazy good idle and pull to 7500 even with stock heads when you put a decent spring on them. Should work well with your tunnel ram and 4 speed. They worked well with a 305 Chevy in a 3500 lb. stock car.
    1Nimrod and rod1 like this.
  13. Lloyd's paint & glass
    I was at the machine shop today and told my machinist that somebody asked me how i had the block bored without even having the pistons yet, he looked at me really funny and said "ask them where they're getting their inconsistent pistons" lol. Then he said "yeah I've seen those oval pistons". Then he asked me how did i know what pistons to buy before he knew how much oversize the block was gonna have to go to straighten it up.
    hotrodjack33 and Desoto291Hemi like this.
  14. hotrodjack33
    hotrodjack33
    Forget them oval pistons...if you put SQUARE pistons in a 350 (4.000˝ bore and 3.480˝ stroke) ...you get a 445 ci small block;)
  15. camshaftgrinder
    camshaftgrinder
    The early duntov stuff is ok, that being said small valves and small cubic inch, any motor for that matter you want to open the intake valve as quickly as possible. This 283 needs a Racer Brown st14. 266 advertised duration and .485 lift 108 lobe center. Racer was way ahead of his time with valve acceleration rates. Yes I can grind one of these.
  16. 55blacktie
    55blacktie
    How creative do you want to be? I bought a used, 2nd-gen. LT-1 OEM Corvette cam, EFI manifold and throttle body to use on a 283. The 2nd-gen. LT1 has reverse cooling/w dry manifold. The manifold was modified to work on a 1st-gen. engine. 60-degree Chevy V6 roller lifters could be used in place of aftermarket linked roller lifters. The earlier 2nd-gen. LT1 cams have the mechanical fuel pump concentric and distributor gear. Roller cams don't wear out and can be reused, if not damaged, and no need to worry about them going flat during break-in. That cam is rather mild in a 350 but a good choice for a 283. The engine, along with a T5 transmission, were going into a 53 Corvette kit car. However, shortly thereafter, I inherited my dad's 55 T-bird, sold some of the Chevy parts, and donated the rest to my daughter's hs auto shop. I can't say I was being practical with the 283 build, but I didn't break the bank. It's amazing what you can discover on the net. In my case, I prefer learning from others and avoiding costly mistakes. At the time, there wasn't much available in the way of aftermarket EFI systems. There are more, better choices available, now.
  17. 55blacktie
    55blacktie
    I just remembered that I used 2nd-gen. LT-1 aluminum heads, too. Some coolant p***ages had to be welded up, and a hole cut into the front of each head for routing external coolant hoses. The cost of used heads+mods was considerably less than buying new 1st-gen aluminum heads.
