Art & Inspiration brush/spray can paint jobs
Discussion in 'The Hokey Ass Message Board' started by rusty1, Apr 13, 2021.
  1. Blues4U
    Blues4U
    from So Cal
    That looks great. I'm curious what you used to retain the hood onto the body?
    GordonC likes this.
  2. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    The art of brush painting with enamel is having a really good quality natural bristle brush and knowing how to use it.
    The trick to getting a nice brush job is to learn how to "tip it off" as they say in the trade. I've brush painted several cars and gotten very good results with no other work. But then I'm not picky. In the mid '60s my buddy and I got kicked out of Washington Park in Denver for painting my '46 Buick in the park. A 3.00 gallon of surplus Air Force Blue paint and a couple of cheap brushes did the trick. A case of beer helped, too.
    Rawrench, deadbeat, AHotRod and 3 others like this.
  3. blowby
    blowby
    from Nicasio Ca
    Ha, many years ago when I was young and my Corvette was black primer..
    Friday night, my buddy and I were getting ready to cruise for chicks in the Vette. I bought two rattle cans of black primer to freshen it up. So right around dusk we pulled in behind a bakery on the main drag, he started down one side and I went down the other. There were some houses on the hill behind the bakery, I guess that's what happened, because halfway through the cops showed up rather excitedly. Fortunately my paperwork was in order and we were allowed to finish up and move on.
    deadbeat, bobss396, swade41 and 6 others like this.
  4. chessterd5
    chessterd5
    from u.s.a.
  5. GordonC
    GordonC
    Blues4U - The hood is kept on by a center pin that I welded on the hood which inserts where the normal A hinge would go on the cowl. I then used some standard hood hold downs on the two sides of the radiator. Seems to work ok so far. Here's a pic.
  6. KandN Kustoms
    KandN Kustoms
    Spay bombed the roof of my Rambler a couple weeks ago, if that counts? 20210404_130620.jpeg 20210404_130632.jpeg 20210405_172458.jpeg 20210405_172520.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    Rawrench, deadbeat, clem and 18 others like this.
  7. chessterd5
    chessterd5
    from u.s.a.
  8. Mr48chev
    Older Waco Texas rodders will tell About Laddie Segrest painting his 32 Coupe with Gibsons true black spray cans. He used several cases of paint and color sanded between coats just as you would a high end spray job.
    If a guy is good with International farm tractor red the International Harvestor brand spray bomb paint is some seriously good paint. I painted the front of a tractor with it and the farm workers on the dairy washed it just about every day with a pressure washer and they didn't damage the paint work.
    My 48 had green paint over brushed on primer when I bought it in 1973. The car wash spray wand took a lot of the green paint off but didn't touch the brushed on primer and I block sanded a lot of that smooth and then primered over it again.
    Boat paint is pretty spendy but a lot of high end boats are painted by what is called rolling and tipping. Roll and area on with a roller and follow with a tipping brush to flow it out. That is on multi million dollar boats.
    deadbeat and Blues4U like this.
  9. Flathead Dave
    Flathead Dave
    from So. Cal.
  10. Mike
    Mike
  11. Blues4U
    Blues4U
    from So Cal
    Ah, clever! Thanks for the info. One of these days I'm going to add a hood like that. BTW, that paint is just gorgeous, that came out really well.
    GordonC likes this.
  12. Blues4U
    Blues4U
    from So Cal
    I've used a lot of it over the years, I probably still have a few cans in the paint cupboard. They have a few other colors besides red, but not much. I used a lot of the flat black and the gloss black over the years. Like you said, good stuff.
  13. donsz
    donsz
    You might want to Google: "50 dollar rustoleum paint job" Many of the articles describe using a roller, some of them look pretty good (in the pictures at least).
  14. Casey Riley
    Casey Riley
    from Minnesota
    I'm learning a lot in this thread. I'm enjoying it. Thank you
    deadbeat and GordonC like this.
  15. adam401
    adam401
    My car is brush painted. As I do the metal repairs I sand an area, fix it then brush it again. It'll get sanded back to metal again for a proper paint job eventually.
  16. Greaseballs
    Greaseballs
    I used this technique to paint the hull on my vintage Chris Craft Constellation when I owned it.....painted all 50 foot of her every season. I got so good at the technique that people thought it was a high-dollar spray job. Sanding prep work was key along with proper outdoor air temperatures and humidity levels and properly thinned epoxy paints. I've never thought of applying this technique to a hot rod.....until now!
    Blues4U likes this.
  17. 4woody
    4woody
    I'm going to brush/roller paint my truck in the driveway, but I live in a tightly-packed suburbia, so overspray on the neighbors cars would be a problem. I tried to get Tekaloid coach paint from the UK, but nobody would ship it to the U.S., so I settled on doing it with marine paint (EZ Poxy, which is not epoxy at all).
    I'm almost ready to paint the bumpers (The first parts to get a finish coat), and will post pics soon.
    warhorseracing, AHotRod and Blues4U like this.
  18. This works great in Rustoleum…...
  19. Here is a great video about Coach Painting as I mentioned. Not some backyard hack home depot paintjob.
    deadbeat and safetythird like this.
  20. 283john
    283john
    280655_10150249369651687_2337233_o.jpg this is rolled-on Rustoleum. Been on there over ten years.
  21. Rusty Heaps
    Rusty Heaps
    8DEB3919-2602-46A2-B987-3D0982C52061.jpeg 6B975B0F-72A8-46F0-9D4E-DFA3557E1151.jpeg I’m at it again! Rustoleum oil based. Unfortunately I started with a Home Depot 4” roller, the lint started to pull off into the paint, swapped out for a Purdy 4”. It’s a 50 footer! But considering how rough the roof was anyway, it’s not bad.
  22. wheeldog57
    wheeldog57
    The Chevy was painted with Rustoleum through a gun 11 years ago. Still ok but I think it's time to do it over.
    The roadster is brushed on with tractor paint. Two coats with a good brush 24 hours apart. Had a couple of runs but they sanded out then re-brush.
    NoSurf, Rusty Heaps, adam401 and 4 others like this.
  23. rusty1
    rusty1
    old thread I started way back; anything new to add?
    Chucky likes this.
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I bought my two sons a OT Pinto to run around in during high school. One weekend - it was prom weekend and one son did not go - we masked and spray canned flames and graphics over the entire body with two colors of spray cans.
    It was voted Best Student Car and featured in the yearbook two years in a row.
    loudbang and b-body-bob like this.
  25. swade41
    swade41
    from Buffalo,NY
    Rustoleum with 4 inch foam roller
    17 yrs later
    clem, Chucky, Lone Star Mopar and 7 others like this.
  26. swade41
    swade41
    from Buffalo,NY
    White base is rolled on Rustoleum and the orange/yellow panels are spray cans
    11 yrs later still holding up
  27. williebill
    williebill
    Those look damn good!
    swade41 likes this.
  28. swade41
    swade41
    from Buffalo,NY
    Thanks, it's a lot of labor doing it that way but sweat equity is part of the game
  29. bobss396
    bobss396
    We did the stock cars with Rustoleum quarts and a disposable 3" roller that came with a chintzy roller tray. Of course thin it with a splash of lacquer thinner.
    Damn... the cars looked mint from the stands. Touch up was done with spray bombs. Before the feature, we would take anything, AFT, WD40 on a rag and wipe the car down.
    williebill likes this.
  30. continentaljohn
    continentaljohn
    IMG_6435.jpeg Not a car but we make mahogany boats and brush on the varnish. We dry sand flat every 3 coats and do about 12 coats total . The micro finish is spot on to our spray booth urethane . So why not a car with a similar viscosity..
