Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Squablow
    Squablow
    The woodgrain dash looks really good, at least in a picture. I like it.
    Stogy, Elvis100 and loudbang like this.
  2. TigerFan
    TigerFan
    from Athens, GA
    I agree with Cyclone Kevin. This thread is just terrific.
  3. Elvis100
    Elvis100
    Thanks, I enjoy sharing it
    Stogy, Cyclone Kevin and loudbang like this.
  4. Elvis100
    Elvis100
    The SAR quarter panels are not finished, the corners need small filler pieces and doublers where they mount.
  5. Elvis100
    Elvis100
    Squablow, Stogy, Ottomotive and 7 others like this.
  6. Elvis100
    Elvis100
    Worked on the quarters again. Added the small tab with a square hole for a carriage bolt that also goes through the sill plate. Drilled the hinge bed holes and tweaked the hinge beds to get the hinges to sit flat.
    Squablow, brEad, Stogy and 3 others like this.
  7. Your work is awesome, and shows that if you break it down in to tasks, the whole project comes together. When your posts come up, I open them right away.
    Thanks!
    Stogy and loudbang like this.
  8. Never2old
    Never2old
    from so cal
    Do you find that all of your sheet stock and repo parts are far softer than Ford originals? I do.
    Dak Rat, Stogy and loudbang like this.
  9. Elvis100
    Elvis100
    Thanks. It seems kind of daunting sometimes, then I get a couple projects moved forward and I get reinvigorated
    Stogy, loudbang and Cyclone Kevin like this.
  10. Elvis100
    Elvis100
    Defiantly, the original metal doesn’t move like modern metal.
  11. Elvis100
    Elvis100
    Finished up the quarter panel modifications on the drivers side. Then I test fit the panel above the decklid
    Did some pressing on the hinges to make them flat...they have had a rough life
    brEad, Stogy, Cyclone Kevin and 4 others like this.
  12. Elvis100
    Elvis100
    Got the hinges flattened, pins removed and cleaned. The first hinge pin came out no problem, the next two I had to drill out. The last one was the hardest. They had already had the pins replaced at some point so I will need a couple oversized pins. This should be good for mock-up
  13. Rocky
    Rocky
    Classified Editor
    Those SAR quarters also work for 5 windows with a little work. 34floors1_09small.jpg
    brEad, Stogy, Ottomotive and 2 others like this.
  14. Elvis100
    Elvis100
    Test fit the quarter panel support and the “hoop” with original b-pillar brackets. The original “hoop” wasn’t savable from its heavy modification and liberal lead application
    brEad, Stogy, Cyclone Kevin and 5 others like this.
  15. Elvis100
    Elvis100
    Pressed the dimples in the wheel wells
    Was easier to get the nuts on the back by rotating the body
  16. WIDE BOX BENNY
    WIDE BOX BENNY
    NICE!
    Cyclone Kevin and Elvis100 like this.
  17. Elvis100
    Elvis100
    Indexed and drilled the holes for mounting the tack strip around the rear of the cockpit. Eventually I’ll rivet this all together, but I used small machine screws to attach the “hoop”. I’m really happy with how this is fitting
  18. dumprat
    dumprat
    from b.c.
    Amazing work you do!
    Steel gets harder as it ages, new metal of the exact same alloy will be softer than 100 year old stuff. The new material won't have the nickel content of the original either.
  19. krylon32
    krylon32
    from Nebraska
    Great work, you are a craftsman.
  20. Elvis100
    Elvis100
    Made a set of the brackets to mount the top irons and temporarily installed them with bolts. These will get rivets for final assembly
    Test folded a set of top irons, checked that they folded correctly
  21. Elvis100
    Elvis100
    After a failed attempt last year to steam bend top bows...we have successfully done it.
    hfh, Stogy, Tim_with_a_T and 7 others like this.
  22. vtwhead
    vtwhead
    be nice to see a tech on that.
  23. Elvis100
    Elvis100
    There is a good video on YOUTUBE that has all the technical information. Basically I built a giant machine that bends the steamed oak blank.
  24. You Sir are genius, whether working with metal or wood.
    The37Kid, Stogy, milwscruffy and 2 others like this.
  25. irondoctor
    irondoctor
    from Newton, KS
    Outstanding!
    Stogy, loudbang and Elvis100 like this.
  26. Elvis100
    Elvis100
    Worked on a set of door jam tins. I have another roadster project for sale and it needed the tins. Don’t know if I’ll use these or the originals on this car
    Stogy, brEad, loudbang and 3 others like this.
  27. Elvis100
    Elvis100
    Fit check the second one
  28. Elvis100
    Elvis100
    Just a quick post, if you are building a roadster from a pile of parts or converting a phaeton. These will be available soon
  29. Elvis100
    Elvis100
    Made a package tray using a pattern a friend sent. It was just a little too wide to fit in my bench top planer, so I used a handheld power planer to get it down to 3/4 inch. Sanded and first coat of marine varnish.
    Stogy and Squablow like this.
  30. Great build thread. What is the story on what looks like a homemade rotisserie from engine stands? I like it small and compact.
    Stogy likes this.
