Technical Distributors
Discussion in 'The Hokey Ass Message Board' started by junkman73, Apr 16, 2021.
  1. junkman73
    junkman73
    So distributors are too new of a subject to discuss????
  2. alchemy
    alchemy
  3. ol-nobull
    ol-nobull
    Say what???? Perhaps too new for engines that are too new to be HAMB acceptable. Jimmie
  4. junkman73
    junkman73
    My thread was deleted from last night for being too new of a subject.My question was about distributors and not the engine it was going on.
  5. George
    George
    repost w/o mentioning the engine...
  6. junkman73
    junkman73
    So my question was has anybody cut the bottom of one type of distributor and grafted it to the top half of another.I want to use a Chrysler type of ignition on a chevy.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Reinventing the wheel?
  8. greybeard360
    greybeard360
    Don't know why you would go to that much trouble..... points is points.
  9. junkman73
    junkman73
    The engine that I have was never made available with a points style ignition.And nobody made one either.Picked up the motor for free.So why not try to put a carb and ignition on it.
    Elcohaulic and chryslerfan55 like this.
  10. junkman73
    junkman73
    want to put points ignition on an engine that never had them.
  11. Budget36
    Budget36
    Just a question, is a carb intake available for it?
    I’ve not done what you want to do, but think I’d start with two distributors side by side to get a perspective of what needs to be done.
  12. junkman73
    junkman73
    yes a carbed intake is available.And I did plan on doing a side by side with the two dizzy's.I wanted to know if anybody had done anything like this before that could give some tips.
  13. Jokester
    Jokester
    Saw a hot rod once with a Saturn engine. He had built a manifold for it, got rid of injection and electronic ignition. He had rigged up a belt driven distributor with a toothed type belt (like a blower drive). It even had a mount to enable timing adjustment. Pretty neat I thought.
    .bjb
    junkman73 likes this.
  14. Budget36
    Budget36
    I’ve seen pics of distributors that @RichFox has done, maybe he can add some tips for you or PM him for some ideas.
  15. RichFox
    RichFox
  16. Budget36
    Budget36
    I’d say Rich has a handle on it;)
    Desoto291Hemi and junkman73 like this.
  17. junkman73
    junkman73
  18. junkman73
    junkman73
    I'm headed down to my local pick and pull for supplies .
    Desoto291Hemi likes this.
  19. RichFox
    RichFox
  20. Blues4U
    Blues4U
    from So Cal
    @GMC BUBBA does a lot of this type of thing. Try reaching out to him for advice.
  21. Rusty O'Toole
    Rusty O'Toole
    If you mean what I think you mean, I would probably use the stock crank trigger ignition and hide the coils.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
  23. People have been modifying distributers for a long as there have ben hot rodders and racers. your only limit is your skill.
  24. junkman73
    junkman73
    Picked one from an old chevy inline 6. Shouldn't be too difficult to make something work .
  25. 55blacktie
    55blacktie
    If nobody ever asked, "What if," we would still be cave-dwellers who grunt to communicate. I would ask, however, will your end product be an improvement over what you already have.
    chryslerfan55 and Blues4U like this.
  26. junkman73
    junkman73
    What I currently have is a few hundred pounds of s**** metal sitting in my driveway that will not do anything without a bunch of electric wizbangs hooked to it.The end result I am hoping for is an engine that will start and run.
  27. junkman73
    junkman73
  28. junkman73
    junkman73
    After measuring things I will have enough length on the chevy points unit to graft the drive gear and bottom of the electronic unit together.
  29. That’s great,,,,,,points work just fine as well .
    I think some are afraid of using points,,,,,because they don’t really understand the settings .
    The exact same way that a lot of guys can’t adjust solid lifters .
    They are adjusting them every couple of weeks,,,,,nothing wears that bad,,,,,or the rockers don’t move that much out of adjustment.
    Anyway,,,,,,,very pleased about the points setup .
    Tommy
    chryslerfan55 and junkman73 like this.
  30. junkman73
    junkman73
