Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Beanscoot
    Beanscoot
    I'm envious of your bubble balancer.
    One minor point, wouldn't it be a good idea to paint all the surfaces of the wheels? Or is everything primed anyhow?
    31Apickup, loudbang and Paul like this.
  2. Paul
    Paul
    Editor
    The entire wheel got primer,
    It's the same stuff I used on the body of my '27, but brown and without a top coat.
    It's been doing fine with no signs of failure in six plus years.
    The gloss top coat on the visible parts was just to make them look shiny.
    I did put a good layer at the bead area to help ensure an air tight seal.
    Both primer and top coat are rust inhibitors.
    RodStRace, loudbang and Stogy like this.
  3. Paul
    Paul
    Editor
    shot paint on the rear wheels yesterday between raindrops
    cured just enough to stretch L78-15 tires on today.
    these are used tires, still soft with no visible issues
    sanded the beads lightly to get the crud off and wiped the beads with Track Bite to soften them a bit.
    that smell sure brought back memories..
    sprayed the beads with Windex to lube them
    and they went on with minimal effort.
    didn't need the strap on the bigger tires as the bead was just touching the rim
    aired up and balanced, one took 4.5 oz and the other took 5
    washed and mounted
    PXL_20210315_164745004.jpg PXL_20210315_165650630.jpg PXL_20210315_175038365.jpg PXL_20210315_181332034.jpg
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
    Never cared much for white walls, but I must admit they work great on that car. Definitely gonna be a fine little hotrod.
  5. 31Apickup
    31Apickup
    Looks good, I’ve balanced a lot of wheels and tires with a static balancer like that. Also have an EZ cabinet. IMG_1489.JPG
  6. Paul
    Paul
    Editor
    That is so cool!
  7. loudbang
    brady1929, Tman and bct like this.
  8. Paul
    Paul
    Editor
    been far too long between updates here,
    or even progress on the Hulk
    busy with life's distractions I guess.
    today I finally spent a few hours on it
    figured it was time to put together some headers
    started by pulling out all my bits and pieces of header makin' stuff
    chose to use a set of separate flanges, three on each side with the center ports joined
    and will run 1-3/4" primaries on all three.
    slice and dice some short sections of tube
    shape them over some square tube
    weld the pieces together
    trim and weld them to the flanges
    and clean them all up
    and test fit.
    PXL_20210415_184117563~2.jpg PXL_20210415_195620776.jpg PXL_20210415_205257559.jpg PXL_20210415_212313063.jpg PXL_20210415_232815206.jpg PXL_20210416_181245775.jpg PXL_20210416_183152640.jpg PXL_20210416_191022627.jpg PXL_20210416_211240679~2.jpg PXL_20210416_220917766.jpg PXL_20210416_224035632.jpg PXL_20210416_224354063.jpg PXL_20210416_224403513.jpg
    tomkelly88, OFT, Just Gary and 16 others like this.
  9. Paul
    Paul
    Editor
    that was the easy part,
    now I have to decide on a design..
  10. jebbesen
    jebbesen
    from Winona, MN
    Looks great! If I'd have seen this earlier I'd have lent you my die that makes the end ones. I really like how Rockets and Cads look with the separate flanges!
    kidcampbell71, loudbang and Paul like this.
  11. Part Timer
    Part Timer
    Always enjoy seeing your work. Nice execution on the siamesed center ports. Glad to see you got a chance to get back out in the shop. It is amazing how life distracts us. Thanks for the inspiration.
  12. kidcampbell71
    kidcampbell71
    No doubt. I wanna' quote biblical stuff when Paul works. :) One of the best, here.
    "So tidy !"
    RustyBullet, loudbang and Paul like this.
  13. Paul
    Paul
    Editor
    been thinking about header design since this car first started to form in my mind
    few things are more important in projecting the overall feel,
    no fenders, no top, open engine, multiple carburetors,
    and in your face headers.
    I'm down to what really is only two or three designs
    1. separate and unjoined,
    short like Clarence Catallo's Olds in his Silver Saphire
    or long like Gene Chan's Hemi in his '23 T
    or the early version of John Gate's Cadillac in his '15 T
    2. joined
    like Norm Grabowski's Cadillac in his Lighning Bug
    or John Gate's later version Cadillac in the '15 T
    number 1. would be wild but
    number 2. would be easier to fit mufflers to..
    1:
    2:
  14. dutchrod
    dutchrod
    Just found this one , great build !
    Love it
  15. AndersF
    AndersF
    Number one is the hardest one to pull of to get it right.
    But done right it really look great.
    I would do number two couse it look more cleaner.
    Number one look more like showrod when number two have more of a streetdriven look.
    OFT, loudbang, WalkerMD and 1 other person like this.
  16. Paul
    Paul
    Editor
    Another reason to choose #1 is I have parts on hand to get it started, if I don't like it it wouldn't be much time of effort lost if I were to cut and redo..
    Stogy, loudbang and AndersF like this.
  17. RICH B
    RICH B
    I think #1 is best of the choices presented.
    Paul likes this.
  18. vtwhead
    vtwhead
    ^^^^^I agree with Rich
    Paul likes this.
  19. AHotRod
    AHotRod
    How's your hearing Paul? :)
    I made my exhaust go all the way out the back on my Coupe this time, yes, it' has no mufflers, but I'm almost 65 years old and my hearing is not as it once was from working at NHRA National Events and NASCAR races for 30 years.
    Make it enjoyable !
    Stogy, loudbang and Paul like this.
  20. Paul
    Paul
    Editor
    Yes, it will have mufflers and exhaust will exit out the back.
  21. RICH B
    RICH B
    I never realized how the headers were hooked to the exhaust on the car until I saw the rebuilding pictures on Instagram.
  22. bchctybob
    bchctybob
    You're absolutely right Paul, at this point header choice can make or break the overall look. I vote for #1 if you cap them and run mufflers underneath. They look nice and not too long. The Gates car looks good but sorta common. If you split the center ports so you have 4 ports on each side to deal with, I kinda like the 2 into 1 and 2 into 1, with two collectors per side. Again, capped with mufflers underneath. If you plan on lots of chrome and candy paint, the Chan style would work.
    You know, I've been known to build more than one set for my cars and swap them out occasionally. Build something for now and build something else later if something comes to mind.
  23. Paul
    Paul
    Editor
    tacked together some pipes for a visual..
    'might look good it they were trued up and shiny
    but right now they seem a little.. ratty
    PXL_20210419_001415037.jpg PXL_20210419_001422393.jpg PXL_20210419_001437883.jpg
  24. Marty Strode
    Marty Strode
    don colaps, Jet96, brEad and 7 others like this.
  25. Paul
    Paul
    Editor
    Cadillac in a T Roadster, you get a p***
  26. Paul
    Paul
    Editor
    my first set 35 years ago
    don colaps, OFT, Jet96 and 8 others like this.
  27. Paul
    Paul
    Editor
    some more over the years..
    there were more, rarely thought of taking pictures.
    camera or film not handy or if pictures were taken they melted away
    454 003.jpg 8-10-08 012.jpg IMAG2291.jpg 20160703_181838.jpg 20170817_191046.jpg
    jebbesen, bchctybob, Stogy and 4 others like this.
  28. Marty Strode
    Marty Strode
    I have the twin to it !
  29. loudbang
    This set is pretty Nifty. :)
    warbird1, bchctybob, Paul and 2 others like this.
  30. loudbang, bchctybob and Paul like this.
