Hot Rods Hot inline six cylinders -
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 13, 2021.
  1. lake_harley
    lake_harley
    I've had a soft spot in my heart for 6 cylinders since I was a teenager or in my early 20's when there was an article about Kay Cissell in Hot Rod Magazine. There are some great photos of really neat 6 cylinder engines in this thread, but what it's missing is VIDEO with SOUND! Nothing so sweet sounding as a 6 cylinder at full boil!
    Lynn
    Fingers, 41 GMC K-18, Hnstray and 2 others like this.
  2. Blake 27
    Blake 27
  3. 41 GMC K-18
    41 GMC K-18
  4. sunbeam
    sunbeam
    The Ford 300 most bang for the buck.
    chessterd5 likes this.
  5. 251 Flathead Desoto - dual carbs, dual exhaust, dual point ignition, reground cam, lightly shaved head - all shoved down into a 1948 Plymouth P15
    Its not in a car yet.... and its not "hot" lol But it is a 265 Dodge flathead with factory dual carbs and dual exhaust. Its factory hot. lol
  6. NashRodMan
    NashRodMan
    This one is in my avatar, 41 chevy coupe. Bored 30 over, cammed, 4 barrel, Offy intake, cast dual exhaust manifolds, dual exhaust. 5 speed . Wish I had a more appropriate air cleaner.
  7. hkestes
    hkestes
    This was the .060 over 59 model 230 that was in my old 48 Plymouth. Offenhauser intake, Carter Webber carbs, Fenton repop headers, mini-HEI and Edgy aluminum head.
  8. D-Russ
    D-Russ
    262 Ford inline in the 640 XO/PP Virginia HAMB Special built and owned by @john mullen (turn up the volume):
    @Cody Walls needs to post up pics of the 6 that was in the 59 wagon, as well as his current mill for the 32.
  9. chessterd5
    chessterd5
    from u.s.a.
    That Sir, is a fact!
    7 main bearings
    Timing GEARS
    50 cubic inches per cylinder
    It will take up to a .700 lift cam from the factory. Built right it will make about 330 ftlbs of torque.
    Just don't rev it past 5500 rpm with a stock bottom end!
    41 GMC K-18, loudbang and Hnstray like this.
  10. Six Ball
    Six Ball
    from Nevada
    270 GMC in my '53 Chevy pickup at it's last freshening in 2008. It's been there since '75.
  11. Ken Smith
    Ken Smith
    Alliance Vendor
    235 ci Chevy. Tattersfield intake, (2) progressive 2bbl webers, Fenton headers, HEI ignition, A/C.
    Hooked to a T5 5 speed transmission in a 51 Chevy Coupe.
  12. sunbeam
    sunbeam
    I took a 85 F150 300 6 with a c6 trans swapped a 240 head 300 fi exhaust manifolds a offenhauser C manifold with a divider between the front and back half with the carb mounted sideways every other cylinder pulled from other side of the carb like a 180 V8 manifold a mild crane cam. The truck in street clothes tires and exhaust was in the 14s
    Randall, VANDENPLAS, Hnstray and 2 others like this.
  13. Stovebolt
    Stovebolt
  14. Six Ball
    Six Ball
    from Nevada
    I have one of those too. Too bad it's too big for the vintage engine cl*** at Bonneville. Too big for much else.
  15. chessterd5
    chessterd5
    from u.s.a.
    That is cool!
    Mine is a little more tame. Stock 300 single exhaust and one barrel carb. A C4 automatic and a 8 inch with 2.79 gears. I guesstimate 90 hp and 220 ftlbs of torque to push a basically 2000 lbs vehicle. My hop up plans are 250 Chevy rockers, a motorcraft 2 barrel carb on an adapter, and the EFI exhaust manifolds.
    Randall and VANDENPLAS like this.
  16. sunbeam
    sunbeam
    The big things about most inline 6s is ****py intake and exhaust . think about a 300 cu inch v8 with a one barrel carb and a poor intake and exhaust. Early heads had ajustable valve train and larger valves If you can find a 240 head it is worth 1/2 point more compression.
  17. set me on fire
    set me on fire
    my 240 - runs great luv driving it - 65 f100
  18. Jacksmith
    Jacksmith
    from Aridzona
    I was at a show several years back and saw this beauty... IMG_1721.JPG IMG_1723.JPG IMG_1726.JPG Don't know who's it was, but hats off to him!:
  19. 1961 Ford 223, 265 Clay Smith Cam, early style Offy valve cover, Clifford intake and splitter headers, 390 Holley, shaved head, Mallory mechanical advance dual-point ignition.
  20. cheezwiz
    cheezwiz
    I may have posted this pic before somewhere but here's Malcolm Studebaker Berry's blown flathead 6 he built for a 53 Stude he is working on....Gotta always mention, Malcolm is 80 !
  21. chessterd5
    chessterd5
    from u.s.a.
    80 years young !
    God bless him!
    41 GMC K-18 and Six Ball like this.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Pics of my HAMB friendly inliner powered hot rods are splattered all over the inline related threads on the HAMB, but in case you have not seen some here is a sample. For more pics check out my profile album or PM me. Enjoy
  23. Six Ball
    Six Ball
    from Nevada
    This is my favorite so far. Is Malcolm fro Arizona?
  24. Hellfish
    Hellfish
    4.2 Jag I'm working on.
    41 GMC K-18, Fingers, Tman and 2 others like this.
  25. Six Ball
    Six Ball
    from Nevada
    What do you plan to put the Jag in?
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The most beautiful production six ever built.
    Fingers likes this.
  27. 6inarow
    6inarow
    I would love one of those.. School. me on the desirable years.
  28. cheezwiz
    cheezwiz
    No , Dayton Ohio...
    Driver50x and Six Ball like this.
  29. 210superair
    210superair
    from Michigan
    I gave serious consideration to buying this when he listed it, but I decided to stay married instead.
  30. nickleone
    nickleone
    1962 Rambler 6 with 3 autolite 1100s. Progressive throttle, runs on center carb mostly. Home made manifold top. tripower.jpg
