Hot Rods Cody Walls Builds 32 Ford 3 window coupe “The Ardun Killer “ .
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Aug 21, 2019.
  1. Cody Walls
    Cody Walls
  2. AmishMike
    AmishMike
    Your car is sweet as always... nice looking Buick in the back ground
  3. Cody Walls
    Cody Walls
  4. hotroddeuce
    hotroddeuce
    from Mi
    Such a great build to follow! just badass!
  5. 61SuperMonza
    61SuperMonza
    The execution one this build is top flight.
    The motor is just******in. She's going to be special.
  6. loudbang
    Wow that engine is a beauty and will be the focal point of the Hot rod. :)
    Stogy, Nostrebor, Cody Walls and 4 others like this.
  7. Cody Walls
    Cody Walls
  8. Joe Blow
    Joe Blow
    Those Webers and that engine = wicked cool.
    rod1, lothiandon1940, Stogy and 3 others like this.
  9. rockable
    rockable
    Wow, Cody! You are so good at what you do!
  10. Runnin shine
    Runnin shine
    Another in the running best example of what a Hot Rod is for the dictionary. Especially due to the Hot engine.
  11. 1low52
    1low52
    I understand you will be at Jalopyrama. Will this 32 be there?
    Stogy and loudbang like this.
  12. Bcap55
    Bcap55
    from PA, USA
    That engine looks great, I really like the header pipe layout. Great job!
  13. Cody Walls
    Cody Walls
    Yes the 32 and my wife’s Buick the EJob will both be debuting there in bare metal
  14. Cody Walls
    Cody Walls
  15. straykatkustoms
    straykatkustoms
    You are Blessed with a lot of talent. Thank you for posting the updates.
    Stogy, Cody Walls, loudbang and 2 others like this.
  16. Cody Walls
    Cody Walls
  17. jimmy six
    jimmy six
    I’ve heard that bangers and flathead V8’s are the only engines allowed at the RoG. A guy with a flathead Ford 6 was told to go home.....
    Outback and loudbang like this.
  18. Cody, Cody, Cody if I told ya once, I told ya a hundred times, every time I see your work I’m amazed.
    Stogy, Just Gary, Cody Walls and 3 others like this.
  19. Blues4U
    Blues4U
    from So Cal
    They make special allowances for select cars.
  20. rob-redm
    rob-redm
    nothing like inline 6 Chevy or Big Jimmy 6
    Stogy, LAROKE, Just Gary and 3 others like this.
  21. Cody Walls
    Cody Walls
    This year there doing a overhead valve 49-54 class so I fall in the category
    But there have been other inliners that have run in the past
    Tman, lothiandon1940, Stogy and 2 others like this.
  22. Cody Walls
    Cody Walls
  23. rod1
    rod1
    Killin it! Run,Arduns,Run..
    Stogy, Cody Walls and loudbang like this.
  24. Cosmo49
    Cosmo49
    Wishing for faux woodgrain and a massive array of gauges including an altimeter and an*****og clock. Hahahaha, whatever you do it's gonna be cool!
  25. Cody Walls
    Cody Walls
    Even though I totally agree .I have to do something totally different than anything else I’ve seen done before .and I’ve never seen anyone put a 1955 simca dash in one of these things
    Outback, Nostrebor, winduptoy and 8 others like this.
  26. Just Gary
    Just Gary
    Cody, how do you prevent surface rust on your bare metal during the build?:confused:
    Gibbs? Something else?
    BEAUTIFUL build- and photography- btw.:cool:
  27. Cody Walls
    Cody Walls
    Climate controlled shop , and I try not to touch the metal with bare fingers ,
    the oils and acids from ones hands can make things rust .
    I don’t put anything on it because it’s such a pain to get off when it comes to paint
    Tman, Nicholas Coe, loudbang and 9 others like this.
  28. lcfman
    lcfman
    from tn
    That Buick steering wheel is spot on.
    Nicholas Coe, Stogy and loudbang like this.
  29. Cody Walls
    Cody Walls
