Features The 1955-1956 Plymouth and Dodge Thread
Discussion in 'The Hokey Ass Message Board' started by MrBelvedere2, Feb 12, 2009.
  1. George
    George
    Checked with Fatman?
  2. 35desoto
    35desoto
    There was a company in the USA that was cutting and rewelding the kingpin boss for MOPARs for the years 1939 through to 1956 and thus created a dropped spindle. I did have a set but here in New Zealand they are not legal on our cars according to our beauacratic Govt (welded suspension items are illegal). If someone had enough orders to recast the whole spindle that product would find a good market down here in the South Pacific.
    Hemihead_NHRA and stillrunners like this.
  3. Sperduton
    Sperduton
    from NJ
    I used a set of drop blocks to lower the front of my 56 a bit.
  4. Bbdakota
    Bbdakota
    I ordered new heavy duty coil springs and had them made to lower the front 1-1/4" from stock on my 56 dodge. No alignment problems when I had the front end aligned.
    57 and on used torsion bars. Could just crank the adjustment to lower the front
  5. As George said....check with Fatman as they did/do drop spindles & have done for years....and as 35DeSoto mentions they are illegal in NZ and here in Oz also......shorter coil springs and/or remounting the lower spring pocket on the bottom of the lower A arm have been used to lower our independant Mopar front ends...........andyd
  6. I've dug through the thread and didn't come up with any solid answers. Has anyone physically tried to fit a 1956 Plymouth front end on a 1956 Dodge? I know the Canadian 1956 Plymouth Mayfair had a specially tooled Dodge front clip, but that doesn't help me. I think the biggest areas of question are the fender height at the cowl, the hood width at the cowl, the contours at the cowl, and the overall length of the fender from cowl to frame horn.
    I ask all this because (1) I have a line on a nice Coronet club sedan, (2) I really like the Coronet body/trim lines from the cowl back, but (3) can't stand the fender and hood leading edges. No matter what I've seen people do to the Dodge front end, something isn't right about it when looking at the car as a whole. I think it is a combination of the headlights sticking out proud like tubes and then the cluster-f of angles where the hood front tries to peak in the middle, then curve up to meet the kick-up, and then curve up and around to go horizontal. Frenching the headlights seems to help, but then there's the hood. Splicing on Plymouth fender leading edges would probably look great, but then there's the grille. By the time I contour the fender leading edge, deal with the grille, and rework the hood, I surmise I'd have less work and a cleaner product in fitting a Plymouth front clip. At the end of the day, I'd be perfectly happy with a '56 Plymouth too.
    Anyone ever physically play around with mocking up the front clip or building a template?
  7. 302GMC
    302GMC
    from Idaho
    '56 Plymouth wagon I bought in '84. Surprisingly rust free for an Idaho farm county car, but with a whole bunch of dents & bumpers ripped to shreds. It started life as the absolute cheapest wagon offered in '56, black rubber on the gl***, 1 stick of chrome on the sides, painted trim on the lights & hood... We thought the '55 "Sportone #1" side trim had been added by the dealer to help sell it when new. On the + side, it was a 277'' V8 with overdrive, big heater, & the 1 piece plastic headliner was flawless. I traded a Chev V8 Crower cam kit & a pair of fuelie heads for complete body & paint work, & Ogden Chrome performed a miracle on the bumpers. I gradually found Belvidere taillights, headlight rings, hood trim, etc. for it, & bought a windshield & stainless trim from Neil Freman in Whitehall, Montana. Used a '55 center section in the grille, & '55 parking lights - ever try to find '56 parking light rubber retainers ? Found a Weiand 4 bbl intake for it, & bolted on an AFB from something. Dual pipes with the $11 red "barrel" mufflers every parts house stocked. Traded a valve job on a Datsun PU for the upholstery, which was 2 tone gray tuck & roll on the front seat & door panels - somehow the rear seat came up missing over the years. I had the garnish rails & jockey box lid chromed. I had a '56 Dodge signal seeking radio which was about twice as big as a Plymouth, but by reversing the heater controls, it just barely fit & sounded sweet. I used Magnum 500 wheels with 165 & 225 - 14 rubber, & cut 1 coil up front - the crossmember & pan stick way down on those cars ...
    I needed to pay taxes around 1996, so I put it in the "Thrifty Nickel" for $3500. Biker from Blackfoot rode up to look it over & offered $3 grand. We settled at $3200 & I kept the Magnums. We shook on it, & he came back a week or so later with the wheels, and the wagon was wearing the Americans in these pics.
    A few years ago, it shows up in the HAMB cl***ifieds looking exactly like it did the day the scooter guy brought the wheels back to me. Well, almost - the ****y hanging mirror got added, as well as the s****es in the tailgate.
    The seller made up a whole bunch of **** about how original everything was. He's asking $18,000 for it ... Wagon 1.jpg Wagon 2.jpg Wagon 4.jpg Wagon 5.jpg Wagon 6.jpg Wagon 7.jpg
    Dantana, Big Dad, 2deuces64 and 7 others like this.
  8. stillrunners
    stillrunners
    from dallas
    Man that was a nice looking wagon !
    klleetrucking likes this.
  9. George
    George
    A hard to find intake. You thinking of getting it back?
  10. stillrunners
    stillrunners
    from dallas
    And you can't give away those cast iron factory 4 barrel one's...
  11. "You can't give away those cast iron factory 4-barrel intakes," as in no one will take them even if you try to give them away? 4-barrel A block (1956 - 1966) intakes are selling for $500 and don't come up often since they only produced them from 1956 - 1962. They outperform the Weiand single plane on a street car. If you have a factory 4-barrel intake you can't give away, I'll give you $25 for your time and pay for shipping.
    caprockfabshop and George like this.
  12. newredporch
    newredporch
    from pittsburgh
    LOST ANGEL and stillrunners like this.
  13. vwfye
    vwfye
    from SW Oregon
    Working on bring this back to life. Been sitting since 78 2023-03-31-23-45-09-861.jpg
  14. Just Chad
    Just Chad
    Hi guys, thought I'd post as I was searching for some brake information on my 56 Coronet and found the HAMB (again). I don't want to over post, but here's some things I've done. I've rebuilt the door latches as they seemed to be somewhat of a common problem, the issue is the pot metal star wheel that breaks apart. I took my latches apart and made the star wheels out of steel using patience and a dremel and welded them back together. In the picture is my tail light treatment. The top lights are just bullet style plate lights that are now wired with the brakes/signals. The brake and reverse light lens' are 60 Impala that I machined down. The fish tail exhaust is homemade too. It's just a cruiser I have fun in. 20220731_112232.jpg 20220821_193225.jpg
  15. stillrunners
    stillrunners
    from dallas
    looking good.....nice job on them tailights !
    Just Chad likes this.
  16. patsurf
    patsurf
    how many hours to make that gear(s)?
  17. Just Chad
    Just Chad
    It took about 3 days, half day to get the doors apart and latches out. One and a half days to take the latches apart, make the patterns, turn down some rod to size, and grind the gears and re***emble the latches. Then half a day re***emble the doors. That's steady working 8hrs a day. What I found is any latches (if you could find them) for sale were used and already questionable, so this was a solid option. I have more pictures of the latches blown apart if it's something you're thinking about.
  18. gene-koning
    gene-koning
    I'd be interested in seeing a write up, with pictures of the door latch rebuild. My son has a 57 Dodge wagon.
    I've replaced those old latches on my stuff with modern post and claw setups because I drive my stuff a lot. Replacing the old latches with modern stuff is a lot of work on the door around the latch and handle area, adapting the handles to make them work, and then you need to add the door striker post to the door frame.
  19. patsurf
    patsurf
    thanks!-was wondering if any other latch ***y's are similar to rob parts from
    stillrunners likes this.
  20. wallyringo
    wallyringo
    1955 Plymouth grill insert, need some help with this fellows, how do I take off the grill insert. I'm prepping for paint and body work and this thing is driving me nuts. Where are the hidden bolts. Thanks in advance.
  21. stillrunners
    stillrunners
    from dallas
    You have to get some inside the fender towards the front.....if no one beats me I'll take some pictures tomorrow - it's 8:30pm here at my place.
    wallyringo likes this.
  22. ProStock1320
    ProStock1320
    from Spokane WA
    My former beater: '56 Plymouth Belvedere, 361/push ****on AT, '70 8 3/4 from a '70 B-body. Was my daily until she was sold to purchase a race car.
  23. stillrunners
    stillrunners
    from dallas
    not to get the grill off - hope these back side pictures help......including the pan below also..... upload_2023-7-7_14-11-30.png upload_2023-7-7_14-11-49.png upload_2023-7-7_14-12-25.png upload_2023-7-7_14-12-48.png
    wallyringo and Jalopy Joker like this.
  24. impala4speed
    impala4speed
  25. vwfye
    vwfye
    from SW Oregon
    Does anyone know of a transmission mount to put an a904 into a 56? Heck, I would fab one if I could get dimensions from anyone. It is almost impossible for me to get completely under the car currently to measure.
    Any he'p would be awesome!
  26. Dantana
    Dantana
    from San Diego
    This is a cool thread, goes back a long way with some great info. My buddy's dad built this 1956 Plymouth Suburban Sport and I have after it for the last three years. He finally sold it to me! I have some plans for it while I cruise it but here are the short specs - 413 Wedge with cross ram intake, bagged in rear (Front coming soon), shaved handles, tuck and roll interior and lots of other cool things.
  27. wheeltramp brian
    wheeltramp brian
    Guy named Scott used to own that wagon?
    Dantana and stillrunners like this.
  28. Dantana
    Dantana
    from San Diego
    Yessir.
  29. wheeltramp brian
    wheeltramp brian
    I thought so, but I haven't seen him around in years.
