Projects 33 3 Window Coupe
Discussion in 'Traditional Hot Rods' started by pennafxu, Mar 4, 2021.
  1. pennafxu
    pennafxu
    from Kentucky
    Frame rails were heated and beaten with a body hammer.
  2. pennafxu
    pennafxu
    from Kentucky
    Laid out...
    flathead 37, patmanta, brEad and 4 others like this.
  3. pennafxu
    pennafxu
    from Kentucky
    Clamped and ready for tacks.
  4. pennafxu
    pennafxu
    from Kentucky
    Back on the table...
    Using MIG this time to switch things up... Practicing on some coupons... IMG_1570.JPG throwing down tacks... IMG_1571.JPG IMG_1573.JPG
  5. pennafxu
    pennafxu
    from Kentucky
    X marks the spot...
    These areas will need m***aging with heat and hammer IMG_1576.JPG IMG_1577.JPG IMG_1578.JPG IMG_1579.JPG IMG_1580.JPG
    Tried a small run. Not bad for 25 years out the game!
    patmanta and chryslerfan55 like this.
  6. dumprat
    dumprat
    from b.c.
    If you are going to run a purchased spreader bar you will need to cut the boxing plates back a bit. The end at the front crossmember, and the front section of the frame is two layers. It will just make all the measurements weird the way you have it extended out to the very front of the frame.
    If you were closer I have a couple of frames you could look at.
    pennafxu likes this.
  7. rusty valley
    rusty valley
    snooping around your shop, i see a superhawk fender. 305, or 160?
    chryslerfan55 and pennafxu like this.
  8. pennafxu
    pennafxu
    from Kentucky
    I was looking at that....
  9. pennafxu
    pennafxu
    from Kentucky
    Actually an SS125... I’ve owned the 305 and wish I had never sold it...
  10. 2deuces64
    2deuces64
    At this point I would get your frame to the correct dimensions, then make and install your ex members Since you plan on channeling it I would build my own floor. Buy a sheet of 16 gauge cold rolled sheet metal ($100-150) and go to town. Here are pictures of the floor I made for my roadster. I raised it in the rear, built a shelf for my gas tank and built a tunnel for my drive shaft. 003.jpg 004.jpg 32 roadster- cabri 001.jpg 32 roadster- cabri 002.jpg 32 roadster- cabri 003.jpg ] 32 roadster- cabri 014.jpg
  11. 2deuces64
    2deuces64
    Here are pictures of the 33-34 sub rails. Since you plan on channeling your car , with your metal working experience you should be able to build your on. There is a guy here in Kansas that makes the sub rails his name is Steve at 620 241 7096 . You could use these as a start an add about 2" for your channel . These sell for about $400 s-l1600 (9).jpg IMG_20201231_120819986_HDR (1).jpg IMG_20201231_120855952_HDR.jpg
  12. pennafxu
    pennafxu
    from Kentucky
    Beautiful and very inspirational! Thank you.
  13. pennafxu
    pennafxu
    from Kentucky
    IMG_1590.JPG IMG_1591.JPG IMG_1592.JPG IMG_1593.JPG IMG_1594.JPG IMG_1595.JPG
    Continuing with the metal dressing on the frame...
  14. panhead_pete
    panhead_pete
    If you havent already check out Matt Murray's youtube channel Iron Trap Garage. He just did a floor on a heavily channelled 32. Might be of some help.
    Lil'Alb, chryslerfan55 and pennafxu like this.
  15. Mike Colemire
    Mike Colemire
    I really like watching Iron Trap garage, pretty interesting stuff.
    Lil'Alb, pennafxu and chryslerfan55 like this.
  16. KiwiGlen
    KiwiGlen
    I agree, @IronTrap is really cool, and since I'm not in a position to build a car myself, I can do it vicariously through Matt, Mike and the others there on the Iron Trap Garage youtube channel... as well as through build threads like this one here on the H.A.M.B..
    Glen.
    Lil'Alb and pennafxu like this.
  17. pennafxu
    pennafxu
    from Kentucky
    IMG_1596.JPG IMG_1601.JPG IMG_1602.JPG IMG_1603.JPG IMG_1604.JPG IMG_1605.JPG IMG_1606.JPG IMG_1607.JPG
    One rail done and dressed
    Outback, patmanta and brEad like this.
  18. pennafxu
    pennafxu
    from Kentucky
    Crossmember from p and j... 1” drop, needs to be welded in at a 7 deg angle... IMG_1608.JPG
    brEad likes this.
  19. I would recommend buying these subrails. once you get you frame ***embled, lay the subrails on the frame and slide body over and fill the areas between the subrails and the body depending on the channel you want. The build the floor pans too tie everything together.
    I went this route on my 34, but I was taking the channel out of the car.
  20. pennafxu
    pennafxu
    from Kentucky
    Which side is which in this picture?
  21. Subrail on right is p***enger side. the long flange sits on top of the frame rail. The body sits on the small flange. if you are channeling the car, just cut the flange off and add material as needed.
    please excuse the chicken scratch
    Hot Rods Ta Hell likes this.
  22. Here is a picture of the floor pan with the sub-rails installed. The body sits on the small flange at the bottom of the sub-rails. Apparently he is making the sub-rails with a 2 inch channel already built into them, 2 in channel rails are shown in this picture
    picture with body on sub-rails
    brEad, Besty34, rusty valley and 3 others like this.
  23. fordgezzer
    fordgezzer
    from texas
    Lots of great info on this build, thanks.
    Atwater Mike and pennafxu like this.
  24. pennafxu
    pennafxu
    from Kentucky
    What are the exact brand of these wheels please?
    dumprat likes this.
  25. Alphy
    Alphy
    Good Info!!!
  26. Alphy
    Alphy
    I purchased the same floor pan. Awesome workmanship.
  27. dumprat
    dumprat
    from b.c.
    I've been trying to figure out those wheels for a while. No luck
    pennafxu and loudbang like this.
  28. pennafxu
    pennafxu
    from Kentucky
    Driving me damn crazy!
  29. Shadow Creek
    Shadow Creek
  30. WiredSpider
    WiredSpider
    The wheels are one offs.
    I think they were made by Mike Curtis
