Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    Thought the '50s Olds oil canister collectors were pretty nifty too,
    Those were on the 671 blown '57 Olds in the '30 coupe I built here a few years ago
    Jet96, Tim, brEad and 9 others like this.
  2. Paul
    Paul
    Editor
    Thanks man, but I'm trying for a 1960ish show car look with this build,
    Those look a few years earlier to me,
    and I still have that car,
    can't have both cars in the garage with the same headers.. ya know? ;)
    brEad, Speedy Canuck, Stogy and 2 others like this.
  3. bchctybob
    bchctybob
    For the sixties show car look I think you’re on the right track with what you tacked together. They need to all be the same length, angle and evenly spaced and I would add nicely detailed 2 bolt or 3 bolt caps to the end of each one.
    You could drop them down, add a bend to parallel them with the ground or with the ch***is. Make them all the same overall length so the ends come out staggered. Keep them sorta close to each other though so they look cohesive and not gangly like Chan’s.
    Stogy, Paul and loudbang like this.
  4. goldmountain
    goldmountain
    Back in the sixties, the local muffler/ hot rod guru made headers with a collector that ran all the pipes in a row. Definitely a local thing, but definitely sixties.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  5. Paul
    Paul
    Editor
  6. goldmountain
    goldmountain
    Paul, Stogy and loudbang like this.
  7. Paul
    Paul
    Editor
    redid the front and back (cylinders 1 and 7) primaries
    center line radius' were 3", 4" and 5" front to back
    now all 4"
    added 12" to the straight leg on each for equal length,
    I like the Catallo Coupe headers but the super short rear as compared to the extra long front primaries make me think of unequal burn and tough tuning..
    welded them all up
    and dressed all the welds
    using all 4" centerline radius bends made me short a couple
    so I had to order more to do the other side..
    anyway, here's some pix,
    PXL_20210419_202654746.jpg PXL_20210420_002150644.jpg PXL_20210420_002210355.jpg PXL_20210420_002242861.jpg
  8. 64 DODGE 440
    64 DODGE 440
    from so cal
    Everything about that car looks right. Looking forward to seeing it in color.
    Stogy, loudbang and Paul like this.
  9. Paul
    Paul
    Editor
    Rolled the car outside to turn it around to make it easier to work on the p***enger side.
    OFT, cactus1, Tim_with_a_T and 13 others like this.
  10. I dunno Paul, nice work as always but to me they look like you took the easy way our.
    tomkelly88 and OFT like this.
  11. Paul
    Paul
    Editor
    I do always try to make it look easy,
    you know, so anybody will think they can do it too.
    jebbesen, Tim, brEad and 4 others like this.
  12. bchctybob
    bchctybob
    That's better. Can't wait to see how you finish it all up.
    When doing outside headers, every time I turn a car around to do the other side it takes me a little time to re-orient my head. I always level the car, make me a floor standing fixture, take lots of measurements and look from every angle before I commit to too much welding. Lol
    brEad, loudbang, Stogy and 3 others like this.
  13. Marty Strode
    Marty Strode
    Great job Paul, you got it right !
  14. Paul
    Paul
    Editor
    Just a couple self explanatory snapshots while I wait for parts.
    PXL_20210420_224714500.jpg PXL_20210420_224654023.jpg PXL_20210420_224519959.jpg
  15. rob-redm
    rob-redm
    Nice Paul ! Are you doing anything at the end of the exhaust pipes ? flared ?
    loudbang, Stogy and Paul like this.
  16. Moseywildfire
    Moseywildfire
    Really Looking Good
  17. Paul
    Paul
    Editor
    I do have something in mind there,
    we'll just have to wait and see ;)
  18. lake_harley
    lake_harley
    Paul....fantastic lesson learned from those photos! I've lucked out on exhaust work and a couple headers I've built in the past, but using what I'll call your radius fixture is genius! Maybe everyone else knows about doing that but me?:(
    Lynn
  19. Fair enough. You're certainly right that they look a few years earlier. I must have missed the intended era of the build for this one.
    What you've come up with looks great however! Always impressed with what you pull together, great stuff.
  20. Paul
    Paul
    Editor
    Yeah, it's kind of ambiguous but there are a few clues, the 1962 steering wheel for one.
    Looks like it'll be a week before more U bends get here..
    may have to work on something else in the meen time.
    Stogy, loudbang, AndersF and 2 others like this.
  21. Eddiesixem
    Eddiesixem
    very cool!
  22. rob-redm
    rob-redm
    ok I'm waiting LOL...:D
  23. Paul
    Paul
    Editor
    me too...
    chryslerfan55, Stogy and loudbang like this.
  24. Paul
    Paul
    Editor
    I had one half a U bend and a couple s**** curved pieces of the 4" cl tube left,
    enough to put together two of the p***enger side primaries
    so.. 'did that.
    then measured angles and location of driver side pipes,
    made a wood jig to mirror them
    got the two p***enger side pipes roughly where they belong..
    ..still should wait on the last pipe before final fit and weld..
    PXL_20210421_211309932.jpg PXL_20210421_211410382.jpg PXL_20210421_212309170.jpg PXL_20210421_212327057.jpg
    Atwater Mike, bchctybob, OFT and 19 others like this.
  25. Thats a cool Jig!
  26. 31Apickup
    31Apickup
    Nice, I build slot of temporary wood jigs to hold stuff too.
    OFT, Stogy, loudbang and 1 other person like this.
  27. Paul
    Paul
    Editor
    I had modified a bracket to mount the generator up top when this engine was to go in an A Coupe.
    I wanted to keep it in the engine compartment,
    now in the little T it was too much in your face.
    so, moved the headlights forward about an 1-1/4"
    used the generator bracket from the '27 as a pattern
    and relocated the mount holes in the new bracket to bolt the generator back 13/16" to align with the rear pulleys.
    All to give a little more clearance between headlight bucket and generator pulley.
    cut, grind, drill and bolt..
    and wrap with shiny.
    I made the generator wrap of aluminum for the '27 before I found a chromed generator.
    PXL_20210422_182906506.jpg PXL_20210422_184347423.jpg PXL_20210422_185346690.jpg PXL_20210422_195151671.jpg PXL_20210422_204529530.jpg PXL_20210422_205904378.jpg PXL_20210422_215629459.jpg
  28. Paul
    Paul
    Editor
    Tacked together primaries for cylinders 2 and 8
    Making both sides the same is like hanging paintings on a wall, it is all about what looks right to the eye not necessarily what is plumb and square.
    All tubes are the same length, set at close to the same angles and dimensions from body, frame, floor etc.
    But with the right side starting further back than the left minor adjustments can make them appear more balanced.
    PXL_20210423_204201634.jpg PXL_20210423_204209881.jpg PXL_20210423_210656636.jpg
    RustyBullet, bchctybob, OFT and 15 others like this.
  29. RICH B
    RICH B
    I'm kinda late to the party catching up on the header making; but the change to matching bend radius made all the eye-pleasing difference in the world.
  30. Stogy
    Stogy
    Looks great @Paul...that should keep the pavement clear on both sides of the Hotrod, do the doors open enough to get in?
    chryslerfan55, loudbang and Paul like this.
