Technical Stock battery location on '34 Roadster
Discussion in 'Traditional Hot Rods' started by bandoola, Apr 20, 2021.
  1. bandoola
    bandoola
    This may seem like a dumb question, but, where is the battery located on a stock '34 Ford Roadster?
    Thanks
  2. sloppy jalopies
    sloppy jalopies
    if your firewall is butchered and needs work or replacing check out '37-'39 truck firewalls... they look alot like the '33-'34s and give you about 4" more engine bay and have the battery box built in... DSCN1843.JPG
    rattlesnakehoey likes this.
  3. 31aford
    31aford
    from az
    under the floor on drivers side. there is a removable access door in the floor
  4. bandoola
    bandoola
    Thanks. Would it fit on the p***enger side as well?
  5. 31aford
    31aford
    from az
    you would have to cut a access hole in the floor board.
  6. 31aford
    31aford
    from az
    Here are 2 photos from my car . The one you can see the access door on the left floor board. The other picture is where I mounted the battery on the right side under the floor board. I made an access door in the floor to access the battery.
  7. bandoola
    bandoola
    That's perfect - thank you. That's exactly where we were thinking of mounting it. Out of the way, fairly easy access, and closer to the starter.
