Technical HEY PAINTERS!
Discussion in 'The Hokey Ass Message Board' started by Clik, Apr 21, 2021.
  1. Clik
    Clik
    I was thinking about what color to paint my panel truck and possibly my Henry J.
    2019 Jeeps had a color called Bikini Pearl.
    I was wondering if it is a solid color that requires no clear coat.
  2. Technically it’s a base/clear.
    you would have to ask the paint store if it can be mixed in single stage.
    If it’s metallic or a real tri-coat pearl, don’t expect it to look exactly the same in a single stage.
  3. K13
    K13
    It' a metallic and a pearl so probably a tri-coat so there is very little chance there is a single stage formula for it and unless you can spray it perfectly you don't want a single stage as there is no way to fix anything like runs or orange peel.
  4. rusty valley
    rusty valley
    Shoot a solid color, 3-4 coats ,single stage, so it can be wet sanded and buffed, then even a dope like me can look like a pro painter
    Frankie47, catdad49 and flynbrian48 like this.
  5. impala59
    impala59
    from vallejo,ca
    You might change your color choice after you check how much these bad *** new colors cost, Friend just spent $1,800 for a gallon and a half of color and $800 for clear 2020 Lexus paint color.
  6. rusty valley
    rusty valley
    I am painting my daily rite now. Factory color code showed only available (at my ppg dealer) in concept, the top of the line, 600 a gallon, and only base coat/clear coat. Instead I had them use they're fancy-pants computer camera and took a shot of the hood, pretty good paint yet, and then the computer made me a mix for same color in single stage urethane at 300 a gal, and no clear coat. Its a modern world. as stated above. if you are not a pro, and do not have a booth, stay away from the fancy paint
    catdad49 likes this.
  7. If it’s metallic color, you’re not going to cut and buff it like normal for a single stage
  8. flynbrian48
    flynbrian48
    Kirker Dark Garnet single stage, using their base coat converter, their clear. $85 for 3 quarts of color (I bought 6 and have half gallon left), even less for the clear, Arctic Blast pearl over white, $85 for 3 quarts of each with almost all of those left, I'll use it on my T'bird. Shot with a HF gun, add 3 days of color sanding and buffing. The Kirker colors are limited, and you can't have a factory color duplicated, but for around $500 for everything, including primers, I'm happy. And my pecs and arms are more defined...:p 26F1A176-EFE7-46FA-A275-9103DC423841.jpeg A8D95FAC-66C9-4018-9800-625DF3BBA40A.jpeg 65D88998-2314-434D-878C-E923B1058604.jpeg
  9. Pats55
    Pats55
    from NJ
    Looks real good. You did a really good job. There are still some paint companies out there that put out a decent product at a fair price .
  10. Testify brother :D just got started on a 65 chevelle convertible. The guy dropped the car and sent me a picture of the paint code he wanted to go with. I called the paint supply, then called the car owner, $2600 for the red base coat. He changed his mind on the color lol
    impala59 likes this.
  11. rotten ron
    rotten ron
    I know nothing about painting but neighbor has this color on is jeep. looks great it really pops.
  12. koolbeans
    koolbeans
    What is that color spec? In ppg?
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  13. Clik
    Clik
    Holy Cow!
  14. stuart in mn
    stuart in mn
    That Bikini Pearl is a pretty color, but I don't know how good it would look on a vintage car...it's kind of too 'modern' to my eye.
