Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. atch
    atch
    Here is one that a friend made from a needle nose vise grip and a bunch of original Model A parts (I don't know where they are on an "A" but he tells me that the weight is a bunch of Model A washers welded together):
    ...and here's a pic that I stole from the net; probably here:
  2. drdave
    drdave
    Looks like the bit off the A on your friend’s needle nose vise grip is one of the mechanical brake rods
  3. Can't get a good enough grip on the spark plug boot to pull it off? I did this today while changing plugs. I put a loop in a coat hanger tight enough to grip the boot, grabbed both ends with pliers and gave it a yank. I'd wasted 30 minutes and s****ed up both hands trying to get that damned plug wire off before I remembered the coat hanger trick. Two seconds later, the boot was off. Works on hemis, too. Learned it on a 341 DeSoto more than 50 years ago.
  4. blowby
    blowby
    from Nicasio Ca
    A friend recently gave me a set of gold clubs he picked up somewhere. I've discovered the covers are perfect for storing the pliers, cutters, strippers and scissors I carry in my truck tool box, instead of having them loose, snagging and pulling half the tools out with them.
    If anyone has a good use for the golf clubs and bag let me know.
  5. 61SuperMonza
    61SuperMonza
    My dad gave me this tip for a small water proof tool box. Use a small metal ammo box with the hinged flip top lid for your emergency tool kit.
    Totally durable and water proof. Have used it on the float plane and the boat for years. Sorry no pics
  6. Six Ball
    Six Ball
    from Nevada
    My father-in-law, a golf fanatic and never a fan of my cars, just rolled over in his grave.
    Jet96, rpm56, vtx1800 and 10 others like this.
  7. I used those in my jeep for years
  8. buckwild27
    buckwild27
    Lots of helpful and great information here I will be using some of these tips in the future
  9. fyrffytr1
    fyrffytr1
    I just thought of another use for the golf club covers. They are used to cover the heads of the "woods" and the 1 wood is called a driver. So put one on your floor shift handle when it's parked and take it off when you go to Drive!
    vtx1800, chryslerfan55 and loudbang like this.
  10. davidvillajr
    davidvillajr
    Heck, just get a WiFi extender and drag your laptop or phone out there. Instant T.V. :D
  11. Glen Trotter
    Glen Trotter
    chryslerfan55 and Boneyard51 like this.
  12. Glen Trotter
    Glen Trotter
    i will give that linseed oil trick a try boiled got it thanks
  13. Boneyard51
    Boneyard51
    Also great for wood, like ax and hammer handles!
    Bones
  14. Jacksmith
    Jacksmith
    from Aridzona
    I've got a small DVD player on the shelf next to a T.V. we replaced from the house... It plays CDs also, so I've got tunes with no annoying D.J.s or a movie. I like watching Mad Fabricators while I'm building.
  15. gimpyshotrods
    gimpyshotrods
    The shop is 3-miles from the house. I am not sure an extender exists that has that range.
    We have internet access there.
  16. davidvillajr
    davidvillajr
    Yeah, you'd probably need one heck of an extension cord. :D
  17. well if you have line of sight... there are ways :D
  18. Coggles
    Coggles
    Especially if you like Pringles and it’s 2006.
  19. ekimneirbo
    ekimneirbo
    Be very careful with linseed oil in your shop. Rags with linseed oil on them are known to spontaneously combust. Personally I don't keep any in my shop......then I can't forget.;)
  20. Yup, I toss my used linseed oil rags right into my woodstove, winter OR summer!
    loudbang and caseywheels like this.
  21. Mart
    Mart
    Ok we all know about putting a nut on a bolt when you want to shorten it. I did a little tech short video on the subject which you might find interesting and/or get a chuckle out of at my expense.
    Cheers! Mart.
    Six Ball, fauj and ken bogren like this.
  22. dover12
    dover12
    from maryland
    great tips thanks
  23. fourspd2quad
    fourspd2quad
    So I had my shoebox gas tank hot tanked and flushed out at a local shop. Afterwards I decided
    to make sure the pickup tube was clear. I took some mechanics wire and put a little kink in the end, put it in my
    drill and proceeded to run it through the tube. I slowly worked it back and forth from one end of the tube to the other. I was surprised at all the grit that I cleared out. Initially I started with a thicker wire and it would not feed through the tube. This is something to keep in mind when when running a nice new 3/8 line for high HP setups from your old tank.
  24. Doublepumper
    Doublepumper
    from OR-WA, USA
    Tired of scratching your wheels trying to remove the hub cap?
    I use this little goodie I made from a s**** piece of nylon. Works like a champ!
  25. Elcohaulic
    Elcohaulic
    I made one today and it works like a charm!! The baby moons on my cousins car are a royal pain in the *** too.. Thanks brother..
    Boneyard51 and loudbang like this.
  26. goldmountain
    goldmountain
    The brush in the cap on the anti-seize bottle doesn't reach the bottom and sides. At that point, I cut the bottle apart and stuff the remaining goo into the next bottle.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  27. ekimneirbo
    ekimneirbo
    I misuse and abuse my chop saw regularly. Often the clamping device is in the way of what ever I'm misusing it on. Notice the latest "nick" in the blade. Anyway I removed the clamp by unbolting it and then welding some nuts on the bottom. A little reconfiguretion of the hole so the slide comes out easier. That way its easy to take it off and reinstall it. Makes it easier to cut plate material and other non-conforming parts. Wear gloves and gl***es........
    Boneyard51, LAROKE, loudbang and 4 others like this.
  28. Dick Stevens
    Dick Stevens
    Surely you've already replaced the damaged blade before it explodes and causes someone great bodily injury!
  29. Fortunateson
    Fortunateson
    Yeah get rid of that potential rotating bomb!
  30. loudbang
    Got these in a tool set I won for being honor graduate in my Auto mechanics course at my trade school. They were insulated when I got them 54 years ago LOL.
    But time and use had the insulation falling apart and for sentimental reasons want to keep using them.
    So I just cut a couple lengths of simple shrink tube, used mostly on wiring, slipped them on and heated them up.
    It's fairly thin so if you use them around electricity you might want to double up.
    Note the black stain where the end of the original plastic used to be. :)
