Your opinion on the ford cruise-o-matic?
Discussion in 'The Hokey Ass Message Board' started by malaguena, Dec 19, 2011.
  1. jimmy six
    jimmy six
    I replaced the Ford-O-Matic in my 56 Victoria with a 62 medium case Cruise-O-Matic behind a 292. So far it's been the best change I've made in the car. I had to fab some on the column linkage and really like the vacuum modulator for shifting. The down shift arm was also pretty easy to adjust using a slot style fitting on original throttle pressure arm. Best thing is seeing the "green dot" on the indicator. image.jpeg
  2. willys36
    willys36
    I put a '63 Cruise-O MX (big case) in my Mysterion reproduction to match what Roth used. The guy I bought it from took it out of his Galaxie 'cause it quit shifting. I rebuilt it and it was pristine inside except the Bellville clutch spring was broken. I got a replacement on ebaY. Was easy to get a rebuild kit.
  3. Rocky
    Rocky
    Classified Editor
    I once had a 49 ford F-1 with a 289/cast iron cruiso and a 4.27 rear gear. Trans worked great! Busted the spindly dana rear end twice. 49fordpu.jpg
    lothiandon1940 likes this.
  4. Dennis Cator
    Dennis Cator
    from CANADA
    Simple question for you Mechanical Artists Im looking at buying this 1951 Monarch Canadian model of 1951 FORD 56000 Miles real Do you think the automatic transmission will be in decent shape.I know it depends on service and ownership care. But generally were theses early tranys Pretty tough?
  5. Elcohaulic
    Elcohaulic
    I remember the transmission in my 62 Galaxie used to make this pounding sound then sitting at a light.. I never knew what a automatic was really like until I went for a ride my our friends 70 Olds 442. 455/turbo 400.. Wow did that car go..
  6. 26Troadster
    26Troadster
    i guess i can tear up a steel ball with a rubber hammer. i have never had a borg warner automatic transmission hold up to me, ford or amc.
