Projects 33 3 Window Coupe
Discussion in 'Traditional Hot Rods' started by pennafxu, Mar 4, 2021.
  1. pennafxu
    pennafxu
    from Kentucky
    I really like the cartoonish rake on that car above and this rendition... I ***ume they pie cut the frame. Is it done fore of the cowl? If so does it effect front/rear pinion angles? What about cross members? Do you tack them in after? What about the front 5-7 deg caster that is to be welded in? Should I wait until wheels and body are on? What angles for each aforementioned detail?
    Outback, 1927graham and TigerFan like this.
  2. dumprat
    dumprat
    from b.c.
    It would be pie cut at the firewall.
    But as you are going to channel yours just build the frame flat and drop the front of the body down a bit.
  3. pennafxu
    pennafxu
    from Kentucky
    Would the body need to be shimmed on the rails? What is the purpose of the pie cut? and how about the opposed Angle look of frame and body?
  4. dumprat
    dumprat
    from b.c.
    You can mount it flat to the frame and pie cut the frame, OR leave the frame stock and mount the body at an angle.
    Make sense?
    Outback, 4ever18 and pennafxu like this.
  5. pennafxu
    pennafxu
    from Kentucky
    Yes sir I figured that, but why do they angle the front portion up? Purely for aesthetics? And would you need a rear shim to get that look?
  6. dumprat
    dumprat
    from b.c.
    Where would the shim go? I don't quite understand.
    pennafxu likes this.
  7. pennafxu
    pennafxu
    from Kentucky
    To elevate the rear body to achieve the angle, wouldn’t there need to be a shim or something on the back of the frame rails to raise the back end of the frame for the body to sit on?
  8. Dedsoto
    Dedsoto
    from Australia
    Don't lift the body, channel it, 6" in the front 4" in the back
  9. dumprat
    dumprat
    from b.c.
    ^what he said!
  10. Ruby32
    Ruby32
    Very cool
  11. pennafxu
    pennafxu
    from Kentucky
    Took the heads off...
    With some hot wrenching
    j hansen likes this.
  12. pennafxu
    pennafxu
    from Kentucky
    IMG_1656.JPG IMG_1658.JPG IMG_1659.JPG IMG_1660.JPG IMG_1661.JPG IMG_1664.JPG IMG_1665.JPG
    Not holding my breath here, but this looks less frozen.
    Outback, patmanta and brEad like this.
  13. pennafxu
    pennafxu
    from Kentucky
    The lifter gallery is a greasy sloppy mess [emoji849] IMG_1667.JPG IMG_1668.JPG
    This block had bolted on water pumps, whereas the previous block didn’t??
    Came out easy enough.
    Outback and brEad like this.
  14. pennafxu
    pennafxu
    from Kentucky
    Before...
    After
    I TIG welded the opening down some... a little ways to go. I was going to use a small piece of steel but wanted to practice my weld building skills. It’s all about heat control, patience and good shielding. I used a flat ground tungsten also for a wider arc. It’s very difficult not to get rod impurities on the tungsten which causes an unstable arc...
    brEad likes this.
  15. rusty valley
    rusty valley
    If your other block had no water pumps its a 36 and older. they had the pumps in the heads
  16. dumprat
    dumprat
    from b.c.
    That block doesn't lok too bad! I'd soak it in diesel for a month or so. Then see if it comes apart.
  17. pennafxu
    pennafxu
    from Kentucky
    It has the later heads? 49-53 They may have been removed by po
  18. pennafxu
    pennafxu
    from Kentucky
    Yaay! Would you remove the innards or wait post soak?
  19. What are those parts in the mol***es soak looking like? Been about 3 weeks now
  20. dumprat
    dumprat
    from b.c.
    I would soak the whole thing. It will make it much easier to get apart and. A lot of the crud should just float away.
  21. pennafxu
    pennafxu
    from Kentucky
    This weekend we will take a look!
  22. J'st Wandering
    J'st Wandering
    If it does not have water pumps in the block, they are in the front of the head. So, similar, sort of, to the 8BA heads, kind of. ;) The early blocks are 21 stud heads rather than the 24 of the later blocks.
  23. panhead_pete
    panhead_pete
    Make sure you get that block checked out before spending a cent on parts...
  24. johnsmith45a
    johnsmith45a
    Where can I get this?
  25. pennafxu
    pennafxu
    from Kentucky
    Get what?
  26. pennafxu
    pennafxu
    from Kentucky
    Out of the primordial goo... 4 weeks.
    This is very impressive.
  27. pennafxu
    pennafxu
    from Kentucky
    Block looks etched
  28. pennafxu
    pennafxu
    from Kentucky
    The bolts were able to turn hand loose... very weird
    I haven’t even tried to even clean the block yet.
    And now the bad news. The crank rocks about 1/8” up and down but is still frozen. I’m so annoyed. I’m thinking sawzall or milling machine.
    patmanta likes this.
  29. dumprat
    dumprat
    from b.c.
    Flip it over. Wash it off then put bleach on the pistons. Let it soak. It will eat the aluminum enough to knock them down to get the crank out and then pound the piston up.
  30. pennafxu
    pennafxu
    from Kentucky
    For how long, what type of bleach?
