Technical ANYONE STILL USE PUSH BUTTON START?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 26, 2021.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I have had a few cars, mostly '39 & '40 Fords with a key to turn on the switch and a ****on to start, I haven't had a car with one in a long time but I liked the simplicity and if I ever need to replace the ignition switch in my old beater it's something to consider.
    How about you guys? HRP
  2. pirate
    pirate
    from Alabama
    Ironically my three project cars all have key switch’s but my last two new daily drivers have push ****ons.
    hemihotrod66, clem, chopped and 2 others like this.
  3. jimmy six
    jimmy six
    My OT F-150 is push ****on start....so is my wife’s 2015 OT
    Beepx22 and HOTRODPRIMER like this.
  4. abe lugo
    abe lugo
    I was going to add it back to my Caddy, I found this schematic from Rebel wiring. I'm sure there is another version
  5. SlamIam
    SlamIam
    Still pushing the ****on in my 51 F1
  6. 51 mercules
    51 mercules
    On my 51 Merc I still use one!
    HOTRODPRIMER likes this.
  7. proartguy
    proartguy
    from Sparks, NV
    I like to use original ignition switches on my old rides, so they have starter ****ons as they originally had foot activated starters.
    Driver50x and HOTRODPRIMER like this.
  8. millersgarage
    millersgarage
    yup, my 47 and 33 both have them
  9. fordy7coupe
    fordy7coupe
    from Wylie, TX
    The starter position of the column mounted key ignition switch on my daughters OT vehicle wore out. She didn't have the $ to replace it, so I wired in a push ****on on the dash and told her, "There, now you got one of them 'modern' cars with a push-****on starter." She wasn't impressed.
  10. squirrel
    Not since I sold the T....or the Hudson before that....
    time for me to get another one, I think.
    Dino 64 and HOTRODPRIMER like this.
  11. ROADSTER1927
    ROADSTER1927
    My 40 Pontiac and 50 Chevrolet ramp truck currently!:)
  12. Special Ed
    Special Ed
    I like to think of the push-****on on my '53 Jet as a theft deterrent. I never remove the key from the ignition switch. If I'm out somewhere and someone decides that they'd like to take it, they'll turn the key and quickly discover it won't start. ;)
    Driver50x, clem and HOTRODPRIMER like this.
  13. Stooge
    Stooge
    My Buick will have a push****on with in lieu of the gas pedal starter switch, but im keeping the keyed column switch and use it as an interrupter since its also the column support and steering lock out.
    Hnstray and HOTRODPRIMER like this.
  14. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I did it for simplicity on my Model A, I like being able to roll a motor over without having to disconnect ignition etc.
    Stan Back and HOTRODPRIMER like this.
  15. Mr48chev
    I have lost track of how many Chevy AD truck guys I have tried to convince that they can put a push ****on in their truck for "start" rather than swapping ignition switches to something that never fit right and always come loose. It's amazing as to how many don't grasp the concept and don't understand that if you hide the push ****on just enough so that you can't see it but can easily reach it you have a pretty good theft deterrent plus if you leave the keys in the truck along with a small child they aren't going to be able to crank the starter if they play "drive the truck". It's not hard or expensive to replace the stomp pedal with a tractor foot start switch either.
    Years ago I lost my keys and ended up putting a push ****on and toggle switch under the dash to start and run my 48. I drove it that way for over a year.. My buddy had ridden in the truck a number of times before he figured out that I didn't have a key in the switch.
    Budget36, 51pontiac and HOTRODPRIMER like this.
  16. das858
    das858
    My '38 Plymouth pickup still uses the original push ****on to crank the engine , I like it !
  17. HOTRODPRIMER
    HOTRODPRIMER
    Thank you, this could be helpful to someone wanting to wire in a starter ****on. HRP
    32SEDAN and 3W JOHN like this.
  18. typo41
    typo41
    40 pickup - Yes
    50 Ute - Yes
    28 Ford Land Speed Roadster - Yes
    54 Wagon has a key start
    Chick's 28 key start, but I will change that this year
    I think of it as a theft deterrent, like a clutch
  19. cfmvw
    cfmvw
    I had an OT beater that the column ignition switch broke in, jamming the tumbler and preventing me from starting the car or removing the key. Happened to be in a Walmart parking lot, so I went in and bought some cheap tools, and took the steering column apart so I could pop the broken tumbler out, then stuck a long screwdriver in there so I could start the car. When I got home, I cut the steering column lock off, and added a toggle switch on the dash to power up the car and shut it off, just used the screwdriver to start it. While I was at it, I also took all the pins out of the door locks; it was very convenient to just use a screwdriver to unlock and start the car!
    MO54Frank, Budget36 and HOTRODPRIMER like this.
  20. My 50 ford and 2021 Tacoma both have push ****on start, what is old is new again.
    32SEDAN, chopped and HOTRODPRIMER like this.
  21. Dan Hay
    Dan Hay
    I retained the push ****on start with the original locking column and on/off switch in a 40 Ford Sedan. I used a relay as mentioned above. Putting in a key start would take away something neat that makes an old car cool. If I were doing it again, I'd do it the same.
  22. mickeyc
    mickeyc
    I like the push ****on on my 40 Ford. I tend to bang my knee into on
    occasion when entering or exiting the coupe. This of course produces an
    embarr***ing lurch at the most inopportune of moments. Its okay I gave up trying to look cool long ago!
  23. 2935ford
    2935ford
    Starting with my '35 slantback, all mine since are push ****on start.
  24. Taboo56Chevy
    Taboo56Chevy
    still got a starter ****on on my 33 pickup. 1538803_781802488500174_490833137_n.jpg
  25. GeezersP15
    GeezersP15
    from N.E. PA
    Yep...My 1948 Plymouth has push-****on start.
  26. flatford39
    flatford39
    Planning on using a key to liven it and then start with the PB on my 31 Roadster with an 8BA. Kinda like how Henry did it but not a floor ****on.
  27. 4ty
    4ty
    40 Ford coupe with the ****on.
    Paul in CT
  28. Push ****ons and stomp starters make me happy.
  29. Deuces
    Deuces
    My o/t 2019 Ford has one...
  30. My '40 Ford coupe and '32 Ford roadster have a ****on. The '35 Ford PU has a key switch that came with the wiring kit.
