Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    on the way home from work I stopped at the slackers to help him put the windshield in. he had the gl*** in the frame and had glued the top seal in. he also put the seal around the out side. IMG_1974.JPG
    dwollam, TFoch, OFT and 7 others like this.
  2. tb33anda3rd
    tb33anda3rd
    Tim, nunattax, dwollam and 9 others like this.
  3. tb33anda3rd
    tb33anda3rd
    Charlie had been busy all week. he got the doors all back together and the side gl*** working perfectly. IMG_1975.JPG
    nunattax, dwollam, TFoch and 9 others like this.
  4. tb33anda3rd
    tb33anda3rd
    IMG_1973.JPG IMG_1972.JPG he also got all the front lights working including the turn signals.
  5. tb33anda3rd
    tb33anda3rd
    nunattax, dwollam, TFoch and 6 others like this.
  6. tb33anda3rd
    tb33anda3rd
    and the correct tires were delivered to him this week...much better than the military jeep tire he got last week. IMG_1971.JPG
    dwollam, TFoch, Stogy and 7 others like this.
  7. tb33anda3rd
    tb33anda3rd
    dwollam, loudbang, TFoch and 2 others like this.
  8. tb33anda3rd
    tb33anda3rd
    I measured up for the latch and removed the lid again. I cut a slot and welded the latch on. next step is to make a hook to receive it. I also trimmed the middle cross member and made a new return. IMG_1983.JPG
  9. Stogy
    Stogy
    I love those lights on top of the fenders...are they turn signals?...if yes is Charlie just doubling up on security as you only need one set...
    chryslerfan55, loudbang and TFoch like this.
  10. tb33anda3rd
    tb33anda3rd
    the lights on the fenders are just running lights. the turns on the frame are vintage Harley.
  11. tb33anda3rd
    tb33anda3rd
    I swopped out Charlie's tires. I had to be careful not to hurt the old tubes, the slacker wants to use them to mock up the next build. super moon rising in the back ground...and zoomed in. IMG_1986.JPG IMG_1989.JPG
  12. TFoch
    TFoch
  13. The37Kid
    The37Kid
    Wonder if anyone had four transfers made to attach to their MOON disks?
  14. kidcampbell71
    kidcampbell71
    HA !!!
    Good stuff in those parts, enh' ?? ;)
    Stogy, chryslerfan55 and tb33anda3rd like this.
  15. tb33anda3rd
    tb33anda3rd
    made a little latch for the hasp. simple eye bolt, bent off set, double nutted with nylon washers against the box. IMG_2008.JPG IMG_2009.JPG IMG_2010.JPG IMG_2012.JPG
    dwollam, TFoch, Stogy and 10 others like this.
  16. tb33anda3rd
    tb33anda3rd
    rotate the eyelet up and the hasp will slide over it. rotate it down to hold it in and/or put a pad lock on for security.
    TFoch, Stogy, OFT and 5 others like this.
  17. The37Kid
    The37Kid
    Would a TIG on either side of the eye be overkill?
    Stogy, loudbang and chryslerfan55 like this.
  18. tb33anda3rd
    tb33anda3rd
    to connect the loop? good idea.
  19. patmanta
    patmanta
    from Woburn, MA
    You could also just Loc***e the threads if you want to be able to break it back apart easily but not casually.
  20. tb33anda3rd
    tb33anda3rd
    I took the new "box " and sub frame out and welded up the flange I had made for it to finish and strengthen the back edge of the middle crossmember. IMG_2023.JPG IMG_2024.JPG IMG_2025.JPG
  21. tb33anda3rd
    tb33anda3rd
    a "nod" to Charlie's service in the army. stationed in Germany in the motor pool. IMG_2026.JPG
  22. tb33anda3rd
    tb33anda3rd
    the other night I painted the pieces and then ***embled it last night. IMG_2027.JPG IMG_2030.JPG
  23. tb33anda3rd
    tb33anda3rd
    I brought it to work today and me and my buddy Daniel stopped at Charlie's. with the help of his neighbor Pete we put the bed in place and bolted it down. IMG_2032.JPG IMG_2033.JPG IMG_2034.JPG IMG_2035.JPG
  24. tb33anda3rd
    tb33anda3rd
    charlie was able to get the rest of the interior panels in, including making some garnish moulding and installing a dome light. IMG_2036.JPG
  25. tb33anda3rd
    tb33anda3rd
    since we had some muscle around we pushed it out of the garage to check the proportions. IMG_2039.JPG
  26. tb33anda3rd
    tb33anda3rd
  27. tb33anda3rd
    tb33anda3rd
  28. tb33anda3rd
    tb33anda3rd
  29. nunattax
    nunattax
    looking good .is there rear fenders and mirrors on the horizon?
    Stogy and loudbang like this.
  30. tb33anda3rd
    tb33anda3rd
    yep Charlie will fit the rear fenders now that the the bed is in place. not sure what his plan for mirrors is but I know he will put some on.
    Stogy, dwollam, chryslerfan55 and 4 others like this.
