Technical Speedway vega steering box
Discussion in 'The Hokey Ass Message Board' started by sdluck, Apr 21, 2021.
  1. Malcolm
    Malcolm
    from Nebraska
    Zero play, zero adjustment needed. It just feels much more precise and doesn't wander on the road like the old foreign box.
  2. figure8
    figure8
    Anyone try the Vega style power steering box Speedway and others sell?
  3. 1971BB427
    1971BB427
    from Oregon
    I'd send it back to Speedway, and get credit towards a Flaming River Vega box. Speedway wont likely refund your money, but they're good about crediting towards another purchase. The Flaming River Vega boxes are much higher quality.
    I didn't replace a cheap Vega box, but I do have the Flaming River Vega box in my '39 Chev coupe. It's a great box that I've had zero issues with. I simple fabbed a mount and bolted it on. Set the proper lash and nothing else.
  4. uncle buck
    uncle buck
    I wouldn’t put a Flaming River box in my lawnmower or buy anything else that they make. You are very lucky to have have zero issues with yours. Their lack of “customer service” and ******** “lifetime warranty” are the worst in the industry. They made me pay $150 to correct a Mustang steering box that they incorrectly manufactured with a input shaft 1.375” too long. To make matters worse, I shipped it back to them in a USPS $13.95 flat rate box. They returned it to me in the exact same box after correcting the shaft and charged me $30.00 to ship it back. THEY ****! Step up to a Borgeson box and support a company that makes a superior box and will stand behind it.
    2OLD2FAST and butch27 like this.
  5. 31Apickup
    31Apickup
    Replaced a stock Vega box on my A pickup about 6 years ago, was on it for about 28 years plus who knows how many miles were on it when I originally pulled it in the junkyard. It was getting sloppy. Replaced it with a Borgeson, just bolt it in and go, no nonsense and an excellent product. You get what you pay for on the cheaper boxes and I don’t cheap out on critical components.
  6. milwscruffy
    milwscruffy
    Sorry you had an issue with them with a "Mustang" box. What does that have to do with a "Vega" box or have you had issues with a Vega box from them also and if so, what issues?
    1971BB427 likes this.
  7. 1971BB427
    1971BB427
    from Oregon
    I guess somebody will have trouble with any manufacturer, as all of them can occasionally have an issue. But Flaming River gets very good reviews overall.
    bchctybob and milwscruffy like this.
  8. uncle buck
    uncle buck
    My point was the company ****s and doesn’t stand behind their products.
    rbrewer likes this.
  9. olscrounger
    olscrounger
    I only use Borgeson--had issues with others
    abe lugo, 31Apickup, rbrewer and 2 others like this.
  10. nochop
    nochop
    from norcal
    Yup, why risk it, they wrote the book
    Atwater Mike, rbrewer and olscrounger like this.
  11. bchctybob
    bchctybob
    I’ve used several Speedway Vega boxes and the first thing you need to know is that not all of them come properly adjusted. I’ve used or installed maybe a half dozen or more and after checking them out almost all needed to be adjusted. I haven’t had any excessive wear problems or failures. If you’re concerned I would go with a Borgeson, you sure don’t want to be driving around scared that you’re going to have a steering failure.
  12. lake_harley
    lake_harley
    I put a Borgeson Vega box in the Model A I'm working on. I don't have the car on the road yet but I had the same problem that the pitman arm didn't seat tightly because the washer and nut bottomed out before the arm was tight on the splines. I machined a thick washer with the center hole the same size as the shaft threads and cut a "relief" on the underside to clear the splined portion of the shaft which allowed the outer diameter of the washer/spacer to fully seat the pitman arm. Don't know how many Vega boxes might have that issue, but it's worth checking.
    Lynn
  13. X38
    X38
    Are these factory or aftermarket pitman arms you guys are talking about?
    Fordors likes this.
  14. krylon32
    krylon32
    from Nebraska
    Thanks Uncle Buck for saying what I was trying to project in my post above.
  15. milwscruffy
    milwscruffy
    Well for the record you didn't list a manufacturers name in your first response, which I would find helpful.
  16. krylon32
    krylon32
    from Nebraska
    While I won't use another Flaming River box on a customer ch***is at the time I was a dealer for them the boxes were marked Mfg in Argentina. I think they are now being ***embled in the USA, where they get their parts I have no idea, From my own experience, in new boxes there is no comparison to a Borgeson box.
  17. sdluck
    sdluck
    I replaced the ****on head allens they were real soft,and installed some new bolts and lock washers and torqued to specs and marked them.I will road test and report.
    milwscruffy likes this.
  18. 1971BB427
    1971BB427
    from Oregon
    No matter whose steering box I use, I always check adjustment and fluid levels before using them. Even the best can need adjustment, and any make can miss occasionally on fluid. Just part of the pre start up inspection list for me.
  19. sdluck
    sdluck
    I checked the adj a few times ,Never checked the bolts for the cover.
  20. Flathead Dave
    Flathead Dave
    from So. Cal.
    From the Speedway Vega Box ad
    Info
    From the Speedway site.
    Note: Vega steering box is not adjusted at the factory and therefore, it is necessary that the steering box be adjusted upon installation per the instructions as provided on the PDF instruction sheet.
  21. sdluck
    sdluck
    I saw all this information no where did I see I was supposed to retorque the bolts holding the steering box together
    Sent from my SM-J737T using The H.A.M.B. mobile app
  22. sdluck
    sdluck
    Also when I called Speedway to talk to them about this they said in 23 years they never heard of this happening
  23. X38
    X38
    That surprises you?
    Whenever anyone calls a company about something not working, not fit for purpose, falls apart etc. it's always "the first time..." :rolleyes:
  24. Rocky
    Rocky
    Classified Editor
    To be fair I bought my Speedway vega box from their Garage sale option. It was not returnable. I shoulda known better but I bought it. Something in it was not machined correctly so as soon as the lash was taken out, the steering gear was super hard to turn. I lubed it up and installed it in my 34 anyway, thinking it may just need to be "worn in" .
    It got worse and I pulled it apart a 2nd time...aside from the white plastic ball holders in the balll bearings it appeard ok but it was a piece of ****! I tossed it in my s**** pile, installed my gennie vega box after a good dis***embly and lubing but the bearing race is beginning to gall........gotta adjust it every 400-500 miles or so. I'm buying a Borgeson.
  25. Budget36
    Budget36
    Is the Vega box a cross steer set up? And does it have side mounts to the frame, like for a 35-40 Ford?
  26. X38
    X38
    Yes, it is a cross steer box and mounts to the frame sides.
    Budget36 likes this.
  27. Budget36
    Budget36
    Thanks! I have trouble looking at vendors pics and figuring it out.
  28. birdman1
    birdman1
    If you pansy ***es would do like I do, go to the junkyard and get a factory made box, rebuild it myself, and make it work.everything has to be store bought and easy bolton for you
  29. perry parsons
    perry parsons
    I was wondering if you could help me . I have just received speedway Box, paperwork says it may need adjusting ? right out of package ? or every 200 miles? what exactly happened to yours?
  30. 31Apickup
    31Apickup
    For a 35-40 Ford, use a Saginaw 525 box instead of a Vega, bit beefier. They came on everything from Malibu’s up to later S-10’s.
    As for original Vega boxes from a junkyard, good luck finding those anymore.
    Another option is to use 37-48 Ford cross steer boxes, you could always cut the shaft and grind/ machine for a double D universal if you don’t have room for the solid shaft.
