Technical Odd ball independent rear end thingy
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Apr 28, 2021.
  1. This gem pooped up on marketplace.
    Sellers says Dana with 5:38 gears.
    What say you HAMB experts?
    464BDBFF-A144-4F31-A3C3-03A0ECAD44E3.jpeg EC7B3D7C-5DBC-40FE-8275-5AD8CEF8929D.jpeg
  2. 1-SHOT
    1-SHOT
    from Denton
    It’s definitely a top loader
    Bandit Billy, Deuces and VANDENPLAS like this.
  3. chriseakin
    chriseakin
    I'd say if you have the cash, buy it and if you can't fix it, hang it on the wall.
    anthony myrick likes this.
  4. I know. It’s a few hours up the road.
    Dang it
  5. Rickybop
    Rickybop
    You better reinforce the wall.
  6. Has some early looking backing plates for those drums.
  7. oldiron 440
    oldiron 440
    My guess it's millatairy
  8. Kinda seems like it with those gears.
  9. I know there are some cushman and Taylor-Dunn warehouse carts that came with ford 9” diffs and other strange setups.
    It doesn’t look homemade or bodged together. FA47C772-0D04-4DEE-B331-EFBCEC659345.jpeg
  10. Budget36
    Budget36
    Odd something that short would be non-symmetrical.
  11. miker98038
    miker98038
    Am I seeing this right? Inboard drum brakes for a swing axle rear suspension? Or maybe independent depending on the outboard mounts? Looks hell for stout though.
    Deuces, gnichols and anthony myrick like this.
  12. oldiron 440
    oldiron 440
    The width is crazy, the axels would be very short in a automotive application.
  13. gnichols
    gnichols
    from Tampa, FL
    Any way this could be part of an early Jag IRS? Just guessing....
    Deuces and stillrunners like this.
  14. mgtstumpy
    mgtstumpy
    Doesn't appears to be a Jag IRS, looks like a scaled down version of a 12" Strange centre section however they're not IRS. Rockwell produced top loading solid rear axles for trucks. It'd be interesting to see whether it has fine or co**** splined axles, are there any casting numbers of other identifiers? 5.38:1 could suggest an industrial application.
    Deuces likes this.
  15. greybeard360
    greybeard360
    Ring gear looks pretty chewed up.
  16. stillrunners
    stillrunners
    from dallas
    Yep....maybe a Dana 44....not too exciting.....
  17. 56sedandelivery
    56sedandelivery
    I used to have a 1948 Gibson Garden Tractor, Model D. Had a big one lugger engine, a pre-1937 top shift Chevrolet 3 speed transmission, and an 8-3/4" MOPAR rear end. The "Positraction" (Sure Grip), is basically the same as the 55-64 style Dana Arma-Steel, Chevrolet Positractions. That's what I think the "guts" of that rear end are. No idea about the half-shafts. I am Butch/56sedandelivery.
    Deuces and anthony myrick like this.
  18. Rocky
    Rocky
    Classified Editor
    Yeah, it appears to be a dana 44. Jaguar used dana 44 center sections with inboard brakes but I've only seen disc brakes. Maybe it's an early version of the Jag. I see it used a torque tube driveshaft setup too.
  19. banjeaux bob
    banjeaux bob
    from alaska
    I think the JAG is a ****er 44 derivative called a Salisbury in England. It also has a rear cover....not top load.
    mgtstumpy likes this.
  20. Fordors
    Fordors
    A ‘48 Gibson tractor had an 8 3/4 MOPAR rear end? Seems like the 8 3/4 was introduced in the late ‘50’s, wasn’t it?
  21. xlr8
    xlr8
    from Idaho
    Dodge WWII weapon carriers and later M37's used a 5:38 ratio, ring and pinion could be out of one of those.
  22. Fordors
    Fordors
    The cover for the rear in the OP’s photos has bolt holes in a symmetrical pattern, unlike any Dana axle I’m familiar with.
  23. 56sedandelivery
    56sedandelivery
    I was "told" it was a 1948 when I bought it to use as yard art. They also did't all use the same rear ends. I do know mine had an 8-3/4" MOPAR, no doubt about that. I am Butch/56sedandelivery.
  24. Mr48chev
    Currie got their start with 9 inch rears cutting them down for Taylor Dunn carts and other industrial carts.
    VANDENPLAS likes this.
  25. Mr48chev
  26. Budget36
    Budget36
  27. ronzmtrwrx
    ronzmtrwrx
    Wow. I’ve never heard of those. Very interesting.
  28. 34Phil
    34Phil
    Can anyone explain to what that quarter elliptic mounts?
  29. mgtstumpy
    mgtstumpy
