Wife says I created a monster. Willys Jeep build
Discussion in 'The Antiquated' started by anthony myrick, Apr 22, 2021.
    block doesn’t seem to have water but the intake did. :(
    Deuces and VANDENPLAS like this.
  2. The Stude trans and the jeep trans share the same bolt pattern and hub register.
    The bells won’t swap between the 2.
    The Stude bell will fit the jeep trans. The Stude bell is around 1/2 inch shallower.
    The drivers side starter mount hits the firewall.
    These aren’t hard obstacles
    Currently tearing down the flat 4 to see what’s bad.
  3. BamaMav
    BamaMav
    from Berry, AL
    You know a Buick V6 fits like a glove in these don’t you? I had two with one in them, but they were CJ5’s. Not sure your trans will handle the torque of a six though. I had a CJ2 like that one and the trans was quite a bit smaller than the ones behind the V6’s. Got rid of all my Jeep stuff several years ago.
    Deuces, 31Apickup and anthony myrick like this.
  4. Kid wants a flat motor. Currently tearing down the 134.
    Might need to locate a better core.
    The t90 should be ok as long as he keeps the 700-750 tires on it.
  5. The shackles are interesting, last weekend was WWII weekend here in the St.Louis Metro area. My Wife and I took our son and his friend. WWII weekend is a live reenactment with Americans, Germans, British, French, and Italians. Most of the vehicles there were American, my son got his first ride in a 1943 Willys Jeep. Your picture of the shackles reminded me that they may not look very substantial, but they took lots of abuse.
  6. I have a soft spot for old Jeeps and Willys. I'll be following along.
    Deuces and anthony myrick like this.
  7. the oil soup
    the oil soup
    from Tucson,AZ
    Dodge used those shackles on their trucks for years, I think the Dodge ones were 4” between centers and the Jeep were 2 3/4”. Right and left hand threads also depending on mounting location.
  8. Rats nest is bad news.Nasty.
    Deuces likes this.
  9. The flat 4 is stuck.
    Going to let it soak while I figure out if the Stude 6 will work.
    Clutch is on the correct side but would have to fab new linkage. Modify the firewall for starter bump clearance. The biggest is the large round steering crossmember in front. Ours is cracked and needs replaced. So building one to move the radiator forward probably won’t be much more effort than fabricating s new one.
    I have located another block and found a forklift with a running continental flat 4.
    Okie Pete, Deuces, VANDENPLAS and 3 others like this.
  10. Whatcha soaking it with? I had an Olds block a few years back that was locked up tighter than hell. Soaked the cylinders for days with Diesel/ATF, put some heat on the pistons, pounded with a hammer and a 2x4... nothing. Filled each cylinder with Coca Cola and let sit. Next day I gave one cylinder a tap with a hammer and a 2x4 and the whole ***embly turned.
    cactus1, deathrowdave, Deuces and 4 others like this.
  11. rustydusty
    rustydusty
    "Things go better with Coke"!
  12. Kid got the body removed.
    He’s been watching trans and transfer case overhaul videos.
  13. 82CBC098-B82F-4CC1-9507-1F643BD39672.jpeg BBB3F328-B2D6-44CA-B6AE-CF7716890885.jpeg 01F5BD3B-9FCE-4DE9-A58F-94A004C66FFD.jpeg
    Got our other body.
  14. ADAA7382-58E0-46B6-909E-9855AA03AE03.jpeg 58D4B763-1A2B-48EE-A30D-CE3037509EF0.jpeg B036C94B-BEAF-46DE-9DC8-5E853C0B0819.jpeg B1B74BBF-95E9-4D00-8185-2FB246600F09.jpeg ADAA7382-58E0-46B6-909E-9855AA03AE03.jpeg Well we ended up with another ch***is and tub.
    May not look better in the pics but it a huge head start over the other.
    Well still use some parts from the first one including the trans and t-case.
    B1B74BBF-95E9-4D00-8185-2FB246600F09.jpeg 58D4B763-1A2B-48EE-A30D-CE3037509EF0.jpeg B036C94B-BEAF-46DE-9DC8-5E853C0B0819.jpeg
  15. Road trip again
  16. Guy Patterson
    Guy Patterson
    Does it turn over is the big question
    Deuces likes this.
  17. Yep.
    And complete.
    Appears to be a standard bore
    Deuces likes this.
  18. The engine looks great.
    All standard.
    cactus1, Okie Pete, BradinNC and 5 others like this.
  19. Guy Patterson
    Guy Patterson
    That is a nice looking block good luck an have fun on the rebuild
    Baumi, Deuces and anthony myrick like this.
  20. The kid is excited.
    His jeep 4 banger was shot when he bought it. Even the starter had rust holes in it.
    I offered up several other options. He sad no.
    It has to be a flathead. After a few months of searching for a complete 134 that would turn, he bought it.
    Had a fun day tearing it down.
  21. OahuEli
    OahuEli
    from Hawaii
    How is the project coming along?
    Deuces likes this.
  22. Slow. He started college.
    He’s been working on it when he can.
    Okie Pete, Deuces and OahuEli like this.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Here's pic of my son working on his '48 Anglia. I bought it for him when he was 13.
    He is now 47. This car project has helped cement our relationship over the last three decades.
    Father / son projects are the best, and not just because there is a finished car at the end. Its the journey together...
  24. Santa dropped off some jeep parts
  25. Deuces
    Deuces
    anthony myrick likes this.
  26. deathrowdave
    deathrowdave
    from NKy
    I had the job to rebuild an Ajax gas compressor many years ago . It sat in a pipeline RW for years . I tried everything to get it to free up , nothing . A pipeliner from the stare of Louisiana was there and ask me “ do you know what will free it up over night ? “ Naturally my answer was dynamite ! He chuckled and says the “ **** *** way is pour her full to the top with coke , let her sit a day and she will be free ! “ I’m like WTH , so I bought 12 bottles , that’s how long ago it was . Poured it full and sure enough free spinning in a day ! The ole boy told me I’d make a fine “ **** *** “ go home and work with us !
  27. Axles took apart. Except the carrier. The carrier looks good. Plan on a thorough cleaning and reseal.
    Hub bearings look great. Cleaned and ready to repack.
    Got the rear flange off, working on pulling the rear axles.
    Ordered new front king pin bearings.
    Deuces, Okie Pete and TFoch like this.
  28. Yokes pulled and currently cleaning the bearings while in the carrier. Every thing looks and feels good. We’re gonna leave em but clean up the mess
    The rear had a tad bit of water.
    The front was just old gear oil
    Deuces, OahuEli and Okie Pete like this.
  29. Hey Anthony, great project that will be loads of fun for you and your son when you're finished (plus the 'fun' while doing it).
    Check over on the Garage Journal, under 'garage builds' (I think). @Zeph's Quasi Garage (?). He's rebuilt a bunch of WW II Army rigs, Jeeps included, and has posted a ton of details on them. Good luck!
    anthony myrick and Deuces like this.
  30. Truckedup
    Truckedup
    My 47 CJ2A after a lot of work.... 9550859334_c0b52bfd5b_c.jpg 12309389684_edb24534e7_c.jpg
    cactus1, alanp561, tractorguy and 5 others like this.
