Projects Building My 34 B'Ville Coupe With a Potvin
Discussion in 'The Hokey Ass Message Board' started by N49racer, Aug 11, 2020.
Tags:
  1. N49racer
    N49racer
    Sure would like to find a Hilbourn 2 port for a 6/71 that would top it off. So here is the next project. Because i want to run EFI (yes Not period correct) I want to hide the injectors under the runners. There is no room so I took a Hot Heads dual carb manifold and gently removed the runner sections from the plenum. This manifold has the runners standing more vertical thereby allowing more room under the plenum. When I'm done adding the tubing to the tops of the runners I'll add a top and bottom and ends to make it look like the Potvin unit pictured. IMG_2020.JPG IMG_2021.JPG IMG_2022.JPG IMG_2024.JPG IMG_2025.JPG
  2. N49racer
    N49racer
    Now it’s starting to take shape. I had a good friend Dan Fantini fish mouth the runners.
  3. Deuces
    Deuces
    That is neat..... :)
    Stogy and loudbang like this.
  4. Brand Apart
    Brand Apart
    from Roswell GA
    Looking forward to seeing the new top in it's finished glory!
    Outback, Stogy and Deuces like this.
  5. That look great! One of the coolest pieces of Tech on the board right now.
    Outback, Stogy, panhead_pete and 2 others like this.
  6. N49racer
    N49racer
    Thanks TMAN
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Do you know how your friend Dan Fantini fish mouthed the runners? Maybe horizontal mill with over arm support?
    Beautiful Work!
    Stogy, Deuces and loudbang like this.
  8. j hansen
    j hansen
  9. N49racer
    N49racer
    Sure He used a boring head on his vertical mill with the head rotated about 40 degrees. The problem he ran into was when you lean the tool over it cuts an ellipse so he had to reset the bore diameter as he went deeper
  10. N49racer
    N49racer
    So a little back ***wards but this might as will be a build thread. After starting on the engine (previous posts), I now have a little time to start on the ch***is build. First off. Thank You guys for any and all feedback i have and will receive during this build. It's not going to be fast (the build) but hopefully i can stay at it steady.
    As I couldn't borrow a ch***is table i had to build a cheap unit that will work for this build then give/sell/ or cut it up.
    Deuces, Stogy, TigerFan and 1 other person like this.
  11. N49racer
    N49racer
    I just noticed you build side plate adapters for the 301 quick change. Do you still make them? I have a 11 bolt 301 halibrand I'd like to use.
    Stogy likes this.
  12. Check his threads, he has a whole thread on them!
  13. N49racer
    N49racer
    Yes, I saw that but they were posts from 2016. I want to know if he still makes them.
    Stogy likes this.
  14. TigerFan
    TigerFan
    from Athens, GA
    Im glad to see you’re going to make this a build thread. The level of thought going into your decisions is inspirational. Keep it up, and thanks for sharing.
    Stogy likes this.
  15. N49racer
    N49racer
    Thank
    Stogy likes this.
  16. N49racer
    N49racer
    Stogy likes this.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I sure do. Start a conversation and I can help you out.
  18. N49racer
    N49racer
    Sorry for Jumping around. I got the frame down off the wall and started the dis-***embly. How many rivets in a 34 frame? A FREAKIN MILLION OF EM. well not quite but i hate taking old frames apart. Next will be the repairs and then the mods. After 2 days of swinging body hammers (a 3 LB. and a 2 LB.) i have the rails in pretty good shape along with the inner frame/xmember. I started to repair by cutting out the rust at the rear kickup then realized I didn't have any material so onto other stuff. QUESTION. Is there a preference for large images or the thumbnails??
    . DSC05619.JPG DSC05619.JPG DSC05604.JPG DSC05613.JPG DSC05614.JPG DSC05615.JPG
    Outback, Deuces, lurker mick and 3 others like this.
  19. larger images please
  20. N49racer
    N49racer
    So one of the mods I want to do is stretch the frame 3 inches to try and make a little more room for the Potvin. I decided to cut the frame just ahead of the steering box mount. To kill 2 birds at once I'm using replacement frame horns. I had to m***age the new horns as the rails and the horns were different depths where i wanted to join them. Besides the vertical cut i also had to make a horizontal cut in the new horn to make them match up. then it's a case of clamping them all up and carefully welding them up. Onto the other rail except it has a problem. In the last pic you can see that the un modified rail is about an inch low in the crossmember area. Luckily the rail just needs to be corrected back where it starts to kick up and will only needs to be corrected in one spot. Once the rails are patched straightened and ready to go back together I'll put the body on and make some decisions on further mods.
    Deuces, loudbang, j hansen and 3 others like this.
  21. N49racer
    N49racer
    Okey Dokey TMAN
    Ted
    Outback, loudbang, j hansen and 2 others like this.
  22. PotvinV8
    PotvinV8
    I like your thinking on the intake manifold re: hiding the EFI injectors. I hid mine under the SBC Potvin intake and had to put everything in the valley of the block. Finger's crossed they never leak! Are you planning on running fuel through the blower? Have you figured out your wheelbase yet? What are you going to do for radiator, alternator, and water pump or did I miss those details?
    Great build by the way!
  23. j hansen
    j hansen
    Large please:)
    loudbang and Stogy like this.
  24. Stogy
    Stogy
    I'd love to see a inspired image of the desired look of this street monster...
    loudbang and brady1929 like this.
  25. N49racer
    N49racer
    I don’t think I’d worry too much about an injector leak. There are production cars with the injectors under the intake. The plan for the wheelbase is 115 but may change once I get it together enough to fit up a nose piece. I’m really fussy about how the proportions look. I don’t want it looking like Pinocchio.
    The rad will need to be in the trunk with 2 electric pumps. One pushing water each way.
    For the charging my first plan is to mount it above the blower with a pulley running off the end of the blower. The pulley part is already built and I’ll take a pic of it but it may not make it to the final product. It adds 3.5 inches to the length and I don’t know if it will fit. The alternator will need pretty good output as there are more than a few motors to run.
    As for putting fuel through the blower, they were never designed for that. They were designed to only move air. Yes there are many special instances where people have put fuel through them and it works fine but that is because of the special usage.
    Here’s something I,ve thought about, the blower was never designed to be mounted by the end plate. What affect will it have on the operation? Will the case flex, will the rotors clash.
    Ted
  26. N49racer
    N49racer
  27. PotvinV8
    PotvinV8
    My concern is with an O-ring leak at the fuel rail, under the intake. But that's OT.
    Funny, your wheelbase is exactly the same as mine, 115-inches. Body is '29 roadster. Radiator will be in the rear as well, though I didn't think about having a pump on both ends. Thought about driving the alternator off the blower, but had the same concerns as you. Ended up driving it off the driveshaft, mounted on the quickchange. Plans are to use a deep cycle AGM and a capacitor bank to help with the load.
    I wasn't planning on running fuel through the blower, but a few folks with more experience than I recommended it due to the heat that will be generated by the rotors. Food for thought.
    I thought the same regarding the blower being mounted by the end plate but have never heard of any failures due to the design. I know of a handful of Potvin setups being used at Bonneville/El Mirage and there's one in a T-bucket that's been on the road for years. I still put a 2x4 under the blower when the engine is on the stand! LOL
  28. N49racer
    N49racer
    I thought about running the alt off the driveshaft but I want the no/low speed charging. I had a car with that setup years ago and in traffic the battery voltage kept dropping off. Now that was 30 years ago and the tech has changed.
  29. Pete1
    Pete1
    from Wa.
    Somebody made at least one change gear setup for that blower drive because I saw it at Bonneville many moons ago.
    loudbang and Tman like this.
  30. PotvinV8
    PotvinV8
    Yup, there have been a few. Chico @ Mooneyes is running one in his Modified Roadster.
