Technical MY NEW TIRES ARE UGLY
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 5, 2021.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I was working on my old beater tonight and while I was taking a break I was staring at my tires and I hate the way they look, they are black walls but they have bold lettering and some other markings.
    Anyone ever sanded or shaved their sidewall's? HRP
    DeLuxe 32, scotty t and loudbang like this.
  2. Rocky
    Rocky
    Classified Editor
    There have been several threads on it, Danny. Do it so I'll know the tricks because I also have ugly tires.
  3. Deuces
    Deuces
    That will screw up the warranty on the tires...;)
  4. Yep. DA sanded all the **** off the sides. Wiped with some thinner. Looked great
    DeLuxe 32, VANDENPLAS and loudbang like this.
  5. Squablow
    Squablow
    I too have sanded all the lettering off of the sides of some tires with a DA sander, generally started with 80 grit in spin mode to get the high spots off, then switch to dual-action and buff smooth. You don't have to sand it super fine to get a good smooth sidewall. Helps to practice on an old ****ty tire first.
    Not as good as real period-correct tires, but it definitely helps the look.
    DeLuxe 32, irishsteve and loudbang like this.
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
    Ugly tires don't bother me as long as they have a good personality...
    verno30, mgtstumpy, 5window and 25 others like this.
  7. How do you keep a paper bag on them?
  8. sawbuck
    sawbuck
    from 06492 ct
    all radials are fugly !
  9. blowby
    blowby
    from Nicasio Ca
    Yes I have. Angle grinder with 80 grit then DA.
    Are those the Goodyear tires you are running? You would have to sand all the lines off too, all the way around. Not worth it. Looks like a modern alloy wheel. If not, let's the actual tires. Looks better than a Hankook tire or something like that.
  10. Petejoe
    Petejoe
    from Zoar, Ohio
  11. slowmotion
    slowmotion
    It's what's on the inside that counts (air)...(heard many years ago on a blind-date fix-up).o_O
  12. twenty8
    twenty8
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    As the boss once said “ all traditional cars deserve bias ply tires “
  14. HOTRODPRIMER
    HOTRODPRIMER
    That's not my actual tire, I snagged the off the internet to use as a example. HRP
  15. Matt55folife
    Matt55folife
    Let a woman drive it thru the drivethru somewere! Shell rub all the letters off on the curb then u aint gotta worry about em no more!!!!
  16. 4tford
    4tford
    put these over the lettering.
  17. lake_harley
    lake_harley
    Tires all get better looking at closing time.
    Lynn
  18. silent rick
    silent rick
    towel city shaves their tires. a little aftershave and they look spiffy if that's the way you roll.
  19. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Couldn't agree more. Lots of labor polishing those out and they'll still look like modern day Good Years. You won't fool anyone including yourself.
    Sell them and at least compromise with some Excelsior radials.
    You and the car only live once...
  20. dirt car
    dirt car
    from nebraska
    I know your wanting to retain the tires you have, but worthy of mention is the Cooper Trend setter & BFG's as they offer about the cleanest sidewalls over the counter, the question remains if your size is available.
    guthriesmith likes this.
  21. alchemy
    alchemy
    So, HRP, this is tech week. You have your ***ignment. Show us your homework.
  22. Dan Hay
    Dan Hay
    Or, you can rub every curb and grind them off, like my neighbor, who had raised white letters, but now has what I call "curb walls".
    vtx1800 likes this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    My bad, I had to buy tires at the last minute before the All Deuce Run a few years ago, They are a off brand and the shop I was at didn't have a bias ply in stock.
    I'm not ready to toss these tires, I will wear them out before replacing. HRP
    5window, Deuces and rockable like this.
  24. rusty rocket
    rusty rocket
    Hrp, your sedan is kick *** the way it is! I understand the smooth sidewall thing and the folks that tell you to run bias plys to make it a real hot rod are full of ****!
  25. Rickybop
    Rickybop
    1182.jpg They look fine when they're spinning. Nice and smooth. As in your avatar. All the more reason to keep on cruising.
    Deuces and AVater like this.
  26. Mr48chev
    A few years ago when the Sears tire department had about a dozen brands of tires I looked at all of them looking for an uncluttered sidewall and they didn't exist.
    Deuces likes this.
  27. kasselyn29
    kasselyn29
    Send Quain Scott a pm
    Deuces likes this.
  28. blowby
    blowby
    from Nicasio Ca
    Yep, if they are a few years old, not new as the ***le says, just wear 'em out. It's a time consuming, filthy job sanding them.
    Deuces likes this.
  29. AVater
    AVater
    Hey, I didn’t know you lived next door! Have that on my OT pickup
    Deuces likes this.
