History Anyone recognize this 60’s, Orange, Channeled ‘34 5 Window from New England?
Discussion in 'Traditional Hot Rods' started by Shaun1162, May 5, 2021.
  1. Shaun1162
    Shaun1162
    I haven’t checked the block numbers yet... The heads come back as ‘60 389. [​IMG]
  2. Those look like Pontiac header flanges. The center ports on a Pontiac are much closer then on a S.B.C.
    Pontiac-
    Small block Chevy-
  3. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    That rear looks familiar to me but I can't place it. Your best shot would be to shoot a PM to either Church Key or Safariknut here on the hamb.
    Good luck
  4. steven e ryder
    steven e ryder
    Saw the add. Glad to see it moving forward. It does look familiar from back in the late sixties early seventies. Crystal Lake? Hope to see you on the road soon!
    AHotRod and chryslerfan55 like this.
  5. guthriesmith
    guthriesmith
    That is WAY cool! Congrats and hope you can find some history. Love the Pontiac motor in it!
    AHotRod and Elcohaulic like this.
  6. Stogy
    Stogy
  7. woodiewagon46
    woodiewagon46
    from New York
    You might try to contact the "Tyrods", a car club based in the New England area since the 50's. They have a lot of older members that are still actively involved. You might get lucky.
    deadbeat, AHotRod, HRBOB34 and 3 others like this.
  8. Stogy
    Stogy
    deadbeat, WC145, BradinNC and 8 others like this.
  9. Shaun1162
    Shaun1162
    Wow nice find Stogy! That does look similar for sure... I’ll have to check the frame when I get home to see if there’s any traces of white paint!
  10. Stogy
    Stogy
    There is a chance it's a 33...that web on the aft door window vertical is hard to discern...staring at it more the channel is lesser...doesn't mean it wasn't altered...maybe @tombstone can do a better scan...or better yet may know who owned it...
    It was said to be 61/62...
    chryslerfan55 and dana barlow like this.
  11. tombstone
    tombstone
    from sk.canada
    Checked my OLD notes on that car. It came from Saskatoon Saskatchewan, owned at the time by a Gill Verall , member of the Draggins car club . That’s all I’ve got , don’t know what happened to it or this fellow......
  12. swade41
    swade41
    from Buffalo,NY
    That thing is pretty freaking cool
    dana barlow and Stogy like this.
  13. BrandonB
    BrandonB
    from nor cal
    I picked up a set of headlight like those a few years ago. They had that pronounced "A" in the gl***. As I recall they were a European setup.
    chryslerfan55, dana barlow and Stogy like this.
  14. Stogy
    Stogy
    I guess the wrecking yards and the swap meets of the Yesteryear had a mix of Automobile as there certainly was global trade and immigration going on fueling the parts diversity...you see it in mixed in the Vintage images of the Dry Lakes and Racing and even the daily life pics that abound here...
  15. 19Eddy30
    19Eddy30
    from VA
    Cool care ,a Real East cost ,
    Hot Rod
    Show Kustom
    Muscle car
    ""Yankee B-----d""
  16. Hitchhiker
    Hitchhiker
    That wasn't done for the exhaust. It's to keep the spring mounts where they need to be for the spring in front mounts.
    deadbeat, chryslerfan55, Tim and 2 others like this.
  17. Shaun1162
    Shaun1162
    A friend of mine has a set, he thinks they came off a Citroen
  18. panhead_pete
    panhead_pete
    I keep checking in hoping that you have found out some more about its history :)
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Amazing.
    Denns1989 and Stogy like this.
  20. Shaun1162
    Shaun1162
    I added some pictures to the first post in the thread.
    Did some more investigating. Guy gave me a tip that it might be from Joe Eichner Sr/Jr’s auto body shop which was in Colombia Connecticut. Unfortunately it looks like both of them have p***ed away.
    I got the engine to turn over, but it looks like it’s going to have to be pulled. Probably going to need a rebuilt. Not sure if it ever really ran... everything looked new under the valve covers. The front and rear tires were also brand new. Still have the nubs on em. Guessing they’re from the 60’s or 70’s
  21. 56sedandelivery
    56sedandelivery
    I see HEI type spark plug wires; is the distributor also an HEI? Someone may have updated it along the way. Is the rear end a 57-64, or a later Salisbury style? Mr. Palmer, the headers were originally SBC, but then modified to fit the Pontiac engine. Car looks like someone used a complete Pontiac from the 60's as a donor vehicle, and made themselves a 34 GTO. I am Butch/56sedandelivery.
    deadbeat, chryslerfan55 and Stogy like this.
  22. Wow ! That's a sweet find !!
    Stogy likes this.
  23. Spex84
    Spex84
    from Canada
    Holy **** that's cool. Don't change a darn thing! Well, maybe a safer driver's seat, and some new tires haha.
  24. ROADSTER1927
    ROADSTER1927
    That car is SUPER COOL!!!:)
  25. ^^My Thoughts Exactly !!^^
    Stogy, kidcampbell71 and Shaun1162 like this.
  26. Shaun1162
    Shaun1162
    Don’t worry, that’s what I’m thinking too! I’d like to get it back on the road for this summer.
  27. AHotRod
    AHotRod
    Man.... that Coupe is AWESOME !
    I'd drive it just as it is too.
    dana barlow, Stogy and Denns1989 like this.
  28. Stogy
    Stogy
    @Shaun1162, I looked through the entire Cool Cars and Square Roll Bars Book...nothing...that **** end is so unique you would spot it a mile away...
  29. Stogy
    Stogy
    So Shaun someone mentioned the rear end...the one in it looks crazy wide...is that illusion or caused by the offset of the wheel rim?...I thought 57 Pontiacs were like Bronco width...just curious and uninformed...:oops:
  30. Shaun1162
    Shaun1162
    Good eye Stogy, it is just an illusion. The seller stuck some reversed steel chrome wheels on there as rollers. It had 8 lug Pontiac with aluminum drums on it when built. They fit quite nicely up under the fenders, but the tires are gonzo.
    Thinking about switching to some Mickey Thompson Radars for the rear to match the front. Been doing some research, looks like I just need some drums.
    I scanned Cool Cars as soon as I got home with the coupe, but no luck here either!
