Technical Broke down, Vienna, Illinois
Discussion in 'The Hokey Ass Message Board' started by Movinman, May 8, 2021.
  1. Movinman
    Movinman
    Not in my 40 Mercury, but I am pulling it with my 2018 Ford Transit van. I’m still trying to figure out what failed, but we are leaking coolant from somewhere up front. Water pump, maybe radiator? Unfortunately, nothing is open until Monday, and I need to get my car to @choprods in Elmer, Missouri. Anyone live in the area that may be able to refer us toward an open shop? Thanks!
    Rob 954-598-1887
    kidcampbell71 likes this.
  2. lothiandon1940
    lothiandon1940
    Back near the top.
  3. indyjps
    indyjps
    Bump for ya, im no where close.
    I just took that cut across from nashville to rt57 last weekend, not much out there.
  4. MO54Frank
    MO54Frank
    Paducah, KY is 40 miles south.
    Marion, IL 30 miles north.
    Sorry, that’s probably no help. I wish I could do more.
  5. MAD MIKE
    MAD MIKE
    from 94577
    Quick google search came up with...
    https://static.nhtsa.gov/odi/tsbs/2017/MC-10127416-9999.pdf
    Actual fuse locations...
    https://www.fordtransitusaforum.com/threads/2016-250-3-7-overheat-3-fuses-blown.67058/#post-1060906
    If F08 fuse is original 20A it probably blew and took out F30/F31 with it.
    Replace F08 fuse with 30A and F30/F31 with original 40A sized fuses.
    EDIT: Looks like there may be an actual coolant deposit problem as well,
    https://ford.oemdtc.com/6685/3-7l-3...ing-2017-2018-ford-e-series-2015-2019-transit
    loudbang and lothiandon1940 like this.
  6. Stu D Baker
    Stu D Baker
    from Illinois
    Bump for the brunch crowd.
    lothiandon1940 likes this.
  7. pprather
    pprather
    @Movinman , I just sent you a conversation with some Paducah rodder's phone numbers.
    loudbang, Stu D Baker, i.rant and 3 others like this.
  8. Max Gearhead
    Max Gearhead
    from Wisconsin
  9. Movinman
    Movinman
    Thanks everyone for the help on this. We got some Bar’s Leak and ere able to temporarily solve the problem. Called a head to a friend in O’Fallon, Illinois, and he picked up a new radiator for me. We will install when we get there. Thanks again!
  10. pprather
    pprather
    Let us know how you are doing later.
  11. stillrunners
    stillrunners
    from dallas
