Technical Smelly Exhaust. The car
Discussion in 'Traditional Hot Rods' started by modagger, May 8, 2021.
  1. modagger
    modagger
    Greetings oh fount of knowledge
    I come to the well today seeking possible explanations as to why the exhaust for the Y Block in my Model A has an acrid smell.
    It does not smoke, either on start up or under power. The best description for the way it smells is, acrid.
    I have tried grades of gas from 87-93 all with the same result.
    New plugs, carb vacuum tuned, timing in a sweet spot.
    To quote James, The Godfather of Soul, Brown: “Somebody hep me now!”
    Jeff
    RONNY SCHRÖDER, loudbang and Deuces like this.
  2. seb fontana
    seb fontana
    from ct
    Summit sells stuff you can put in the gas to make it smell like roses, or blue berrys, or what ever.. Best I can do.
    ne'erdowell, loudbang and Lil32 like this.
  3. Roothawg
    Roothawg
    [​IMG] I have nothing to add.
  4. jimmy six
    jimmy six
    Are you sure it’s the exhaust? The gas today burns so clean in my Y even with dual quads I have no smell but I sure did when my engine was open. I added a PVC system and I have no more smell in the garage that I did for hours after coming home. I had to put a 61-64 valley cover to make it easier and it’s great.
  5. 19Eddy30
    19Eddy30
    from VA
    A18F633F-DAFE-42F6-B12C-6156DC3CBF04.jpeg Has the exhaust or engine or any parts of the engine been painted possibly that's what you're smelling or aluminized Exhaust ?? I drove & A for over 20,000 miles sedan with half interior both with header's over fenders & full under the car no exhaust smell at all in cab
  6. greybeard360
    greybeard360
    Acrid smell? Possibly coolant? It smells pretty bad when run thru a motor.
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    Mmmm. MMO is better than all that fruity kid stuff. Jack E/NJ
  8. modagger
    modagger
    If I had to chose, I’d take acrid over fruit. At least it smells like a car. :rolleyes:. Is that a grape with eyeballs I just put there?
    Thanks Seb
    RONNY SCHRÖDER and loudbang like this.
  9. modagger
    modagger
    I agree, but I’m not losing any coolant.
  10. modagger
    modagger
    Jimmy
    The smell is definitely coming out of the exhaust pipes.
    I too have the garage fumes when I put it away. I roll it out before starting so as not to fume the garage.
    Mind if I PM you for info on the PVC addition that you did? Sounds like it would do the trick for me too.
    Jeff
  11. modagger
    modagger
    The only things painted have been the exhaust manifolds but the “stank” preceded the paint job.
  12. Deuces
    Deuces
    Yep! It stanks!!!!... ;)
  13. modagger
    modagger
    Not wanting to seem like a big stupe, I was in the process of Googling MMO when I had the forehead slapping revelatory moment. It’s the oil made famous by Stan Lee, right?
  14. Joe Travers
    Joe Travers
    from Louisiana
    Rodent problems? Had this problem with old 8N Ford tractor and a 202 Mercury Comet out in the country. Packing acorns into the mufflers, burning critters and stuff like that. Anything spitting out the tailpipe?
    Joe
  15. Maybe you are not running her hard enough. Take her out and beat her like she owes you money.:D Just kidding, I have no idea, I always smell like exhaust.:eek:
  16. squirrel
    We need Smell-O-Vision.
    (look it up)
  17. Truck64
    Truck64
    from Ioway
    Could be idling or running too lean, even though it makes yer eyes water. Is it a stock cam? Stock carb?
    I think the smell-o-scope would be more accurate ! Lol
    Just started rewatching this show with my kids , too funny.
    Anyways smell from your tail pipe.
    pcv, or lack there of
    Burning oil or coolant ,
    Burning some type of paint or coating off the exhaust system ?
    I had a forklift a few years ago that mice stuffed fresh, unroasted coffee beans in the exhaust.
    It smelled like hair fire !! That one truck basically emptied out a warehouse!!!
    maybe a mouse made a house in your tail pipe a-la-Richard Gere ?
  19. jaracer
    jaracer
    If you are lean at idle you will get what I would call an acrid smell.
  20. modagger
    modagger
    No spitting:rolleyes: only stank.
    RONNY SCHRÖDER, Deuces and loudbang like this.
  21. modagger
    modagger
    Hah! Don’t have to look it up Jim. I remember when they tried that in a theater in town years ago. Everything smelled like wet newspaper.
  22. Bandit Billy
    Bandit Billy
    Acrid? Are you sure it's the car? It's a good idea to have a friend (female preferably...they have a better nose and don't seem to care it they are insultingly rude) give you the sniff test every now and again. Particularly you hot rod bachelors. Those shop clothes tend to get a bit "randy" at times and you may not even be aware.
  23. modagger
    modagger
    Going down the list of possibilities, not burning any oil. Not losing any coolant. Only new paint is exhaust manifolds and the stank was present before paint. So....., pcv seems the most likely cause, or lack thereof.
    No mouse residue present. Neither bedding acorns or fur.
    VANDENPLAS and loudbang like this.
  24. modagger
    modagger
    Hmmm. I’ll check that tomorrow.
  25. modagger
    modagger
    Nuttin’!
  26. modagger
    modagger
    I admit that on a rare occasion I may have had an odiferous “air” about me, but I’ve never been accused of being acrid.
    Now, let’s see can I find me a sniffer for hire.
  27. Frankie47
    Frankie47
    from omaha ne.
    Remember there is a difference between a sniffer and a fluffer.....lol.
  28. modagger
    modagger
    I didn’t build the engine or know about the innards. It is a great strong runner with a Holley 4160 carb with manual choke. 3 speed top-loader.
    Doesn’t smoke a lick.
  29. modagger
    modagger
    Which brings me to a question that I’ve tried to find an answer to for years. If the swallows return to Capistrano on the same day every year, do the spitters show up the day before?
    Butler 32, SS327, Frankie47 and 2 others like this.
  30. loudbang
    With the plugs out in the open like that the first thing I would do is pull a few and read them for signs of LEAN like others have said. :)
    modagger, mad mikey and Desoto291Hemi like this.
