Hot Rods need spring help
Discussion in 'The Hokey Ass Message Board' started by dill68, May 11, 2021.
  1. dill68
    dill68
    from upstate sc
    bought another 32 has a traverse spring with olds rearend with ladder bars. problem is rearend to wide and tire stick out fender but spring is to wide to get rearend where i want just wondering what spring everyone is running
  2. Hollywood-East
    Hollywood-East
    Pictures would help a Lot here...
    I've got spring problems here to... Low 40°s at night..
    warhorseracing and ottoman like this.
  3. dill68
    dill68
    from upstate sc
    Measures 47 inches
  4. saltflats
    saltflats
    from Missouri
    Can't you just get a spring the same width difference you plan to narrow the rear end?
    Like 4 inches narrower rear and a 4 inch narrower spring.
  5. dill68
    dill68
    from upstate sc
    Wheels are to wide but rear end also needs to be narrowed
  6. Mr48chev
    I'd have to think that it doesn't have a 32 spring or normal replacement for a 32 spring.
    It's going to take one of the Deuce brigade to give you the measurements you need to get it right.
    I don't know if you can edit the ***le but you probably should have put "Need 32 Ford rear spring help"
    ottoman and X38 like this.
  7. X38
    X38
    Indeed.
  8. alchemy
    alchemy
    Find a local spring shop. Might have to go to the closest big city. Take your main leaf as an example, and tell them you want the same thing, but X inches narrower.
    As you might find out by looking, stock 32 rear springs have a curve top to bottom and front to back. Only 32-34 springs did this, and it will take an experienced shop to make your replacement.
    Not sure if you knew, but that car was the subject of quite the thread a while ago. The original builder from way back when is a HAMBer, and some reminiscing was done about the car.
    catdad49 likes this.
  9. 57 Fargo
    57 Fargo
    I would leave it the way it is...but I’m weird like that.
    I know that’s absolutely no help
    Happydaze likes this.
  10. 1971BB427
    1971BB427
    from Oregon
    We have two spring shops locally and I've had shorter main leafs made for spring packs on a couple occasions. Then just bolt it into my pack. On one occasion my 2nd leaf ended up longer than the new main leaf so I just used my portaband saw to trim length off other spring leaf to make them all fit.
