Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    Probably just aluminum paint to start with, I like the paint on the '27s headers, very low maintenance and easy touch up
    kidcampbell71, Stogy and loudbang like this.
  2. Your talent and ingenuity never cease to amaze me.
  3. Nicey done, and thanks for the info!
    I'm guessing then, that it was a Barclay-
  4. rob-redm
    rob-redm
  5. 51box
    51box
    from MA
    Headers came out really nice
  6. bct
    bct
    So many interesting details to comment on. To keep it simple I mostly like the shock mounts front and back. The huge amount of room you have for an early T and everything about the front suspension.
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    What he said and besides, it's just a dang cool little hotrod.
    loudbang, Stogy and Paul like this.
  8. Stogy
    Stogy
    Mac, I looked all over for that but never figured it was a toy...I imagine many of these diecast toys were repurposed as cap ornaments...certainly a very unusual aircraft and apparently difficult to fly...
    @Paul, does that aircraft have a family connection either as a toy as a kid or the real deal? They are circa 1932 or so...
  9. Stogy,
    The jury is still not out on what plane this slush-mold toy was patterned after. There have been a few pop up on Ebay lately, and there are always seem to be three "windows" cast into the side of plane- if so, it's not a Gee Bee, but more like a Northrop Alpha. Either way, it's a great 30's toy and a clever way of using it!
    ...sorry for the thread-steal... now back to Paul's T :D
    Tman, kidcampbell71, warbird1 and 3 others like this.
  10. Stogy
    Stogy
    That's what Paul gets for capturing the wings in the foreground...:D...yes Mac I believe you are correct, that dull grey one is pretty convincing...especially noting the lack of skirting on the landing gear...yupp back to Hotrods...;)
    Paul and loudbang like this.
  11. Paul
    Paul
    Editor
    I guess I never really looked at it closely, it is not a Gee Bee, it is exactly the same as the picture of the Northrup Alpha toy Mac the Yankee posted above.
    can you imagine what it was like to be a p***enger in one of those, seated right behind that engine?
    bchctybob, Tman, Stogy and 2 others like this.
  12. Paul
    Paul
    Editor
    not much of an update here,
    'been pecking away at little stuff, not much worth do***enting.
    I did snap a few pictures of the dash rail replacement.
    the original angle iron dash rail support was bent and rusty
    so I replaced it with 3/4" square tube.
    PXL_20210504_004226531.jpg PXL_20210504_004251746.jpg PXL_20210504_004730164.jpg PXL_20210504_005636024.jpg PXL_20210504_181356415.jpg PXL_20210504_181400946.jpg PXL_20210504_181414246.jpg PXL_20210504_183907584.jpg PXL_20210504_193922946.jpg PXL_20210504_193939117.jpg PXL_20210505_003704874.jpg PXL_20210505_003712917.jpg
    bchctybob, OFT, AHotRod and 15 others like this.
  13. Paul
    Paul
    Editor
    the stanchions were also bent and fit poorly
    so using a little heat I got them to fit the contour of the cowl a little better,
    added some little crescent shaped wedges to close the gaps in the front,
    relocated screw holes and welded in receiver nuts on the dash side.
    fit is much better and they are surprisingly stout
    PXL_20210505_172349223.jpg PXL_20210505_172359229.jpg PXL_20210505_172406649.jpg PXL_20210505_172416052.jpg PXL_20210505_172432994.jpg PXL_20210506_010925072.jpg PXL_20210509_002558022.jpg PXL_20210509_002620989.jpg PXL_20210509_002626882.jpg PXL_20210509_002706136.jpg PXL_20210509_222012175.jpg PXL_20210510_193516686.jpg PXL_20210510_193525782.jpg PXL_20210510_193530804.jpg PXL_20210510_193541798.jpg
    RustyBullet, bchctybob, OFT and 23 others like this.
  14. jebbesen
    jebbesen
    from Winona, MN
    Man you do first rate work! Thanks for showing all the step by step shots too. It's great to see different peoples fab methods.
    Stogy, loudbang, Paul and 1 other person like this.
  15. 64 DODGE 440
    64 DODGE 440
    from so cal
    All of those little details to make it look like the parts were perfect to start with. Your metalworking skills are amazing.
  16. rob-redm
    rob-redm
    Mr. Detail ! .. nice man !
  17. Paul
    Paul
    Editor
    started working on the dash
    been thinking about it for a while
    had a few ideas but nothing firm.
    I bent up some 1/4" round stock to tape some ideas on
    scanned, printed to scale and cut out a set of gauges
    and taped them to some poster board
    tried a few different shapes and layout, oval, oval with V bottom, and t****zoid with top corners rounded,
    speedometer and tach centered, with small gauges on both sides
    speedometer and tach directly in front of driver seat with all small gauges to the right.
    settled on the t****zoidal shape with speedometer and tach in front of driver with small gauges to the right.
    bent up some 3/4" .062 wall steel tubing for the outer edge
    and used the 1/4" round to define the gauge panel
    filled the gap mig welded 18 gauge steel
    grind the welds down
    cut and bent a strip for the bottom edge
    mig welded it to the 1/4" round along the bottom and 3/4" tube at the ends
    and ground it all smooth.
    taped the paper dash panel in place
    and temporarily clamped the whole thing in place.
    the dash will get welded in and the gauge panel will bolt in from behind
    at least that's the plan today..
    PXL_20210511_013917070.jpg PXL_20210511_221140436.jpg PXL_20210512_235743893.jpg PXL_20210513_000359237.jpg PXL_20210513_000446961.jpg PXL_20210513_000458287.jpg PXL_20210513_182728985.jpg PXL_20210513_184102780.jpg PXL_20210513_194003841.jpg PXL_20210513_194034821~2.jpg PXL_20210513_194920287.jpg PXL_20210513_195529650.jpg PXL_20210513_202815760.jpg PXL_20210513_204039920.jpg PXL_20210513_210959975~2.jpg PXL_20210513_233654342.jpg PXL_20210513_233846400.jpg PXL_20210513_234635297~2.jpg
    bchctybob, silent rick, OFT and 22 others like this.
  18. No big deal, right? :p
    Looks amazing!
    silent rick, Stogy, RICH B and 2 others like this.
  19. Paul
    Paul
    Editor
    Just another day in the shop. ;)
  20. Paul
    Paul
    Editor
    Welded some 1/4-20 bolts to the perimeter of the opening,
    cut and drilled a piece of steel to hold the gauges,
    bolted the gauge panel to the dash,
    and got the whole shebang roughly where it will go.
    Again, dash will get welded to the body and gauge panel will be removable.
    IMG_20210515_162941_990.jpg IMG_20210515_162942_122.jpg IMG_20210515_162942_206.jpg IMG_20210515_162942_243.jpg IMG_20210515_162942_266.jpg IMG_20210515_162942_300.jpg
    bchctybob, OFT, The 39 guy and 15 others like this.
  21. lake_harley
    lake_harley
    I'm just going to sell my tools and equipment.......
    (hangs head in shame and shuffles off.....)
    Lynn
    spot, RustyBullet, razoo lew and 8 others like this.
  22. Paul
    Paul
    Editor
    Started to fill the gaps,
    P***enger side tacked.
    It will need a bit more m***aging but it's starting to take shape..
    PXL_20210517_225444951.jpg PXL_20210518_003123839.jpg PXL_20210518_003205994.jpg IMG_20210517_205153_798.jpg IMG_20210517_205153_819.jpg
    RustyBullet, bchctybob, OFT and 17 others like this.
  23. loudbang
    Can't get over just how GOOD your floor came out. Just catching a glimpse in these shots makes them stand out. :)
    Stogy, brEad, RustyBullet and 3 others like this.
  24. NashRodMan
    NashRodMan
    Wow, that dash is amazing! Nice work all over this car. A result of having the expertise, the tools AND knowing how to use them.
    You certainly have the skills.
  25. Yes, I was digging on the floors in the walk around video. I also like the way the headers came out. Relocating the generator was a good move. It's the little things...
    Stogy, loudbang and Paul like this.
    But of course I say that, my T has no floors!
  27. Paul
    Paul
    Editor
    same end welded and cleaned up, enough for bondo anyway..
    PXL_20210518_180012536.jpg PXL_20210518_205157724.jpg PXL_20210518_205208117.jpg PXL_20210518_211003176.jpg
    RustyBullet, OFT, Stogy and 13 others like this.
  28. Paul
    Paul
    Editor
    similar deal for the driver side
    but this time I welded the two pieces together and rough dressed them before welding them to the dash,
    figured without a door to remove it might make things a bit easier.
    cut, fit, tack, weld, dress, fit, weld and dress.
    PXL_20210519_175155718.jpg PXL_20210519_180159437.jpg PXL_20210519_180705682.jpg PXL_20210519_181212343.jpg PXL_20210519_182620404.jpg PXL_20210519_184841791.jpg PXL_20210519_190841261.jpg PXL_20210519_204200648.NIGHT.jpg PXL_20210519_213013784.jpg PXL_20210519_231123339.jpg
  29. Paul
    Paul
    Editor
    sneaking a little tip in here,
    when tig welding body sheet metal I typically use .035 mig wire.
    to make it a little easier to handle and feed,
    I unwind a couple coils from the spool,
    stick one end of the wire in a cordless drill
    and the other end in a vice,
    give it a spin under tension
    and voila, nice straight easy to feed .035 welding rod
    PXL_20210519_175619913.jpg PXL_20210519_175644721.jpg PXL_20210519_180106270.jpg
  30. Paul
    Paul
    Editor
    Stuck a set of gauges in the holes..
    (the space in the gauge panel below the gauges will get switches etc.)
    and snapped a couple pictures..
    I think this will do just fine. :)
    spot, bchctybob, silent rick and 26 others like this.
