Hot Rods MODEL A GUY'S - A GAS TANK QUESTION
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 13, 2021.
  1. HOTRODPRIMER
    HOTRODPRIMER
    When I built my Model A pickup back in the day I fabricated a gas tank to fit in the bed that looked similar to a metal box and the fact that the original tank had been cut out before I found the cab.
    What are you using for a gas tank? got a photo please share it with guys that may be building now. HRP
    dana barlow and 3W JOHN like this.
  2. A Boner
    A Boner
    Henry built mine!
    -Brent-, 3W JOHN, bchctybob and 4 others like this.
  3. Model A Gomez
    Model A Gomez
    My avatar 28 ran a V8 60 and the stock tank, nothing wrong with them except limits what gauges you can run in the dash. My 30 Sport Coupe has a Tanks 15 gallon tank in the trunk, I have a good 30 tank but didn't want to use it on this build. IMG_0446.jpg
    3W JOHN, bchctybob, Joe Blow and 3 others like this.
  4. 31Apickup
    31Apickup
    In my A PU I have a tank inside the frame fitted between the left frame rail and the driveshaft, I built a template and had it made. About 12 gallons.
  5. Joe Blow
    Joe Blow
    Not a truck.....but my coupe has an 18 gallon TANKS U2 Universal.
    -Brent-, 3W JOHN, winduptoy and 7 others like this.
  6. 2935ford
    2935ford
    I've seen lots of variations on the theme.
    Home built, purchased, '32 tank on the rear and Model T tanks in the trunk area.
    I have a '32 at the rear on my '28 Tudor and stock tank on my '29 coupe.
  7. Packrat
    Packrat
    I was actually going to ask this very question since I just bought a 29 pickup. It has a good stock tank. Thanks!
    3W JOHN, bchctybob, tdog and 2 others like this.
  8. AVater
    AVater
    Home built combination gas tank and battery box. Biggest I could get in and out was 11 gal. Looking a little dusty back there!
  9. Jkmar73
    Jkmar73
    from Tulare, CA
    I’m using an 18 gallon U2 tank from tanks inc. as well.
  10. ct1932ford
    ct1932ford
    I ran a stock tank in my Model A Tudor back in the 70’s. It was a solid rust free car. Never had any issues, but I must admit that I thought about 10 gallons of gas sitting nearly in my lap, more than once.
    Packrat, 3W JOHN, Elcohaulic and 6 others like this.
  11. I bought a '69 mustang stainless steel 19-gallon tank for my '29 AA, and will mount it below the bed and just behind the rear axle. I will fabricate an express bed with nozzle access through the floor. Like many others, I didn't feel comfortable having 10 gallons in my lap, and also wanted a minimal gauge arrangement in the dash. I'll put a tach and two other gauges overhead in a separate panel.
  12. Russ B
    Russ B
    29 ccpu
    29 cabriolet
  13. pprather
    pprather
    I drove my A Vicky for almost 30 years (140k+), with the stock tank and gauge. Never a problem.
    And at least as safe as the stock tank hanging out the back on my Deuce.
    Packrat, jim snow, 3W JOHN and 5 others like this.
  14. Blues4U
    Blues4U
    from So Cal
    I didn't want to put the tank in the bed of my truck, because I actually use the bed to haul stuff once in awhile. I mounted it instead behind the rear crossmember, and put an access hatch in the bed floor.
    Packrat, Gotgas, 3W JOHN and 10 others like this.
  15. Dave Mc
    Dave Mc
  16. dana barlow
    dana barlow
    from Miami Fla.
    When I was putting my first hot rod together in 1959,the 28A roadster tank already had a rust hole in lowest part of bottom. I was wanting to add over head swing pedals at the time! So cut the bottom out that dose not show from siting in a 28"A" anyway. Later made pedals out of the floor,but didn't know I'd change my mind than.
    So first gas tank,was what I had around,only held about 5 gal.,it was for a outboradmotor boat.
    After nearly a year,I found something a lot better then the ugly boat tank.
    There's a long story about that. But the short of it is,I got a beer keg/15.5 gal.,that both looked cool to me an held more gas. So I replaced the boat tank{like pic.} with what I thought was way better. Still drive with the same keg!
  17. fastcar1953
    fastcar1953
    168708658_4154285254617762_51101527845378256_n.jpg Mine is under the bed, behind the license plate. 15 gallon. I hate the look but I tried 3 different locations. 12000 miles later it works.
  18. Bugguts
    Bugguts
    My 29 has a homemade 14 gallon tank mounted in rear.
    Came with the car and was just a square box when I got it. It just didn't look right square and all when the cars lines are rounded.
    After considering a aftermarket 32 tank, I bent up some 20 gauge sheetmetal to cover the tank and make it appear more 32ish.
    To make it seem a part of the car, I brush painted it with Rustoleum as the rest of the car was brushed years ago.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Tim, 3W JOHN, Dave Mc and 5 others like this.
  19. Dean Lowe
    Dean Lowe
    Custom made 17 gallon tank. Good enough for my first RPU, good enough for this one.
  20. tdog
    tdog
    from Omaha, NE
    That is a cool tank !
    HOTRODPRIMER, 3W JOHN and Joe Blow like this.
  21. clem
    clem
    I don’t have a Model A, but remember reading an article in the early 1980’s about how to install twin saddle tanks inside the ch***is rails.
    Biggest issue was routing the exhaust pipes away from them for heat reasons. Although I am sure with today’s technology there would be better materials for heat shields available now.
    3W JOHN, HOTRODPRIMER and Joe Blow like this.
  22. Primered Forever
    Primered Forever
    from Joplin,MO
    Packrat, Tim, 3W JOHN and 7 others like this.
  24. Joe Blow
    Joe Blow
    Thanks man.
    3W JOHN and HOTRODPRIMER like this.
  25. HOTRODPRIMER
    HOTRODPRIMER
    Dean, that's basically how I mounted the tank in my Model A pickup, that truck is beautiful. HRP
    3W JOHN, dana barlow and Joe Blow like this.
  26. Blues4U
    Blues4U
    from So Cal
    I did too. I used the stock tank for years, but the filler neck was a little damaged and didn't seal well, so when the tank was full it would slosh out onto the cowl when I turned. And the wife always complained about the gas smell when we drove in it. So I mounted the new tank I posted earlier in this thread. I still have the stock tank, it just isn't hooked up. Maybe I should put a T in the line and hook it back up and put some gas in it to keep it from rusting out.
  27. Never2old
    Never2old
    from so cal
    Fabricated an aluminum 12 gallon tank that sits under the rear of the bed. The entire rear of the frame is custom.
  28. Russ B
    Russ B
    No photo, but if the back area between frame rails is open, a thin 49 Merc gas tank can fit nicely. I had one in my 29 Tudor in the sixties. I had split rear wishbones and open driveshaft. It won’t work if car is too low (if driveshaft is too high).
    Gas filler like 36 Ford. A very young me.
    LSGUN, 3W JOHN, Joe Blow and 3 others like this.
  29. sidevalve8ba
    sidevalve8ba
    I am still running the stock Model A tank on my Tudor. I have been for thirty five plus years with no problems. I see no reason to do otherwise now.
    -Brent-, D-Russ, Packrat and 5 others like this.
  30. Chicster
    Chicster
    In my 30 pickup.
