Hot Rods Tire size on 41 pickup.
Discussion in 'The Hokey Ass Message Board' started by PASTDUEBILL, May 7, 2021.
  1. PASTDUEBILL
    PASTDUEBILL
    I am putting a 65 mustang rear with 15/8 old style American tt wheels. What size tire can I put under there with no clearance issues?[​IMG]
    Sent from my iPad using The H.A.M.B. mobile app[​IMG]
    hotrodA likes this.
  2. krylon32
    krylon32
    from Nebraska
    I would think a 235/75R15 should work fine? I think a 255/70R15 would be a little wide.
    da34guy and 40ragtopdown like this.
  3. PASTDUEBILL
    PASTDUEBILL
    I was thinking a 225/75 but 235 would look better when I cut doughnuts in the parking lot. Got to let the big 283 eat.
  4. hotrodA
    hotrodA
    On mine, I mocked up an 8” wheel centered in the rear fender well, hoping that a 255/70R15 would fit.
    With a cross sectional width of 10.2”, I realized that the remaining space wasn’t enough to take care of any body roll, with 12” from the bed side to the fender lip.
    I settled on a 7” wheel and 235/70R15.
    Fronts are 185/70R15 on stock 15x5 Ford pickup steel wheels.
    Nice truck, BTW! Wish I could find AR TT’s in my bolt pattern, 5x5-1/2.
  5. Bandit Billy
    Bandit Billy
    Your rear axle is 57.25" WMS to WMS if the internet is correct :rolleyes:
    TT D 15X8 wheels are 4.5" BS
    If I am doing the math right no tire will fit those wheels to your truck unless you plan to tub it.
  6. Bandit Billy
    Bandit Billy
    Let me say without spacers...and a lot of them.
  7. PASTDUEBILL
    PASTDUEBILL
    If that happens, I'll put them on the black car.
  8. Atwater Mike
    Atwater Mike
  9. hotrodA
    hotrodA
    Correct BB.
    Bed width is 48-1/2”. 57.25” wms. - 9” total back space = 48.25”. Spacer req’d.
    I used 1.5” from USWheelAdapter.com. They show 1”, 1.25”, 1.5” in 5x4-1/2 BP.
    I had rather not, but Bronco rear end (5x5-1/2 BP) was already mounted.
    P.P.P.P. on my part.
    PASTDUEBILL and Bandit Billy like this.
  10. Bandit Billy
    Bandit Billy
    I think they look like 3.5 BS the second time I looked at them. Still need to run at least 1- 1.25" spacer on each side.
    PASTDUEBILL likes this.
  11. Elcohaulic
    Elcohaulic
    225/70R15
    Keep the wheels and tires all the same size if you want it to handle nice..
  12. PASTDUEBILL
    PASTDUEBILL
    You are correct. They are 8.5 wide with a 3.5 bs. I’m getting ahead of myself. Going to get the rear in place first. Then figure the wheels.
    Bandit Billy and Elcohaulic like this.
  13. Elcohaulic
    Elcohaulic
    I like to get the rear end as narrow as possible, that way I can run deep dish wheels and the rear end is stronger with less axle m*** to fail.. I like to use deep dish black steel or deep dish chrome wheels. I like the Wheel Vintiques Series 62 and Series 64..
  14. Bandit Billy
    Bandit Billy
    Good call.
