Projects '51 Mild Custom shoebox coupe
Discussion in 'Traditional Customs' started by Tony Ray, Sep 12, 2017.
  1. Are you interested in some new tail light lenses? I have some and also blue dot lenses that go with them. Let me know and we can work out something.
    loudbang and Tony Ray like this.
  2. Tony Ray
    Tony Ray
    I actually just bought a set of NOS lenses, though I’m on the look out for some Lee Bubble lens.. thank you though!
  3. Tony Ray
    Tony Ray
    Didn’t take any pictures but yesterday Chopolds finished frenching up the drivers said taillight, then we swapped out the 58 “ wide, 9 inch rear I had there for a 56” maverick rear. Big difference in clearance. Now I will have no problems running the 51 merc skirts! Hoping to sort out some side trim and a trunk latch this week, and get back to sanding more of that paint off this weekend.
    chryslerfan55, Thor1 and brEad like this.
  4. Tony Ray
    Tony Ray
    Mark(Chopolds on here) sent me some updated pictures of what he did today to the trunk.. cut out the plate recess, made the patch panel and put it on the English wheel then welded it in.. man I can’t wait to get there this weekend and put some work in![​IMG]
    Some por 15 on it
    New panel
    Welded in with the Frenched taillights.
  5. Tony Ray
    Tony Ray
    The sanding continues!![​IMG]
  6. Tony Ray
    Tony Ray
    So I made a post on Facebook about some ripple pipes.. someone responded he had a two piece ripple pipe, but only one side.. if anyone has a set, or know any information on who made these, I’d be interested in knowing! They are about 58 inches long, 1 3/4 diameter, the ripple is 16 inches long. As I said it’s two piece and the bends on both sides are very different from what I seen.. closer to a 45 on the exit end and more then a 90 on the front side.. IMG_5561.JPG
  7. Tony Ray
    Tony Ray
  8. Tony Ray
    Tony Ray
    All that left on the outside is little bit of the roof to strip..
  9. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    A sneaky way to catch me and Ron outside drinking a beer instead of working.......
    Thor1 and Tony Ray like this.
  10. Tony Ray
    Tony Ray
    Haha!! I totally didn’t notice that!! But at least I didn’t get Glenn in the picture doing all the shop paint work[emoji23]
  11. Tony Ray
    Tony Ray
    This weekends progress.. got the body all stripped for the most part.. need to do the inside of the trunk lid, the engine compartment and window and door jams. We taped up the 51 merc skirt then the trim to give me an idea what needs to be done, going to order two more quarter pieces and put them on the door and front fender. We think it will work better. Mark Wojcik started welding up the seam in the passenger side quarter, while I tried to get inside the window areas. Pretty happy with the progress! IMG_5794.JPG
  12. loudbang, Tony Ray and chryslerfan55 like this.
  13. Tony Ray
    Tony Ray
    got it from a guy on facebook, sold be the quarter panel pieces, both of the check pieces, and the door trims for 50.00 plus shipping. Think it ended up costing me almost 67.00 all together. Im looking for two more quarter panel pieces. I want to use them for the door and front fenders instead of the stock dodge door trim.
  14. brady1929
    brady1929
    Nice job, it looks great.
  15. Tony Ray
    Tony Ray
    Mark, (Chopolds ) from Customs by Flash getting some work done on my coupe.. sent me these pics tonight!! I am no longer going to have to worry about fighting with the removing the rear tires when it’s lowered!! The 51 Merc Skirts gave plenty of room to raise the wheel wells! Thank to Gunar Hansken of the Swanx car club for the idea!!
    Here’s the rear wheel well to start..
    Some cutting..
    Little bit more...
    Some welding..
    Now the wheel well fits the 51
    [​IMG]merc skirt instead of making the skirt fit the shoebox.. all in all Mark said he raised it a little under 2 1/2 inches. Should have no problems with taking off the rear tires now!
  16. loudbang
  17. Tony Ray
    Tony Ray
    chryslerfan55, loudbang and Thor1 like this.
  18. Tony Ray
    Tony Ray
    Chopolds posted some pics up,of the wheel well tonight..[​IMG]
    And now the wheel goes on with no issues! [​IMG]
  19. Tony Ray
    Tony Ray
    Passenger side rear wheel well just about done![​IMG]
  20. Tony Ray
    Tony Ray
    I am looking for two more pieces of 1955 dodge custom royal lancer, or coronet rear quarter panel trim. Can be off a 2 door or 4 door..I need the left and right side.. pic has the style trim and which part I’m looking for. Please let me know if you have it or if you know who might! This is for my shoebox...thanks!
  21. Tony Ray
    Tony Ray
    Mark (Chopolds) owner of Customs by Flash, just put these up.. man.. I can’t wait to get there tomorrow and work on my coupe! This thing is moving right along! At first glance, you can barely tell the rear wheel well is moved up 2.5 inches! Not have any tire issues now!!
  22. 54delray
    54delray
    from Fremont NE
    Cool project. You might want to try @chevsotolac here on the HAMB. I saved a post of his for future reference when I might need some trim for a custom project.
    Tony Ray, loudbang and Thor1 like this.
  23. Tony Ray
    Tony Ray
    I tried but he didn’t have any..
  24. Tony Ray
    Tony Ray
    Mark, ( Chopolds) at Customs by Flash posted these last night! Right quarter is now all finished up! The more I look at it the more I’m amazed. Between raising the rear wheel well, frenching the taillights and decking the trunk lid, the coupe is coming together! All that’s really left for the back end, is mounting the remote trunk latch. The skirts may get a little modifications to the front side, so it matches the new trim line, but otherwise they are done! Next up doors and front end!!!
  25. Tony Ray
    Tony Ray
    More from Chopolds.. man I’m starting to think he gets more done when I’m not around![​IMG]
    door before.. and
    Door after...
    And drivers quarter done with skirt mounted!
  26. Looks amazing!
    Tony Ray and loudbang like this.
  27. Tony Ray
    Tony Ray
    More updates.. after seeing the pic with the skirt on, I just had to ask Chopolds to go ahead and do a little work to the doors as well.. I am so happy how it’s going!!can’t wait to get there Saturday![​IMG]
  28. Tony Ray
    Tony Ray
    And the bottom of door..
  29. Tony Ray
    Tony Ray
    Some random pics from today at Customs by Flash..
    54delray, Thor1 and 40LUV like this.
  30. Tony Ray
    Tony Ray
    brEad, Thor1 and 40LUV like this.
