History Anyone recognize this 60’s, Orange, Channeled ‘34 5 Window from New England?
Discussion in 'Traditional Hot Rods' started by Shaun1162, May 5, 2021.
  1. Stogy
    Stogy
    I think they are French aftermarket lights
    Auteroche Headlights many models of...
    Actually down diagonally to the right from the Big A is a smaller group of lettering including Auteroche...
    This is a pair of French approximately 7 1/2 inch headlights with a prominent A in the center of the lens in very good used condition. The portion of the lens that shows is approximately 6 1/2 inches.
    1930, 1931, 1932, 1933, 1934, 1935, 1936, 1937, 1938, 1939, 1940, 1941, 1942, 1943, 1944, 1945, 1946, 1947, 1948, 1949
  2. KKrod
    KKrod
    Really like the look of this coupe. Congratulations for the great find.
    Shaun1162 and Stogy like this.
  3. Shaun1162
    Shaun1162
    No update on the history, other then the lead I had in CT didn’t pan out. Not sure this car was ever seen much. Odometer says 21 miles, and the tires still had nubs on them. With the 389 it mighta scared them driving it!
    I was able to get the engine to turn over, but couldn’t get it to run. After more investigating, it looks like it needs a rebuild. Pulling it out tonight, bringing it to machine shop tomorrow.
    So far I’ve found it has an Edelbrock intake, Isky roller tappets, aluminum flywheel, bore .060 over, and a Hurst mount. Curious to see what the cam is!
    deadbeat, WC145, AHotRod and 11 others like this.
  4. What a *****in' car man!
  5. 1934coupe
    1934coupe
    By the looks of the parts it had to be a pretty potent engine, especially in a light car. Those look like high compression pistons.
    Pat
    Stogy and Shaun1162 like this.
  6. slick a&t
    slick a&t
    Story I heard is that the car was built and driven very little and then parked until recently discovered.
  7. Shaun1162
    Shaun1162
    Do you happen to have anymore info? Or maybe know someone that might? Seller wasn’t helpful. That story would go along with the 21 miles on the odometer, and the nubs still on the tires
    deadbeat, chryslerfan55 and Stogy like this.
  8. Tim
    Tim
    from KCMO
    Very cool!
    Start looking right there at spring in front hot rods. Super common with 40’s axles because the wishbone is further out toward the king pin. If you split it and pull them out to the frame your turning radius is compromised when the tires hit the split bone. So lots of them get bent there, seems like it would be an easy thing to spot but it’s easy to overlook when a cars all together :)
  9. triumph 1
    triumph 1
    Wow! I love it, nice find!
  10. TBG
    TBG
    what town did you find it in? how long was it there?
    chryslerfan55, Shaun1162 and Stogy like this.
  11. Shaun1162
    Shaun1162
    I bought it out of Plantsville CT, but I don’t think the car has been there too long. Seller said he got it from his friend who had it a long time, but wasn’t the builder. Couldn’t get anymore information out of him.
  12. CaptainComet
    CaptainComet
    Cool find. All the work in the motor is intriguing.
    If you are looking for 14" tires, they are getting harder to find in the wide profiles. In a white letter tire, look at MasterCraft Avengers. Made by Cooper, you can get them through Pep Boys.
    You can still get 235-60-14 along with 215- and 225-70-14s
    These are radials.
    If you are looking to duplicate the tread pattern and white letters, Coker has some options.
    deadbeat, chryslerfan55 and Shaun1162 like this.
  13. Shaun1162
    Shaun1162
    Christopher Laurin sent me this photo that he saw on Instagram. It’s so close, but there’s a bunch of difference. The engine sits too high (or the cars not channeled as much), looks like a chrome firewall without the master cylinder, and it looks like a spring over axle with slightly different rims.... The rear fenders and some other details are so close though!
    Thanks for the link, I had noticed they were sort of scarce. I’ve been browsing Coker, and they’ve got some neat options. I really want to find a pair of Mickey Thompson Radars for the the rear to match the front.
  14. ss34coupe
    ss34coupe
    Here is my channeled 33 coupe built as a tribute to the way guys used to build hot rods like yours.
    Just a tremendous find you have, it would be my dream to get a coupe built back in the day - good luck with your project! IMG_3012.jpg
  15. Baumi
    Baumi
    That´s a way cool HotRod! I ´m keeping my fingers crossed for you to find out more about its history!
    jimpopper and Stogy like this.
  16. Spex84
    Spex84
    from Canada
    The car Shaun1162 posted is the same one I was looking for in my own downloaded photo collection because I thought it might be your car (nope, for all the reasons pointed out above)...but here it is again at the NSRA Memphis nats '75, in blue, with an added fan shroud:
    deadbeat, AHotRod, Stogy and 5 others like this.
  17. Shaun1162
    Shaun1162
    Now you’ve got me wondering!
    There is similar blue paint on the inside of the p***enger door! Also, before the engine was painted the current blue it looks like it was gold and red before that!
    Does that look like a Pontiac engine to anyone else? Also the exact style valve covers and hold downs.
    Do you happen to have anymore info on the car??
  18. harpo1313
    harpo1313
    from wareham,ma
    Blue on the rear fender also
    Stogy likes this.
  19. Shaun1162
    Shaun1162
    deadbeat, AHotRod, Stogy and 3 others like this.
  20. Doublepumper
    Doublepumper
    from OR-WA, USA
    Looks like one to me.
    Stogy likes this.
  21. Hollywood-East
    Hollywood-East
    It ain't SBC., 1 for poncho, From here..
    Stogy likes this.
  22. alchemy
    alchemy
    The red/blue coupe has the rear fenders welded on above the bead. The orange coupe has the fenders welded on below the bead. Seems odd that someone would remove the old fenders and install them again one inch lower. Not the same car.
  23. Shadow Creek
    Shadow Creek
    Also looks like a rectangle or square filler door on the driver quarter on the blue coupe..does yours possibly have any evidence of that? Just another detail to look for. Either way, nice find
    Stogy and Thor1 like this.
  24. 31Apickup
    31Apickup
    The red/ blue car has Michigan plates, red version has 71-72 plates, blue version 73-75 plates.
    Stogy and chryslerfan55 like this.
  25. Jim Bouchard
    Jim Bouchard
    I see the gas door.
    The op needs to check for that!
    HEMI32, Stogy, Thor1 and 1 other person like this.
  26. triumph 1
    triumph 1
    X2
  27. Spex84
    Spex84
    from Canada
    The red/blue car is definitely not the OP's orange coupe(key differences include stock vs chromed flat firewall, rear fender shape, front spring/axle arrangement, channel depth, etc), but perhaps a brother from another mother.
    I hope more info comes to light!
  28. Shaun1162
    Shaun1162
    Yes, the blue/red car is not the same. The original builder is actually on the H.A.M.B. No luck with any other leads.
    I got the motor pulled and off to the machine shop, hoping they can reuse most of the internals. I should know by the end of the week.
    Picked up these recovered Camaro buckets for a good deal off a friend of mine. I took the tracks off to try them out, need to cut down the tracks as much as possible. I removed the gas tank and device holding it, need to figure out if i can modify and re-use them. Car wasn’t built for someone 5’11”!
    deadbeat, WC145, mad mikey and 13 others like this.
  29. 32 hudson
    32 hudson
    Seats look good and fit good in there.
    Joe Travers, Denns1989 and Thor1 like this.
  30. Pitbullgoingpostal
    Pitbullgoingpostal
