History 1956 Ford Thunderbird find, eventually buy, and get most of way home!!
Discussion in 'The Hokey Ass Message Board' started by Hamtown Al, May 10, 2021.
  1. lothiandon1940
    lothiandon1940
  2. 41 GMC K-18
    41 GMC K-18
    Perfection cannot be rushed !
  3. jimmy six
    jimmy six
    Hambtown Al just purchases a 65 year old car and you ask who put a part that doesn’t belong on it. WTF you’ve got to be kidding. What an insult.
    How com you didn’t comment after the first post that shows the emblem under the car cover....
  4. Hamtown Al
    Hamtown Al
    ^^^I'll have to check but I think that emblem on the grille comes with membership in one of the Thunderbird clubs.;)
    Many car clubs have an emblem that you can mount on your grille... or elsewhere... can you say HAMB license plate topper?!;):D:D
    I'm pleased to report that Bert and my daughter have taken the top off (as suggested!!:D) and have been driving the car and giving several folks, including my granddaughter!:), a ride most of the day! They are very happy and I'm happy for them.:)
    Thanks again for the interest and encouragement.
    Now I'm gonna see about relocating that battery to the trunk... so changing the spark plugs will be much easier in the future!!;):D:D
  5. tub1
    tub1
    from tasmania
    How long before your grandaughter wants to borrow the car wow they are cool cars I'd have one if I could afford one
  6. Fortunateson
    Fortunateson
    '56 was a great year for T-Birds, wine, and births but a bad one for the Suez C****!
  7. Fortunateson
    Fortunateson
    I love a happy ending...
    Thor1, Hamtown Al and jimmy six like this.
  8. Hamtown Al
    Hamtown Al
    Yep, International Cl***ic Thunderbird Club... but not as cool as HAMB!;):D:D
  9. tbirddragracer
    tbirddragracer
    Al,
    ctci.org lots of information there.
    Ernie
    loudbang and Hamtown Al like this.
  10. jaracer
    jaracer
    Sure enough, I took it apart and dialed in the setting such that choke was off after warming up and it starts fine!:)
    Thanks for all the help and encouragement and remember to check the dang automatic choke on your carb!!
    Boy I'm glad we figured this one out.:)
    Thanks again,
    Happy Al[/QUOTE]
    Is the choke tube getting hot? In order for the choke to work properly you really need the exhaust flapper valve working and the tube in the intake functional. You have a little filter on the left hand side of the intake that draws air in the tube and it gets heated with exhaust as it is drawn into the choke housing via a small vacuum port inside the choke housing. When the engine is warmed up, the tube going to the choke should be very hot. If it doesn't get hot you will never get the choke to work correctly.
    If the flapper works, and the tube isn't plugged or burned in two inside the intake, the correct way to set the choke is with the engine cold. On a cold engine you turn the choke adjustment until the choke plates just barely close. That is a base starting point. From there one or two marks lean or rich is about all you should need to dial it in. With a good heat stove (the tube in the manifold) the choke should be fully open with the engine at operating temperature.
    If the flapper isn't working and/or the tube is broken or plugged, an alternative is an electric choke cover. Wire it to an ignition circuit and set the choke as I described above. The electric covers work well. That's what I have on my 57.
  11. Hamtown Al
    Hamtown Al
    ^^^Thanks greatly for the added education and insight.;):) Thunderbird club link, too.;)
    We still need all we can get!:D
    We were looking at an overly bent short tube going to the carburetor when the light came on in my pea brain to check the automatic choke!:D
    We will follow up on the added tips.
    Thanks.
    Al
  12. jaracer
    jaracer
    The emblem signifies membership in Cl***ic Thunderbirds Club International.
    Thor1, Hamtown Al and loudbang like this.
  13. jimvette59
    jimvette59
    YUP that choke tube is the first thing I spotted . Find a NOS or a Repro. one. It looks like somebody tried to make one. JHMO
  14. Hamtown Al
    Hamtown Al
    An update:
    Ordered a new distributor that has mechanical tach drive and electronic ignition.
    Had a pal really come through to help by finding an old, pretty much thought of as unobtainable, adaptor to mate a new Edelbrock to the stock 56 intake manifold!! Hope to have all the pieces(I know about!:D) next week.
    I've still got much to learn about how the current system is supposed to work and what will happen when I start tossing and disconnecting the various hoses and lines!:eek::D:D
    Opportunities!!;):D:D
  15. Hamtown Al
    Hamtown Al
    Pure unobtainium!!
    OahuEli, Thor1, loudbang and 3 others like this.
  16. jaracer
    jaracer
    It is a 57 or newer distributor, right?
  17. Hamtown Al
    Hamtown Al
    Supposedly all brand new parts.
    CRT Performance if I remember correctly.
    loudbang and lothiandon1940 like this.
  18. egads
    egads
    I'm not positive but I think this is the adapter you need. --1351935b --The one you show has straight bores- this one has tapered bores. Speedway has them.[​IMG]
  19. jimmy six
    jimmy six
    I didn’t know that...I have 3 .. 1 straight and 2 tapered. 2 came on a dual quad manifold I bought. I think Speedway sells them to fit large base 4 barrels on the flathead 4barrel manifold they sell. So does Clifford Performance for their inline 4 barrel Manifolds..
    Thor1, loudbang, egads and 1 other person like this.
  20. bobss396
    bobss396
    Great story! I tell people that our old cars help keep us off the streets.
  21. Hamtown Al
    Hamtown Al
    ^^^Fantastic!! Obviously I didn't know about Speedway making them... hopefully somebody would have found it for me or I'd have stumbled onto it by myself.
    Thanks, greatly for finding them and sharing the news that they are readily available.
    Teapot owners rejoice! Keep them if you love them but at least there is a relatively inexpensive way to go to alternative carburetion. Another option I found was a brand new intake made just for Thunderbirds that cost $485 as I recall. This is good news for all Y Block owners as to options in building and maintaining their vehicles.
    Another "opportunity to succeed" accomplished... with help from my pals... and the HAMB!!;):D
    Thanks to all,
    Happy Al
    PS Now if I can make it all work properly when I start disconnecting vacuum lines and hoses.:eek::D
    The "opportunities" keep a coming!!:D:D
    I'll keep ya posted.:)
  22. miker98038
    miker98038
    The va***n lines will be easy if you keep them separate. The ones to the loadomatic go away. If it’s a 140x Edelbrock, it will have a port on the back for the brake booster, and the junction block may be reusable for the wiper circuit. The wiper vacuum hose also T’s off under the dash to the heater temp control, so you’ll want to maintain all that (there’s a heat sensing device on the heater box that actually controls the vacuum to the heater valve in the hose on the intake manifold).
    If the new distributor has a vacuum advance, you can choose either full or ported vacuum at the front of the Edelbrock.
    Last item on the throttle linkage. If it’s an o/d car, WOT needs to be set to still activate the kick down switch under the throttle pedal. No o/d, no problem.
    I don’t remember any of this being a problem when I pulled the Tpot on my 55, just things to be aware of.
    warbird1, Hamtown Al, Thor1 and 3 others like this.
  23. Itchy-Pit
    Itchy-Pit
    Great story thanks for sharing! Enjoy!
  24. OahuEli
    OahuEli
    from Hawaii
    Great story! It brought back quite a few memories from when I lived in Portsmouth back in the '80s. A buddy bought a '54 Ford Country Squire that was sitting in a field (out near Windsor I think), we got it running and drove to Portsmouth. After doing the normal stuff it became his daily driver but soon developed issues; it would shut off just driving down the road, let it set a few and sometimes it would re-start.
    We did the same stuff, electrical, carb, fuel pump etc but the problem persisted. One day Keith smelled gas, come to find out the fuel tank rusted through on the top. We actually found another tank at the old Matthews junkyard near the Portsmouth/Chesapeake airport and while swapping tanks we drained the last bit of fuel and what came out of the tank? About a dozen mummified bee bodies! We figured they got in there somehow while the car was sitting in the field, ended up dieing in there and would move around in the tank and eventually get pulled up to the fuel suction, cutting off the fuel. After installing the replacement tank he never had the problem again. Still makes me laugh.
  25. Hamtown Al
    Hamtown Al
    ^^^Thanks greatly for the guidance on vacuum hoses, etc. and what impacts what.:)
    The story about Portsmouth, Windsor, and Matthews Junkyard all bring back memories for me as well. There was a 46 or so Hudson pickup in Matthews for years and years.
    I hope to get all the pieces this coming week... stay tuned... and thanks again for the help and encouragement!:)
  26. rustydusty
    rustydusty
    I've never been a huge fan of black cars, but that color is perfect on that '56!
    I've never been a fan of white cars either (like mine) but that's gonna be changed to "seafoam green" before next spring...
    bobss396, Thor1 and Hamtown Al like this.
  27. trevorsworth
    trevorsworth
    I'm not gonna be able to sleep until I know what happened to the tires. Come on, you set up the suspense...
  28. Hamtown Al
    Hamtown Al
    ^^^Okay, I'll contact the lady we got it from. I was gonna wait until I had the car revamped such that I was pretty sure we could go see her in the car and still get home!!:D I was gonna ask her then but I'll give her a call... I agree it is a mystery.. and one WE didn't catch at first!!:eek::D
    Thanks for the continued interest.
    Distributor arrives tomorrow... I hope!:)
    OahuEli, loudbang, Thor1 and 3 others like this.
  29. sidevalve8ba
    sidevalve8ba
    Glad to see you are making the most of your "opportunities", Al!
  30. jamesu
    jamesu
