Technical 1931 Pontiac build - 25 years and counting
Discussion in 'The Hokey Ass Message Board' started by 31 B'ville, May 15, 2021.
  1. 31 B'ville
    31 B'ville
    from SE Pa
    A few days ago I had a request from clem of New Zealand to post a build thread of my '31 Pontiac Sport Coupe project, so I will attempt to show this 22 +? year project.
    I started this build in 1999 with a pretty complete car with a lot of rotten wood. The vision was to build a traditional '60's style hot rod , although a Pontiac of this vintage was not a normal starting point for this style. As disassembly progressed , we (my brother and I) decided to replace the wood body structure with wood and found an Olds J2 to power it.
    We removed the parallel-leaf front suspension and installed a Ford crossmember and drilled I-beam axle.
    I will try to stay in chronological order, but it may not be 100% because so much time has passed since day 1. 1931 PONTIAC (1999) 002.jpg 1931 PONTIAC (1999) 001.jpg PhonePics 106.jpg PhonePics 133.jpg 20170730_192108 (2).jpg
  2. oldolds
    oldolds
    Hold on guys. This is gonna be good. I have seen some pictures of this car.
    clem, winduptoy, Stogy and 2 others like this.
  3. I have a love ,hate relationship with wood !!!
    MORE , MORE !!!
    winduptoy, clem and Stogy like this.
  4. 31 B'ville
    31 B'ville
    from SE Pa
    100_3970.jpg 100_3971.jpg 20161122_214654.jpg 0206131821.jpg After bracing the body it was removed to work on the frame. Major improvements were done to reduce flexing as much as possible so we modified a Chassis Engineering 'X' to fit the Pontiac frame and then added 1/8" boxing plates with lightening holes in front of and after the 'X'. Also added the mount for a Vega steering box.
    Chrome reverse wheels (15 x 6 front and 15 x 8 rear) and tires were added to mockup stance and fender clearance. At this early stage of the build, Pennsylvania still required fenders, so my original plans were to meet the state requirements. Several years later the laws changed to allow fenderless hotrods and my plans changed accordingly. The rear had already been narrowed for fenders, so they could be added later if one would want to.
    The rear I chose is a '57 Pontiac housing with a '62 Pontiac 3:08 posi center section. I'm a Pontiac guy so that period Pontiac/Olds rear was a perfect choice.
    Pete & Jake's ladder bars were used as part of the rear suspension, as were the Aldan Eagle coilovers.
  5. 31 B'ville
    31 B'ville
    from SE Pa
    First engine installed, a 1957 Olds J2 with a Turbo 350 modified to fit the Olds.
    Next we chopped the top, 3" at the windshield and 2 1/2 " at the back window. 060711203226.jpg '31PontiacChop12.2011 004.jpg '31PontiacChop12.2011 011.jpg '31PontiacChop12.2011 020.jpg '31PontiacChop12.2011 021.jpg
  6. 31 B'ville
    31 B'ville
    from SE Pa
    100_1518.jpg 0206131832.jpg 011912183742.jpg 0206131815.jpg 0206131817.jpg We removed the body and old wood after the roof chop. First pic is the body wood kit (not including wood for the doors) from Jim Rodman . Before I began****embly, I coated each piece with 2 coats (3 coats on the end grain) of clear epoxy to stabilize the wood from expansion and contraction from humidity changes.
    After making sure the frame was level and square, I****embled the wood structure for the body starting at the bottom.
    treb11, jazz1, Okie Pete and 21 others like this.
  7. What year crossmember did you use to use the transverse spring and front axle ??
    VANDENPLAS, Stogy and loudbang like this.
  8. triumph 1
    triumph 1
    Very cool build! The Olds rocket mill is killer. I’ve never really seen how much wood is actually in the body of early GM’s. Thanks for posting all the pictures.
    VANDENPLAS, Stogy, clem and 2 others like this.
  9. 31 B'ville
    31 B'ville
    from SE Pa
    1932 Ford crossmember with a 4” drop 47” axle.
    VANDENPLAS, Thor1, Stogy and 3 others like this.
  10. Rckt98
    Rckt98
    Holy***** that is a big project. Nice to see something different being built.
    Stogy, GlassThamesDoug, clem and 3 others like this.
  11. Have a 33 chev ,thinking of using a transverse spring and axle in it . Chev dropped axle is just way to much money to ship to and from SIDS.
    Also a 34 crossmember somewhere among my junk , LOL
  12. clem
    clem
    Thanks ! ( I just knew this was going to be neat ).
    I saw hints of your workmanship, chassis etc, in other photos that you posted, but had no idea about the wood frame. (And I guess that you had to chop the wood to suit the roof chop).
    There’s a lot of work and dedication there.
  13. WB69
    WB69
    from Kansas
    Wow, the wood replacement looks awesome. Actually the whole car looks awesome.
    Stogy likes this.
  14. 31 B'ville
    31 B'ville
    from SE Pa
    Thanks for the comments. I actually did not chop the wood myself, Jim Rodman made the affected pieces to accommodate my dimensions.
    winduptoy, Thor1, Stogy and 3 others like this.
  15. 31 B'ville
    31 B'ville
    from SE Pa
    PhonePics 067.jpg P1010818.JPG PhonePics 079.jpg The Olds J2 and Turbo 350 had been mounted when a friend informed me that he was selling a '69 Pontiac 428 out of a Bonneville and I couldn't resist getting it. After trying for over a week to avoid redoing all of my work to install the J2, I decided that my Pontiac should be Pontiac-powered. I had a pair of RA III exhaust manifolds from a '69 Firebird that fit inside the frame but had to fabricate new motor mounts. Also designed and built the A/C bracket.
  16. guthriesmith
    guthriesmith
    Very cool! Will be following along!
    winduptoy, Stogy and loudbang like this.
  17. 31 B'ville
    31 B'ville
    from SE Pa
    Near disaster struck in Feb. 2014 when a major snowstorm collapsed a good portion of the roof of my building. Luckily a non-load bearing wall stopped the progression of the collapse before it got to my car, but I couldn't work on it for 6 months while the structure was being rebuilt. 0217141540.jpg 0217141559.jpg PhonePics 033.jpg 0225141628.jpg
  18. 31 B'ville
    31 B'ville
    from SE Pa
    Back on track! Engine rebuilt, bored 30 over, #068 cam, low compression heads, Offy dual quad intake with Carter 500's, and NOS 1961 Weiand valve covers. About 400 HP. A Pontiac Turbo 350 was also rebuilt and a new driveshaft ordered from Inland Empire. P1010935.JPG P1020014.jpg
  19. blowby
    blowby
    from Nicasio Ca
  20. 31 B'ville
    31 B'ville
    from SE Pa
    Repaired some rust and splits on the cowl and added a recess for servicing the distributor (with a lot of help from my brother). Next we nailed the cowl to the wood structure. 20151005_215317.jpg 20151013_200937.jpg 20160111_222454.jpg 20160113_190926.jpg
  21. 31 B'ville
    31 B'ville
    from SE Pa
    We built an upper and lower baffle to optimize cooling by preventing air from spilling around the radiator. Picture also shows an early headlight bar mockup. 20151105_185254.jpg
  22. 30tudor
    30tudor
    Post 6 is great. They are indeed horseless carriages with some sheet metal tacked on. Great job and looking forward to more info. A cousin of mine in Iowa has a couple of Oaklands of that vintage.
    Cheers.
    winduptoy, Stogy and 31 B'ville like this.
  23. 31 B'ville
    31 B'ville
    from SE Pa
    Now it was time to put the body back on the wood framework. We removed the rear wheels and starting from the back, slid the sheetmetal forward onto the wood until it was positioned correctly, and nailed the whole perimeter of the body to the wood. Sorry, I have no pictures of the process, my hands were full. 20160229_212345.jpg 20160229_212415.jpg
  24. spudshaft
    spudshaft
    Very cool car. Thanks for posting this.
  25. Texas Webb
    Texas Webb
    Quite the woodwork craftsman,awesome work!
  26. 31 B'ville
    31 B'ville
    from SE Pa
    With the body in place we addressed the poor fit of the rumbleseat lid. Adjusted as much as we could, then my brother removed a sliver of sheetmetal to make the gap more uniform. P1020053.JPG 20160502_204614.jpg
  27. 31 B'ville
    31 B'ville
    from SE Pa
    Time to deal with the doors. We removed all the original trim, hardware, upholstery and all the remaining nails holding the metal to the wood frame. Then we opened the crimp around the door skin to remove it to gain access to some blind fasteners when we****embled the new wood structure. While door skins were off, I coated the inside with POR-15. Also chopped the doors at this time. In order to make the doors fit properly, we did a thin pie cut on the skin and also modified the top hinge so it would line up perfectly with the other 2 hinges. A lot of time was spent to make the doors look right and operate correctly, P1010898.JPG P1010966.JPG P1010946.JPG IMG_0282.jpg IMG_0263.jpg IMG_0272.jpg 20150119_210540.jpg 20160921_221928.jpg
  28. 31 B'ville
    31 B'ville
    from SE Pa
    P1010791 (2).JPG 20161207_221158.jpg 20170327_190902.jpg I tried to improve my original front upper shock mount design. First picture shows 1st style, second picture shows updated version.
    Also added a bolt-in crossmember connecting the motor mounts to strengthen the frame, but still enabling access to oil pan if necessary.
  29. 31 B'ville
    31 B'ville
    from SE Pa
    I wanted electric windshield wipers but I couldn't find a direct replacement to fit a '31 Pontiac, so I adapted a a New Port Engineering Ford Model A wiper setup and mounted it as high under the visor as I could. IMG_0395.jpg IMG_0394.jpg 20170524_192236 (2).jpg
  30. 31 B'ville
    31 B'ville
    from SE Pa
    I chose a 1965 GTO automatic shifter and used a Shiftworks conversion to make it work with the Turbo 350. Made a few cuts and modifications to make it fit where it felt right. 20170424_151132.jpg 20180110_184945.jpg 20180110_184955.jpg
