Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Jethro
    Jethro
    Is that teak? Looks like a sailboat deck.....in a good way
  2. dumprat
    dumprat
    from b.c.
    I'm not a wood guy. It might be maple. It has a lot of really nice grain and burl marks. It's really springy and tough. It is scrounged from dunnage for a steel building a former employer put up.
    Stogy, brEad, loudbang and 2 others like this.
  3. dumprat
    dumprat
    from b.c.
    IMG_0388.jpg IMG_0387.jpg More and wiring related items today(and my wife wonders why it takes so long!)
    Scuffed and repainted my Kattle Kaller horn. Not sure of the application, my Dad got it at a garage sale for me. It's old, cable operated, and extremely loud! Kinda has atone like an angry duck.
    Then I built little adapters to use H4 bulbs in these old Lucas headlights. They had a funky bulb that looked like an Edison bulb.
    Okie Pete, jvo, guitarguy and 6 others like this.
  4. dumprat
    dumprat
    from b.c.
    IMG_0390.jpg Nerf mounted and polished with the little King bee light I found mounted and done up.
  5. Tim
    Tim
    from KCMO
    That’s killer! Front to back, inside and out it’s feeling very cohesive. Love it :)
  6. SPEC
    SPEC
    Love the Nerf bar.
    Atwater Mike, loudbang and dumprat like this.
  7. Runnin shine
    Runnin shine
  8. dumprat
    dumprat
    from b.c.
    I need a dark and stormy night to fire up the propane burner. It's hot work and it should scare the hell outta the neighbors!
    loudbang, Six Ball and Tim like this.
  9. Six Ball
    Six Ball
    from Nevada
    Damn! That must be what's holding me back, no neighbors to scare. :(
  10. dumprat
    dumprat
    from b.c.
    64358093985__8274B618-343B-45AA-8A18-66CC85FF9E2B.jpg 64359110256__D733BFF5-43F6-4CA9-BFC4-29789329BECA.jpg Crack g to get the truck done before the end of June! Got the seats figured enough to get them to my buddy to s***ch the leather on. Most of the wiring done. Hit a snag with the windows, have to move the latches out 3/8" to clear the gl***. Boo.
    bchctybob, Okie Pete, Stogy and 7 others like this.
  11. Thats what I was wondering if going to have to do mine...
  12. dumprat
    dumprat
    from b.c.
    God news is with the latch mount plate flush with the area where the old lock cylinder screw hole is the window clears the latch inside, barely. I cut the fuzzy in two pieces and am going to run a strip of plastic between the two chunks of fuzzy over the back of the latch. Not exactly perfect but should work well enough.
    Stogy, Six Ball and loudbang like this.
  13. guitarguy
    guitarguy
    The seats look good.
  14. dumprat
    dumprat
    from b.c.
    The seats are pretty hard and firm but I think they should soften a bit with about 1/2" of low density foam under the leather.
    guitarguy, Six Ball and loudbang like this.
  15. Runnin shine
    Runnin shine
    This latch issue is exactly why your paint decisions will pay dividends again and again.
    Tim, Stogy and dumprat like this.
  16. dumprat
    dumprat
    from b.c.
    Exactly! The whole truck needs gone over with a sanding block and some spot putty. The more I look the more "spots" I find. At this point I don't care I just want to drive it. I will touch up the paint as I can.
    Stogy, brEad, guitarguy and 4 others like this.
  17. dumprat
    dumprat
    from b.c.
  18. Duke
    Duke
    Getting really close to driving!
    Stogy and loudbang like this.
  19. dumprat
    dumprat
    from b.c.
    Yup. Needs clutch linkage finished, starter wire hooked up. Gauges wired, gl*** installed and door latches rewelded.
    Hitting it hard tomorrow
    Tim, Stogy, loudbang and 2 others like this.
  20. Six Ball
    Six Ball
    from Nevada
    I really like the wiring. That is what I have for the roadster. I'm looking forward to getting that far and putting a neat system together.
  21. Jethro
    Jethro
    Is that a commercial harness or did you cobble it together. Nice work! Is that black monofilament for tying flies?
    Six Ball, loudbang and Stogy like this.
  22. dumprat
    dumprat
    from b.c.
    I bought a used 32 Vintique harness and cut it all apart. The wrapping is special wax coated string for finishing ropes on yachts.
    bchctybob, Six Ball, loudbang and 3 others like this.
  23. guitarguy
    guitarguy
    I need to learn how to do that come time to build my harness.
    Six Ball likes this.
  24. dumprat
    dumprat
    from b.c.
    It's easy.
    loudbang and Six Ball like this.
  25. Runnin shine
    Runnin shine
    In case none of these other dudes are in touch with their feminine side I’ll go ahead and say it “ that little truck of yours sure is cute” “and the wiring is so nice and pretty” “looks cl***ier than a designer handbag” “is that upholstery leather Louis V?”
    brEad, trevorsworth, Six Ball and 2 others like this.
  26. Tim
    Tim
    from KCMO
    Looking good man
  27. dumprat
    dumprat
    from b.c.
    Fired it up Today! Had a bad condenser, cracked cap and burned points in the Mallory distributor but I got it sorted. Makes 60 lbs of oil pressure max and 45 at idle with it boiling over from running it with the timing out of whack. I had to clock the plug wires and **** with it a bit but with even a little thing it makes 17" of vacuum at idle. Damn near perfect in my books.
    I still need to spend some more time adjusting the pushrods. It has a loud lifter sound. Small block dodge lifters are cheap though.
    Yee haw!
    Toms Dogs, MBog, bchctybob and 8 others like this.
  28. Tim
    Tim
    from KCMO
    **** yes!!!
    kidcampbell71 and dumprat like this.
  29. Runnin shine
    Runnin shine
    Videos “or it didn’t happen”.
    Tim likes this.
  30. What did you end up doing? I just got my smoked gl*** today and the latch is playing havoc..
    Also the door handle stem will also be in the way.. Have you test fitted the handle yet?
