Technical Help ID'ing front axle and brakes on old Survivor Hot Rod
Discussion in 'Traditional Hot Rods' started by jonnycola, May 18, 2021.
  1. jonnycola
    jonnycola
    I picked up this 1928 Chevrolet cabriolet a few weeks back. I'm having a hell of a time figuring out what all the front end consists of. What do you guys think? I would ***ume that the whole front axle, spindles and brakes would be pulled from the same car but who knows? It's 5x4-1/2 bolt pattern and uses wheel bolts rather than studs which makes me think mopar? But i cant find a mopar backing plate that matches mine.
    what do you guys think?
    183762686_10222885989970408_4321314545705282390_n.jpg 184486556_10222885988930382_760062123033978386_n.jpg 184647828_10222885990450420_8277574657681715930_n.jpg 186503309_10222885989610399_6115366041409660693_n.jpg 186546366_10222887091197938_2637944229499790551_n (1).jpg 186468641_10222864927963871_9018719510042000136_n.jpg
    chryslerfan55 and kidcampbell71 like this.
  2. Hudson also used the lug bolts instead of studs/nuts. I remember working on a '37 Hudson Terraplane years ago. My first thought looking at it was that the rear end and brake drums looked the same or nearly the same as similar vintage Mopar.
    chryslerfan55 and jonnycola like this.
  3. 1971BB427
    1971BB427
    from Oregon
    If you'd take a picture of the whole axle it would help ID the axle. Tough to say which maker it is just showing the ends at the backing plate.
    jonnycola likes this.
  4. Mr48chev
  5. Nick Nadol
    Nick Nadol
    Very nice ride!
  6. stillrunners
    stillrunners
    from dallas
    With Mr48 Chevy - drum is a Mopar - can't be sure of the axel - looks kinda like a mishmash of parts like they did back in the day. Nice rare Cabriolet there.
    jonnycola and kidcampbell71 like this.
  7. jonnycola
    jonnycola
    its in the cl***ifieds right now!
  8. jonnycola
    jonnycola
  9. roddering
    roddering
    from Arizona
    Looks like an old Chevy with 49-54 spindles
    Budget36 likes this.
  10. KevKo
    KevKo
    from Motown
    The axle is definitely from parallel leaf vehicle. I thought 49-54 Chevy had bolt-on steering arms? Those spindles look Ford to me, maybe 46/7 pickup? I'm not familiar with any Mopar stuff. Another possibility is mid-60's Chevy, Ford or Dodge cabover pickups and vans.
    chryslerfan55 and irishsteve like this.
  11. sdroadster
    sdroadster
    Maybe if you ran the numbers on the wheel bearings, it would give a clue.
  12. Mr48chev
    I'd have to say that someone figured out that a Mopar axle would bolt up under the Chevy without much trouble and give hydraulic brakes and act as a dropped axle in the process.
  13. wheeldog57
    wheeldog57
    The brakes look alot like the ones on a 56 Dodge truck I am working on
  14. Mr48chev
    Yep Lockheed brakes, Mopars ran them for years on end (23) Vintage Mopar Lockheed Brakes. Typical Issues. - YouTube
    When I was in high school auto mechanics cl***es between 1962 and 65 My instructor for the first two years had been a mechanic in Chrysler and Dodge dealerships before he started teaching. He did have a college degree in auto mechanics though. His ***ociation with The local mopar dealer caused a lot of the older Mopars in the area to end up at the high school auto shop to be worked on and I got pretty good at working on those brakes.
    We also had a cutaway ch***is (that I still had in the shop when I taught) that was made out of a 36 Dodge ch***is complete with the drive train being belt driven with an electric motor. Students in the cl*** a few years ago spent a lot of time cutting that rig apart including cutting pie sections out of a front and rear brake drum, cutting the head in two, cutting part of the block and the side of the pan away and doing the same with the transmission and rear end. It was real handy as a teaching aid and the physical science teacher would bring his cl*** out to show them how a four cycle engine worked.
  15. roddering
    roddering
    from Arizona
  16. roddering
    roddering
    from Arizona
