Technical 32 5w chop styles
Discussion in 'Traditional Hot Rods' started by Gearhead79, May 19, 2021.
  1. Gearhead79
    Gearhead79
    Hello all, I’m looking into chopping my 32 Ford 5w somewhere around 4” possibly more up front for a slight wedge chop but see there’s 3 different common ways to approach this.
    1. The roof stretch
    2. Leaning back the entire windshield
    3. No stretch or lean back but pie cutting the A pillars to meet the top. ( this is the one I’m leaning more towards)
    I’d like to hear all the pros and cons of all , any experience on , what’s is the most traditional and relatively easiest to accomplish if possible. I’ve done other chops in the past but this will be my first deuce. I’m confident with my Tig/Mig and fab skills.
    Any photos will be more than appreciated!
    Thanks
    panhead_pete likes this.
  2. alchemy
    alchemy
    Back I need the olden days it seems most were chopped by stretching, with an even chop front and back. I can't remember seeing any pics with slanted posts like is more common on a 34. But nowadays slanting the posts is more common, and giving a slight wedge is common too.
    I can't say I understand what you mean by your #3 method. You'll have to show pics to explain that one to me.
  3. panhead_pete
    panhead_pete
    Are 2 and 3 the same thing?
  4. Gearhead79
    Gearhead79
    I don’t have any photos but from what I understand both post get pie cuts in the center to meet each other. Top becomes wider and bottom becomes narrower . I think this method works more on mild chops as the more you chop the more the stagger gets.
  5. Gearhead79
    Gearhead79
    I think for 2 the whole windshield gets layed back. A cut is made at the bottom of the windshield aft of the cowl and pushed back . 3 is more of relief /Pie cuts on the pillars to meet top and bottom . The cowl is undisturbed.
  6. AULIZ
    AULIZ
    I don´t remember how much I chopped 15y ago this 1932 5w. I slanted very littlerA-pillars after upper hinge.
    I like, if 5w coupe quarter window is after chopped more long than high.
    You find more chop rod oulu.JPG rod-7.jpg rod-14.jpg pics in my website: www.auliz.fi
    Aulis
  7. My coupe 3 inches from stock stretched the roof and doors. 291A5A25-7F4D-4060-B6C1-7D91F133625C.jpeg
  8. alchemy
    alchemy
    1975 (probably hotrodded 20 years prior to this)
    This coupe was chopped a lifetime ago. It is currently gettin a little tuneup, but the chop is staying the same. It's cut about 5.5" straight down. Required splitting the top over the doors and the quarter windows.
  9. threeimpalas
    threeimpalas
    Hurry up with that "tuneup". We'd like to see it on the street!
    tdog likes this.
  10. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    When I had my 5 window chopped we cut the front 3.5 inches and the back 3 1/8th inches. Leaned the front posts. Looked good.
    Gearhead79 likes this.
  11. harpo1313
    harpo1313
    from wareham,ma
    51box, alfin32, swifty and 2 others like this.
  12. chop&drop
    chop&drop
    I cut this one 4”. Laid the posts back. Required significant work on the forward upper door. Also moved the lower rear quarter of the quarter windows forward about 3/8”-1/2”. C5F03A47-6A2A-410C-912A-60090BF0BDF8.jpeg
    Xman, Bcap55, akoutlaw and 12 others like this.
  13. x77matt
    x77matt
    Good idea for a thread!
    Desoto291Hemi likes this.
  14. tdog
    tdog
    from Omaha, NE
    That body is amazing !
  15. rotten ron
    rotten ron
    Great Chop
  16. A23
    A23
    from Hollywood
    That '32 5w looks really good... I mean really good.
  17. clem
    clem
    harpo1313 likes this.
  18. clem
    clem
  19. harpo1313
    harpo1313
    from wareham,ma
    My bad Clem , and you are correct , the channel was five , the chop three and a half.
    clem likes this.
  20. Fitnessguy
    Fitnessguy
    Check out YouTube series by Mad Fabricators. Whole series of videos on chopping a 3 window by Bobby Walden. All the same principles will apply to what you’re wanting to do. Been watching them and his approach and thought process is perfect in my opinion.
    Joe Blow, clem and alfin32 like this.
  21. daveh1932
    daveh1932
    from UK
    I shared this on another thread, it’s by U.K. hot Rodder Dave Haskell and he has used your option 3 which turned out really well. Worth a watch if you can understand the London accent :)
  22. Johnny99
    Johnny99
    Poke around on here a bit. The Steadfast guys have it going on!
  23. 51 mercules
    51 mercules
    Here's 32 my friend drug home. Can't find a completed pic right now! [​IMG][​IMG]
  24. 51 mercules
    51 mercules
    Here we go! [​IMG]
    tr_rodder, PONTNAK123, swifty and 2 others like this.
  25. alfin32
    alfin32
    from Essex, Ma.
    42F2648C-DCCD-45EE-8CEF-FA969FF47C7E.jpeg C6559ABD-F9ED-454C-829C-4B6399945C0A.jpeg 4.5”, leaned the posts back, no stretch.
    luckylou, Bcap55, PONTNAK123 and 13 others like this.
  26. Ruby32
    Ruby32
    One thing to me that gets over looked sometimes is the stance of the car. A car has to have the right stance to go with the chop whatever you choose. Example you see some cars that sit to high to be chopped as hard as they are. Just my 2 cents consider all the factors before you decide on the chop.
    Clutch101, Just Gary and clem like this.
  27. CrazyDaddy
    CrazyDaddy
    from Austin TX
    This chop is perfect !
  28. rotten ron
    rotten ron
  29. Budweiser
    Budweiser
    from california
    Here’s my 32 five window I’ve started to chop. I took out four inches all the way around. Moved the top roof and inch to meet the pillars. My First chop , the body isn’t that great so decided to go all out and chop it up. It probably won’t get a paint job in my lifetime way too much metal work needed for that. 5014F460-0A56-476A-94CB-E252EEC65C32.jpeg
