Technical Brake light switch failure
Discussion in 'The Hokey Ass Message Board' started by OhioRiv, May 21, 2021.
  1. OhioRiv
    OhioRiv
    Hey. This the brake light switch in my '32. Simple, two wire switch. Not much to go bad, but I need to replace it about once per year. Tail lights have two bulbs, one bright, and turn signals and hazards still function. Is there something that could be causing this to fail so often? Thank you for any advice. 20210521_140312.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
  2. alchemy
    alchemy
    Those hydraulic things have been fizzing out for decades. Change to a lever switch style.
    warbird1, Bandit Billy, egads and 4 others like this.
  3. Slopok
    Slopok
    I have heard that you can purchase better quality ones from Harley Davidson dealers.
  4. Model A Gomez
    Model A Gomez
    I've ran that switch on several cars including the coupe I just finished and they are a problem. The old switches would last for years but the newer ones are basically junk, my 60 T-Bird used the same style switch and they usually lasted a couple of years.
    stillrunners and Truck64 like this.
  5. Happydaze
    Happydaze
    Or replace with a Harley D item. Mine has been working satisfactorily for years now. The beauty of this is save for the need to swap out the electrical terminals ( hardly a great chore) its a like for like swap / fix.
    Chris
    Sent from my SM-T515 using The H.A.M.B. mobile app
  6. Hotrodmyk
    Hotrodmyk
    Okay, just went through this with my friend's '38 Willys PU. Other friends never have an issue. The only difference is that his switch is mounted down ( contacts on the bottom). Others talked to have theirs mounted up. Is it possible that fluid leaks into contacts somehow? Don't know, just spitballin' here.
    stillrunners and Bandit Billy like this.
  7. OhioRiv
    OhioRiv
    Funny you should say that, my Harley used the same type. Thank you.
    Bandit Billy likes this.
  8. OhioRiv
    OhioRiv
    Mine is straight up, but thank you.
    Hotrodmyk likes this.
  9. jaracer
    jaracer
    When I first got my 57 many years ago, I went through a couple of brake light switches. They would last about a year. I stopped at a Mustang parts store and they were touting improved brake light switches. That was bout 20 years ago and it is still working. I'm pretty sure it was Mustang of Chicago. https://www.mustangofchicago.com/
    OhioRiv likes this.
  10. OhioRiv
    OhioRiv
    Lever switch broke and this was it's replacement. Maybe need to rethink that.
  11. Slopok
    Slopok
    Not funny, they are better quality.
    OhioRiv likes this.
  12. OhioRiv
    OhioRiv
    The theme I'm seeing is that these switches are ****. Thank you all. I appreciate your time and experience. (A mechanic I'm not).
  13. Slopok
    Slopok
    Just try the Harley one first.
  14. DDDenny
    Public service announcement:
    Two things you can depend on being junk are hydraulic brake light switches.........................
    And ANYTHING The Hoffman Group sells.
  15. alchemy
    alchemy
  16. OhioRiv
    OhioRiv
    Thank you all. I appreciate it.
  17. squirrel
    If the contacts are up, then water could get into the switch area and contaminate the contacts. If they're down, it would less likely to collect in the switch.
    The brake fluid is under quite a lot of pressure, when you push the brake pedal. I doubt the tiny tug of gravity would make it leak...
  18. 325w
    325w
    Any special Harley parts number?
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Maybe not your need but i use a RF brake switch... on all my cars and never a failure.
    cpd682 likes this.
  20. manyolcars
    manyolcars
    what does RF stand for?
  21. Murphy32
    Murphy32
    from Minnesota
    Radio frequency (wireless) ?
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Ron Francis.
    egads and Murphy32 like this.
  23. Truck64
    Truck64
    from Ioway
    It's not just a theme, it's a complete production series of ****ola and getting worse. As a general rule with things like electrical parts, switches, any ignition parts, regulators &c you always want genuine NOS or old school NORS. Common starter solenoid relays and switches and all those parts will maybe look OK, they look the same but, basically if it costs $3 and they have it on the shelf right now, you probably don't want it. A parts manual (so you can search the part #) will get you looking in the right places online.
  24. Doublepumper
    Doublepumper
    from WA-OR, USA
    "Any special Harley parts number?"
    72023-51 is a Harley switch number. There may be a superseded number but this will work.
  25. I’ll bet you $5.00 that Harley switch is made in China now! They are ******* me off.
    The best thing to do with That style switch to throw it away. The second best thing to do is mounted in a place where are you can change it without losing any brake fluid. Consider it a consumable item when you change your fuel filter change your brake light switch
    Hotrodmyk and warbird1 like this.
  26. krylon32
    krylon32
    from Nebraska
    I have 72023-1 for the Harley switch? It's a low pressure switch that's supposed to be good with DOT5?
  27. Jmountainjr
    Jmountainjr
    Member 100% Matt sells a brake switch that has the brake fluid separated from the switch so switch can be replaced if needed without opening up the fluid circuit. You can contact him for more info. He is in CT and sells them through Millworks in MA.
    Jeff Norwell likes this.
  28. ramblin dan
    ramblin dan
    Got rid of my in line stock switch about twenty years ago when it would only come on when I was at a dead stop and was almost rear ended. Made a bracket and put a mid eighties Chevette electric switch and been working perfect ever since.
  29. pprather
    pprather
    The Harley guys seem to recommend Accel #181101
  30. Bandit Billy
    Bandit Billy
    I used the HD switch in my 34, been working fine for 3 years. But I used a lever style switch on the PU I am building because of these posts.
    Hotrodmyk and TrailerTrashToo like this.
