Projects Model A Coupe to highboy
Discussion in 'Traditional Hot Rods' started by panhead_pete, May 19, 2021.
  1. 97
    97
    Sorry that was a balls up, I meant to say machine the axle or space the wishbone jaw...... you machine it off the A axle to fit the later wishbone ...but that is for the major build when you drop the A axle and fit a V8 and 32 K member and/or change gearboxes (the wishbone ball is mounted on the Model A gearbox housing , 32 up its on the ch***is/X member and the wishbone is way longer .... helps with sump clearance etc for a V8)
    You will be keeping the A wishbone and using a 32-36 axle so you just need a couple of 1/4 inch spacers. I was rushing and not thinking clearly , mixing up two different scenarios. Its 1.30 am here I should be asleep.
    Stogy and continentaljohn like this.
  2. panhead_pete
    panhead_pete
    All good mate, Im tired too so just wanted to check. Appreciate the help.
    Stogy likes this.
  3. 97
    97
    Sure
    OzMerc39, 30tudor, Hotrodmyk and 7 others like this.
  4. Blues4U
    Blues4U
    from So Cal
    Thank you!
    Stogy and Joe Blow like this.
  5. Blues4U
    Blues4U
    from So Cal
    Awesome videos! Thanks!
  6. A Boner
    A Boner
    Too nice to hack. Store the spare tire and bumpers in your garage...do the dropped axle and big/little blackwalls, keep the mechanical brakes if you can keep them adjusted properly. Keep the quail...drive it!
    winduptoy likes this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    This thread is what I like about hot rods, every reply is right for the guy posting and no one is wrong, we all have a different idea of what looks great. looking forward to seeing what you do with your car. HRP
  8. HOTRODPRIMER
    HOTRODPRIMER
    Ricky Bobbys rod shop did the transformation The car was a really nice no rust ever car no patches or filler Brand new build on a 49 flatty with a T5 to back it up cruises at 75 no issues electric fan and aluminum radiator 40 Lincoln brakes and rear So cal shocks and beam 32 Ford Wires with all new Coker tires 39 ford column with banjo steering wheel 32 deluxe grille shell with 32 commercial lights.
    Ricky Bobby's Rod Shop FB
    That's all the information I have. HRP
    panhead_pete and Nicholas Coe like this.
  9. panhead_pete
    panhead_pete
    Stogy likes this.
  10. Stogy
    Stogy
    And you also have those traditional Splash Aprons
    I know this is a Deuce but I thought of this with your period look and why would Pete be thinking Fenders Off...
    Hang em in the Garage for a blast...Go for it
    Lou Bingham and his Coupe But I believe you're thinking late 30s early 40s...and a Sport Coupe comes to mind...
    Your Coupe has already been Hopped...to some degree to boot...
    panhead_pete and Joe Blow like this.
  11. Stogy
    Stogy
    :rolleyes:...A little Inspiration
  12. mrquickwhip
    mrquickwhip
    Sometimes I wish there was a really really like option
  13. panhead_pete
    panhead_pete
    Perfect, thanks Stogy! Do you know who's car that it?
    Stogy likes this.
  14. Stogy
    Stogy
    I believe its a Hambers across the pond maybe Sweden perhaps they will chime in...A frames are underrated many times...Can't wait to see what you drum up...I see VHRA on it too...Pendine and Romo
  15. Stogy
    Stogy
    Joe Blow likes this.
  16. Stogy
    Stogy
    Joe Blow and panhead_pete like this.
  17. Stogy
    Stogy
    :rolleyes:...More...
    Credit to Photographers, Owners
  18. panhead_pete
    panhead_pete
    Thanks Stogy, its none of those but loving those pics, especially that B&W one :)
    Stogy likes this.
  19. Stogy
    Stogy
  20. panhead_pete
    panhead_pete
    All those pics of the 6" chops have now got me thinking that way. Either no haircut or a hard chop :) Bummer I cant recall where I saw the pic Im chasing nor where I saved it but most probably on last laptop I threw a beverage all over...
    Stogy likes this.
  21. Joe Blow
    Joe Blow
    Was always a fan of joeyesmen's old coupe.
    Screen Shot 2015-01-24 at 6.32.21 PM.png Screen Shot 2016-04-11 at 3.32.10 PM.png Screen Shot 2016-04-11 at 3.31.40 PM (1).png
  22. luckylou
    luckylou
    from canada
    Thank you..yes very nice cat indeed
    panhead_pete likes this.
  23. Stogy
    Stogy
    brEad, gordspeed, Joe Blow and 2 others like this.
  24. panhead_pete
    panhead_pete
    Cheers Stogy! That Garcia Coupe is legit! I had not seen it before. Thanks!
    Stogy likes this.
  25. Stogy
    Stogy
    Pete there's a video of them chopping it on YouTube...check it out...these fellas are good with the camera on top of Hotrod...;)
    brady1929 likes this.
  26. continentaljohn
    continentaljohn
    Stogy, panhead_pete and Joe Blow like this.
  27. panhead_pete
    panhead_pete
    Wow that car is awesome John!
    Stogy likes this.
  28. panhead_pete
    panhead_pete
    OK Fellas I'm having a bit of a hard time finding some parts I need which can be shipped with the car and a Im starting to run out of time.
    Im hoping to source these near NJ. If anyone can help that would be great.
    Im looking for the following used parts, not new and preferably not repop.
    Headlights - 902C or similar. Commercials etc would work too.
    Set of old headlights stands or a headlight bar etc, a stock obe if I have to I can chop up.
    750-16 and 550-16 Bias tires. Good runable condition. No cracks etc in sidewall.
    33-36 front axle NOT dropped (Have a couple leads on that but if you have one reach out)
    32 Spring Perches (may have found those but let me know if you have some too please).
    Model T rear spring.
    Main leaf from a Model A spring (want a spare in case I stuff mine up when reversing it or a reversed eye spring.
    39 Plymouth tailight ***emblies including buckets. Yep those are HARD to find :)
    Thanks.
    Stogy likes this.
  29. panhead_pete
    panhead_pete
    Quick update. Car gets collected from the seller later this week or next who has been beyond awesome to deal with and really looked after me. Could not ask for a better person to deal with. Same with the guy who sold me the 34. Hope to have it 4 weeks after that.
    I've followed up on a few cars pictured in this thread via PM and would like to thank the members who got back to me and chatted with Chris Garcia from the Bedlam CC who was really helpful about his coupe which is quite an aspirational car for me.
    Im not sure where I will end up with this and wont know what, if anything I will do with the car until it arrives. Priority will be to get it registered here which is not without its hurdles and will most like include having to fit turn signals which I have on the way. Initially its most likely will just enjoy it as is for quite some time.
    That being said I have sourced Guide headlights, Okie Joe drilled 33-36 Axle, 32 Perches, T spring, 750 and 550 Firestones plus a raft of service items including brake floaters which will get fitted pretty quickly. Not sure when if at all they would be fitted but it snows here so have a winter to keep entertianed after snowboarding. :)
    Thanks again for all the help and advice so far.
    brEad and Stogy like this.
  30. Stovebolt
    Stovebolt
    Pete,
    I purchased this coupe after seeing it advertised on the HAMB - it has a stock 34 axle with a reversed eye and flatened front spring, 32 spindles and brakes.
    It also has a T rear spring. It measures a 5" lowering. The 18" 32 wires measure 29.5" tall - same as the original tyre diameter.
    Its no hiboy, however. I post this picture to show what can be done with the clever use of stock parts.
