Technical you know when you fit the bear claw latches
Discussion in 'The Hokey Ass Message Board' started by nobby, May 19, 2021.
  1. nobby
    nobby
    do you still keep the locating wedge - or is it no longer required.
    has anyone 'just' done one on a 35-40 and still have the door cards off
    mini or the big ones
    is it worth getting the pre-fabbled plates
    shirley you dont 'just' bolt the pin to the thin b-pillar ?
    thanks
  2. rockable
    rockable
    No, you don't need the dove tails any more. I use the medium size rotary latches and hardware from Carolina Custom Hot Rod Parts. I like to use the prefabbed pieces because it looks neater and save time on the install. Yes, you weld the plate into the B pillar and that is quite adequate.
    Its going to take more time than you think, if you do it right. I just posted some pictures of my new install on my 34 Ford. (Link below)
  3. Bandit Billy
    Bandit Billy
    I like the look of the dove tails personally so I retain them and reinforce them (on my roadster).
    Oh, and don't call me Shirley!
    Hnstray and Desoto291Hemi like this.
  4. Mr48chev
    The striker pin acts as the locater with the bear claws latches.
    The threaded plate spreads out the contact area to hold the pin solid and hold the door solid but also covers the larger hole in the pillar that allows you to adjust the pin. I don't think too many of us are that perfect at drilling a hole exactly where the pin needs to go for everything to line up right with no adjustment.
    Hnstray likes this.
  5. nobby
    nobby
    do you mean this si a movable threaded bung that can be positioned than tightened for te pin?
    Hnstray likes this.
  6. nobby
    nobby
    where do you get these? - -ahh these are carolina with the nice pressed recess, looks factory
    so i need the ones with two levers - one for door pull and one for door handle?
    so now i nsimply need to spend three weeks getting the doors no not droop
    Hnstray likes this.
  7. 38Chevy454
    38Chevy454
    The bear claw latches center with the latch, as stated. There is more to it, but that is your simple answer.
    There's too much to type on my phone. Send me a PM if interested in my latches. See signature below.
    Sent from my SM-A102U using The H.A.M.B. mobile app
  8. CyaNide
    CyaNide
    from Texas
    Bear claw latches are cheap Chinese BS. I have had them on my shoebox and they ****. You hit a bump or lean on the door and they will come open. I replaced mine with hotrodlatches.com. He is a member here and are made in the USA. Check out his website.
    CN
    anothercarguy and Ned Ludd like this.
  9. Fortunateson
    Fortunateson
    This should be interesting but who is Shirley?
  10. da34guy
    da34guy
    Lavern's buddy
    bowlingball likes this.
  11. Ned Ludd
    Ned Ludd
    Bear Claw is a trademark of the dreaded Hoffman Group. More reputable manufacturers use other terms, notably bear jaw.
  12. Ned Ludd
    Ned Ludd
  13. hemihotrod66
    hemihotrod66
    Mine are the ones Ford made.. Works fine...
  14. alchemy
    alchemy
    I put the double-jaw style bear jaw latches in a '40 tudor about 35 years ago. I left the stock dovetails. Can't hurt to have them in place. Hopefully your doors align correctly and the dovetails aren't needed to shove the door into place.
    Hnstray likes this.
  15. nobby
    nobby
    so i thought, hmm what I will do is - because you can get them in right and left hand drive...so they have key barrels in either side.... is buy two fiat 500 door handles, left hand drive and right hand drive -drivers side..
    kind of look like 38/9 handles, IF a smidge bigger, be simple to do, make the barrells the same
    the beauty being because the hinges snap on them all the time, they are ten a penny replacements.
    NOT SO
    the lock moves that little rod down to lock the electronic door lock, not mechanical.
    so anyway
    even if you fit a double click pincer latch into a non locking 35-40 door and use the stock handle
    it won't be able to lock anyway!!
    ffs, what a ball ache......
    yes, something about not being able to use an early style of door handle that can act like a forward facing hook and catch a childs satchel strap or something
    For Fiat 500 Outer Door Handle Chrome Offside (OS) 735592012 735592026 UK | eBay
    i'm glad the handles are only £5.99
    or $8.50 delivered
    so its simply something to think about, which is
    you don't need 'remote' key fobbed central locking
    merely mechanical central locking -actuated from turning the key in the drivers lock
    so why is there not a slender double click pincer latch that has a solenoid in it that pulls and pushes a pin on the non drivers side latch
    i.e. there be no key barrel in the p***enger lock
    put key in drivers lock and turn
    flicks a switch and both door latches for slender doors, lock and unlock, to enable the rod from the handle to function
    someting like that.
    or
    how would you do it.
    Ned Ludd likes this.
  16. fabricator john
    fabricator john
    from venice fl.
    if you decide to make up your own "latch kit" make sure the latch comes over the top of the striker , and the get rod repair plastic clips in the "help parts" at your local oil store , then regular rod may be bent to work for linkage , biggest problen ive seen also has been people make the linkage too tight and pops the latches or using door handle stuff that arent sprung to return ,,, ok so now a TOP SECRET part for the inside door handle because im a giver ,, 56-64 vw beetle inside door handle mechanisms in repro they are damn near flat are sprung are left and right and are the same spline as gm as long as you use set screw handles (can i say billet style here?) and are usually about 10 bux a piece from all the vw repop houses ,, rember you want enough swing in the linkage to were the handle swings as it did stock or roughly as it did , keeps em from poppin when ya dont want em to and the handle must be sprung or put a return spring on the pull rod somehow ,,
    fabricator john
    miss you dad
    rdscotty and Hnstray like this.
  17. nobby
    nobby
    ahh, I had not even considered the inner door release needed to be spring loaded
    I can't understand why they cannot make these things so they can be locked and unlocked.
    pretty **** really
    I mean, IF you used the original non locking door handle from a 39
    remove the original inside sliding locking latch - i locks
    fit one of these and it don't
    the stock fiat 500 door actuator isn't too big
    this is the side that has no barrel - just a handle rod to open
    so there is a motor inside it that engages the lever to open
    thats the drivers side - lock presses on blue fitting to release the lock mechanism to enable the rods to pull the latch open
    /\ that wont fit in a 39 truck door?
    if it did, would it be a simple matter of giving it 12 volts - no computer controlled remote central locking
    merely when the blue lever is actuated by the rod from the key/barrel it switches the latch enable, when in the other position, doesn't
    /\ note the red one has a slot so it can't ever be accidentally opened
    so the whirring sound in your central locking is simply a little motor with a worm gear moving a pin across to engage the other lever so you can open the door.
  18. nobby
    nobby
    winner
    smart car 450
    1998 - 2007
