Hot Rods A New England Channeled Roadster
Discussion in 'The Hokey Ass Message Board' started by 51box, Aug 28, 2020.
  1. Mr48chev
    Wow You nailed it, straight out of the little East Coast rod books. here is the early 50's box brownie version. Channeled 32 roadster (4).jpeg
  2. 51box
    51box
    from MA
    Decided to take a short break from the metal work and build a seat for the roadster. I used 3/4” ply with some T nuts glued into the wood for mounting. 59FF5A6E-48C8-4A62-95E2-7A7EDD1BD35F.jpeg
    Built a simple bolt in frame to help stiffen the body and mount the seat back to.
    Used some T nuts also to mount the seat bottoms to the floor bracing. Then cut out some windows and added webbing to finish them out. All of the wedge for the seat bottom will be shaped in foam.
  3. 51box
    51box
    from MA
    Here’s how I did the seat foam. First I take some measurements and how much lean back I have in the seat of my truck. I drive 90 miles a day just to and from work so I know it’s comfortable in that setting. Make some cardboard templates and trace it onto the 6” thick foam. 6533B2D1-AF6D-4DB4-8F9B-5EB7219277A3.jpeg
    I used 53lb foam for the seat bottom and 35lb foam for the back rest. To do it this way you must use good glue, I use Weldwood Landau contact adhesive. Cut out the pieces with a foam saw or band saw and glue together.
    Here’s a side shot showing how much support there is under the legs.
    This has more wedge to the seat bottom then my daily driver truck but it’s needed because when you sit lower your legs rise up also.
  4. AHotRod
    AHotRod
    Most excellent seat design
    Stogy, 51box and loudbang like this.
  5. Nice job on the seat. Where do you buy the webbing?
  6. 51box
    51box
    from MA
    Thank you
    Stogy, AHotRod and loudbang like this.
  7. 51box
    51box
    from MA
    Thanks, I buy most of my upholstery stuff from Albrights supply
  8. 51box
    51box
    from MA
    I bought this speedometer and Tach from the Hamb cl***ifieds a while ago now because they were clean and a great price. My plan was to open them up and paint the needles white so they would match the other gauges.
    Instead of trying to get the chrome bezels off and risk damaging them, I used a pipe cutter down near the back and cut through the body itself. This allowed me to paint the needles and then just used a little bit of epoxy and glued it back together.
    It worked out great and I wouldn’t hesitate to do it again! With those situated, the dash was laid out and drilled. There’s more to come with it but it was great to see it start to take shape.
    29EHV8, chryslerfan55, Stogy and 8 others like this.
  9. pprather
    pprather
    I was cringing at taking a pipe cutter to vintage gauges, but they turned out great!
    I may try that on a vacuum gauge that I have been trying to get apart.
    Stogy, loudbang and 51box like this.
  10. 51box
    51box
    from MA
    It was a bit of a gamble but I figured there was no way I’d get the bezel off and on without distorting it or damaging the chrome.
    Stogy, loudbang and pprather like this.
  11. vtwhead
    vtwhead
    You driving that around yet??:rolleyes:
    Stogy and loudbang like this.
  12. scoop that seat base foam, you need a leg bolster to keep you from sliding forward. Doesn't need much, your legs and back will than you.
  13. 51box
    51box
    from MA
    I did add some foam around the horse shoe but it has enough wedge and lean back that you feel pretty planted in the seat as is.
    I started by patterning and doing the upholstery on the seat bottoms first.
    Once those are bolted in, I then match mark the seat back foam to the base so I know the pattern will line up. This seat back was pretty complicated to sew together, although it’s far from perfect I learned a lot doing it and think it looks really neat.
    My gas tank finally came in and have been working on building a structure to mount it. Some more updates soon.
  14. 51box
    51box
    from MA
    give me at least another year!
  15. Tim
    Tim
    from KCMO
    Looks fantastic so far
    Stogy and 51box like this.
  16. loudbang
    Seat look very well done. :)
    Stogy, catdad49, TFoch and 1 other person like this.
  17. vtwhead
    vtwhead
    Your a quick learner on that upholstery deal! That seat came out very nice!
  18. COCONUTS
    COCONUTS
    My wife has been on my tail to get rid of my running and driving Caddy so I give it to my buddy and what happens!!!! He pulls the engine and brings it back to my driveway. Boy, wait until my wife comes back from working at the truck stop diner for the past 12 hours and see it. Just joking, looks good so far.
  19. 51box
    51box
    from MA
    Also got my switches installed on the dash with these neat chrome cabinet knobs that are a dead ringer for 49 Ford knobs but only about $5 each 60218947-D01E-43F4-B000-ED1BAF1A7AE7.jpeg
  20. 51box
    51box
    from MA
    Here they are next to each other, original 49 Ford on the left 7EE85401-9D0F-4F9A-9560-4A2E89767FC5.jpeg
    chryslerfan55, Tim, alanp561 and 9 others like this.
  21. pprather
    pprather
    Can you give us info on the cabinet knob?
    Looks like a dead ringer for 1949.
    Thanks.
    loudbang and Stogy like this.
  22. 51box
    51box
    from MA
    If you punch in Top Knobs 7/8 chrome on eBay it will come up.
  23. loudbang
    That is an amazing find, they look perfect. :)
  24. 51box
    51box
    from MA
    I had found that original one at a swap meet probably 5 years ago but didn’t know what it was from. After some searching and seeing how much nice ones go for, the hunt for an alternative turned these up. Also they are solid br*** so have a nice heavy feel to them and the threaded hole is small probably an 6 or 8, so drilling and tapping to fit the switches is no problem.
  25. big john d
    big john d
    from ma
    are the tach and speedo both cable drive?
    Stogy, catdad49 and loudbang like this.
  26. Rand Man
    Rand Man
    Cool cool stuff here.
  27. 51box
    51box
    from MA
    Yes they are both mechanical
  28. 51box
    51box
    from MA
    I have been working on getting the top irons and bows modified to get the look I’m after. The windshield is a 2” chop and is the max I can go and still fit comfortably. So far I have narrowed the middle and rear wood bows 1 3/4” . The top irons are stretched and modified to lower the center bow 1 1/2”.
    The wood header is trimmed and lowered 1/2” over the windshield. I haven’t drilled any holes yet, just moving stuff around and seeing what looks best to me.
  29. 32 hudson
    32 hudson
    The top looks good.
  30. I like the basic back and top profile. Pending on your seat position you may not like the side of the fabric going clear to the Door opening. I've found it sits me back in a cavern making side vision difficult. Found myself leaning way forward to look to the side. I know the mount bracket is in stock location but if I were doing things for looks I'd remove the mount finger and move it back till I could see past the side skirt while I was fully seated and just turning my head. May not be necessary for you pending on where you actually sit and yes it's a lot more work but not that much in the total scope of where you've already been.
    alanp561, Stogy and loudbang like this.
