Technical Stromberg issue...any ideas or help?
Discussion in 'The Hokey Ass Message Board' started by Blue One, May 22, 2021.
  1. Blue One
    Blue One
    from Alberta
    Hey guys,
    I’m experiencing a perplexing issue with the rear carb on my new Stromberg 97s.
    (English Strombergs from Clive and Uncle Max.)
    First it was p***ing fuel dribbling out the top of the accelerator pump felt and dribbling fuel on the throttle blades after shut down.
    I tried lowering the float level and that seemed to help however now when the engine is running the carb at idle is dribbling fuel constantly on the throttle blades.
    The front and middle carbs are not doing this when you look into the carbs at idle the front and middle carbs are working fine and running on the idle circuit.
    The fuel dribbles constantly on the throttle blades of the rear carb at idle and for about 30 seconds after shut down.
    This is not a fuel pressure issue as the other 2 carbs are working fine.
    Any ideas or knowledge to share?
    Kinda ****s because I can’t drive my RPU this way with excess fuel dribbling into the engine from the rear carb.
    Stogy and VANDENPLAS like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. Hollywood-East
    Hollywood-East
    I'd say psi., The Last carb would have the least resistance
  4. Blue One
    Blue One
    from Alberta
    Thanks, but I think there’s something different going on in my case as the main problem isn’t after shut down as much as it is the constant fuel dribbling on the throttle blades at idle.
    The front 2 carbs are functioning perfectly at idle with no excess fuel dribbling onto the throttle blades and don’t do anything after shut down either.
    I have a fuel shut off solenoid that is off when the ignition is off as well.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I bet you have a failing needle and seat. or some dirt in the needle keeping it from sealing.
  6. Blue One
    Blue One
    from Alberta
    Fuel pressure is 1.5 psi with the Aeromotive fuel pressure regulator.
    I can’t see why fuel pressure would cause the carb to dribble excess fuel at idle.
    Stogy and Hollywood-East like this.
  7. Blue One
    Blue One
    from Alberta
    That’s maybe the case although it’s a Grose ball valve type thing.
    Any idea how to fix that other than replacing it?
    Stogy likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    there may be dirt in it, take it out and clean it and try it again
    alchemy, Stogy, Blue One and 2 others like this.
  9. Mr48chev
    This is most likely what you are facing if the float level is correct. The least little bit of dirt or sand or whatnot out out of the tank can keep the needle from sealing. That is where I would look first.
    Stogy, Blue One and Moriarity like this.
  10. Blue One
    Blue One
    from Alberta
    This is what they look like
    Stogy likes this.
  11. tubman
    tubman
    There was a thread about this on "The Ford Barn".. The consensus there was that the "Grose-Jets" are inferior to a traditional needle and seat and should be replaced.
    stillrunners likes this.
  12. Hitchhiker
    Hitchhiker
    Another vote for dirty needle and seat.
    Stogy likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    take it out, spray carb cleaner in thru the little hole, blow it out with compressed air and try it again
  14. carbking
    carbking
    For a test, place a known pressure gauge right where the line goes into the first carb.
    Regulators WITHOUT A BYP*** often run higher than dialed pressure at less than maximum fuel flow.
    As far as only one carb leaking, as others have said, once one carb relieves the pressure, there is no need for the others to leak.
    Jon.
    nunattax, bchctybob, loudbang and 4 others like this.
  15. Blue One
    Blue One
    from Alberta
    Good call thanks for the help fellas.
    There was a tiny sliver of thread peel off trash that would not come out of the valve and was almost invisible despite the fact that I had cleaned it out previously.
    On close examination in the sunlight I could just see it in the tiny hole. A little bit of work and out it came.
    Surprise :D no more problem working perfectly.
    I’m putting the air cleaners back on and going for a drive :cool:
  16. Blue One
    Blue One
    from Alberta
    Did that just to be sure and the pressure is bang on the minimum for the regulator at 1.5 psi.
    No problems at all now. :cool:
    Larry
    bchctybob, loudbang, Tim and 3 others like this.
  17. Bandit Billy
    Bandit Billy
    Glad you got rid of the drip buddy! Those STD's (Stromberg Throttle Disturbances) can be troubling and downright embarr***ing.
  18. Blue One
    Blue One
    from Alberta
    :D Thanks, it’s running really good now.
    Leak free for the first time since I got it running.
    Had a great drive today. :cool:
    2FCBAAA0-F972-4F8F-9453-1FBF3213A2AE.jpeg 3BB01278-245D-445B-B633-EFCA60B92356.jpeg
  19. Blue One
    Blue One
    from Alberta
    I don’t believe that they’re working perfectly and no problem now.
    Clive recommends them and I’ll stick with them.
  20. tubman
    tubman
    I'm glad things worked out for you.
    I guess time will tell.
  21. Bandit Billy
    Bandit Billy
    Clive vs ford barn... Sounds like a lame movie but an easy decision. I put another 50 miles on mine just now. Stopped for dinner. Darn those ****py grose valves!
    Stogy, loudbang and Blue One like this.
  22. mpschunks
    mpschunks
    Well I'm stumped. I'm running 5 97's on my GMC 302 with Howard intake. After many hours adjusting mixture, idle, linkage all runs great...at idle. The issue comes when I am driving. Backing out my steep driveway, accelerates. (Pointed uphill). Pointed downhill and coming to a stop light, dies. Acts as if fuel is sloshing around in the bowls and either gets fuel or loses fuel. And before you ask, yes, I have adjusted all the floats. If anything the fuel level is slightly low. Stromberg says fuel level should be 15/32" below lip. Fuel pressure is set at 2.5lbs just like my 350 with 4 97's which runs perfectly. Driving the GMC there is no problems accelerating, really pulls with no hesitation. Just don't step on the brakes...blupp, blupp, dead. Starts right up again and I'm off! Help.
    Stogy likes this.
  23. Tim
    Tim
    from KCMO
    Stogy likes this.
  24. Blue One
    Blue One
    from Alberta
    Sounds to me like you have a problem with fuel delivery volume.
    It could also be related to the balancing of the carbs.
    Did you get it running at idle with all of the linkages removed and then set up each carb to pull the same amount of vac*** using a Uni syn carb balancer?
    then when each carb is adjusted and idling the same you can hook up the linkage.
    Stogy likes this.
  25. mpschunks
    mpschunks
    Excellent question. Yes I did balance each carb then attached the linkage. I'm running an electric fuel pump that is steady at 2.5psi. brand new fuel filter. Again, it seems to be related to the position of the car. incline, runs smooth, decline or decelerating, dies.
  26. Stogy
    Stogy
    Brand new inline filter with a steel casing by chance? Did you shake it before installing? Perhaps if you have installed it the glue may have by chance given up hold due to age...
    The reason I mention this is I fought a battle with loss of power after starting was fine, runup fine, driving fine, then without warning the problem arises...it ran like it was missing on cylinders minimal power and stalling at idle...but I always made it home...
    :rolleyes:...the 2 pics are my Spectre Inline Chrome Filter cut apart and what I found...:oops:
    Last pic is its replacement...
    I'm not necessarily blaming the company as Spectre is a known brand...I had the filter for quite some time stored packaged inside a climate controlled environment then installed it...after driving it over time...The problems appeared...remember, you can't see the filter and can't shake it when installed...when I took it off and drained it I shook it and it sounded like a kids rattle...:eek:
    I truly believe the filter was being bounced around and lodging itself periodically against the outlet to the fuel pump aided by the pull from the pump and restricting the flow to the carbs...since installation of the Napa under 10 dollar inline there has not been another loss of power incident...
    For the price fuel filters are one of those things that should be changed out every year or couple depending on distance driven or state of tank...
    I'm very fortunate my tank is clean as that was unfiltered fuel for quite some time in my case...:eek:
    So MPS maybe check that filter out...
    Sorry not a Stromberg issue per se but a general across the spectrum whatever carb your running it could be the simplest thing...unscrew drain and shake...;)
    kadillackid and Blue One like this.
