Hot Rods Pontiac powered rod pics and who has one?
Discussion in 'The Hokey Ass Message Board' started by Koz, May 22, 2021.
  1. Koz
    Koz
    I've been obsessed with building my "A" using Pontiac power with the rest being mid 1960's issue stuff. This motor is by no means a numbers matching, era correct piece of perfection, more what I could get my hands on. There have been some really nice Poncho powered rods already, Alex Idzardis' deuce is one that comes to mind.
    Anyone have pics to share and maybe some of the guys that have them can post up. I'm ready to fire mine up on the stand and can't wait to hear it run. I realize there was a thread back in 2008 but a lot has transpired since then.
    A pic or two to get things started.......
    My build thread- https://www.jalopyjournal.com/forum...-vicky-body-a-build-thread-with-pics.1197541/
    My engine on the stand, now completed. The other pic is Idzardis' coupe.
  2. J. A. Miller
    J. A. Miller
    from Central NY
    kidcampbell71, Tim, loudbang and 4 others like this.
  3. 31 B'ville
    31 B'ville
    from SE Pa
    Love the fact that you are using Pontiac power!
    Here’s my long term 1931 Pontiac project with a ‘69 428. B8FE98E5-8B90-4FBE-8A1F-9F5313091C1F.jpeg 450183DD-6740-4D4C-9D29-9AA5DB91F7CC.jpeg
  4. 31hotrodguy
    31hotrodguy
    I dig the ac bracket!!! [emoji1303][emoji41]
  5. Rocky
    Rocky
    Classified Editor
    My 34 uses a '57, 347 bored .125 to 370 cu in. Old Jahns pop-ups with a Lunati cam, 73 GTO cylinder heads, Offy intake with a single AFB [for now...got a dual quad setup for it too] with Muncie 4 speed and Winter's quick change. 34atpark2_11_20.jpg 34 5_20.jpg 370oncart.jpg
  6. Koz
    Koz
    WOW! Very nice coupe there!
  7. jimmy six
    jimmy six
    Me too.
  8. flamedabone
    flamedabone
    I have built a pile of Pontiac powered hot rods. I just finished this one. Just a little blown 389 that makes about 700 horse.
    -Abone.
  9. 347 Pontiac from a 57 GMC pickup in my 28 T modified on a 21TT ch***is IMG-20210322-WA0004.jpeg
    Sent from my moto g(10) using The H.A.M.B. mobile app
  10. Deuces
    Deuces
    31hotrodguy likes this.
  11. swifty
    swifty
    If that's his ac bracket what does his alternator bracket look like?
    kidcampbell71 and 31hotrodguy like this.
  12. Sum54ford
    Sum54ford
    from St. Louis
    343FA112-A52F-4313-9E5C-20112F12982E.jpeg 5F7D11AB-EF8C-440C-AC6F-E337E2F8FC20.jpeg
    I have a buddy that has a 51 Mercury with a built 1957 Pontiac 370 and Muncie 4-speed. He has had the motor in the Merc since the late 50s.
  13. Elcohaulic
    Elcohaulic
    My all time favorite Pontiac is the 389.. I've had the 421, 455 (462), 400, 428, 370, 350 and 326. The 65 or 66 389 is a runner with some good tuning and blocking the intake manifold heat.. Those Long Branch exhaust manifolds are amazing!
  14. Koz
    Koz
    WOW! A load of really nice stuff here. There are monster torque motors and I'm sure it will move the "A" just fine. For the record, the one I'm using is a '66 389 with 9.0 to1 pistons, nice Comp Cams 268 H-10 with Comp valve train and roller rockers. Mallory duel point and box coil, decent heads with a fresh valve job and mild clean up and match port work, a Tripower Inc. aluminum '66 repop mainifold along with the big bore Rochesters milled to 1 3/8" and a pair of NOS street headers. All this is put to the Ford 3.03 with a Ram lightweight flywheel and 3000lb. pressure plate and Ram disc, inside an old blowproof bell. I'm thinking maybe 400 HP and gobs of torque.
    The motor is finished and I'm doing a bit of rework on the ch***is in my spare time. I also have traded my banjo that I was going to use with the 283 for a 31 spline 9". I've narrowed it to 57" and added a Detroit Locker center with 350 gears, a pair of Moser axles and aftermarket brakes. Pretty sure that will take the Poncho no problem.
    Program is messed up on my phone and I can't post pics at the moment but it all looks pretty cool and is ready to go together.
    I am curious as to how hard to cool they are. I'm using a Walker full size '31 radiator and if necessary I could add an oil cooler. Any thoughts on that gentlemen?
  15. wheeltramp brian
    wheeltramp brian
    20210418_133926.jpg 1957 347 bored to 354,10-1 pistons,comp thumper cam.may change cam
  16. Blake 27
    Blake 27
  17. Rocky
    Rocky
    Classified Editor
    "I am curious as to how hard to cool they are. I'm using a Walker full size '31 radiator and if necessary I could add an oil cooler. Any thoughts on that gentlemen?"
    Koz. My first trip a week after I got it on the road was from the Omaha area to Joplin, Mo for the HAMB drags. I had my 2.71 gears in and a 180 thermostat. Going down the ambient temps were in the 80s-90s and the needle stayed on 180-190.
    Coming home I ran into construction on I-70.....about 20-25 miles of it in mid 90s temps. Stop and idle for 2 minutes, creep ahead for 2 minutes. I run a Walker radiator with original 57 Pontiac fan, no shroud and a small coolant tank with a closed system...8 LB cap. The engine temp creeped up to about 195 a few times but with big hood side louvers and a homemade aluminum under-carb heat shield, [walmart cookie sheet, cut down] my car never stalled or ran funny.
    I've got a 160 in it now but I have great luck running no 'stat at all. BTW, even with the late cylinder heads on my 57 engine, I fab'd up a pair of 1/4" thick adapters to keep running the reverse cooling system the early engines came with and no, the br*** or stainless water gusher tubes will not fit in the late heads. Don't need 'em. Photo was taken before I installed the elbow hoses. Alternator bracket is made from s**** and {I think} a 59. 389 adjuster arm with a stiffener welded into it for strength. 370altmount.jpg
  18. I almost have one , 34 chev truck , pontiac ohc 20190313_212206.jpg 20190308_203511.jpg
  19. ROADSTER1927
    ROADSTER1927
    My Wife's 40 Pontiac. 1963 421 Super Duty with a Muncie close ratio 4 speed. 9" ford rear end with a gear drive positraction center section. FABB1BADA1.jpg
  20. Rocky
    Rocky
    Classified Editor
    Mike Zenor from the Chicago area has a ford coupe with 389 Pontiac engine but I haven't seen him post for awhile.
    kidcampbell71 likes this.
  21. 911 steve
    911 steve
    from nebraska
    my friend Bill has a 39 poncho sedan with Pont 350 motor, Pont wire wheels, over 200,000 mi on it, been across country more times than he can count..prestige plate on it "39 goat" 13717462_619057164936071_1849477919142714130_o.jpg
    Deuces and Koz like this.
  22. Koz
    Koz
    The 200K thing is the best! I just love the long haulers.
  23. Koz
    Koz
    While we're yacking, I haven't been able to fire mine yet due to lack of carb parts but I'm working on my brakes right now and contemplating if I'll have enough vacuum to run a power booster. I'm diabetic and have some leg problems that aren't going to improve with age so a booster would be a nice addition. I may have to wait to see what kind of numbers I pull but if anyone has any experience with this cam I'm all ears.
  24. Rocky
    Rocky
    Classified Editor
    Close, Steve. Bill's 39 actually has a late 60s/70s Olds engine in it. Says if it ever gives him trouble, he'll replace it with a Poncho motor.
  25. Boones
    Boones
    from Kent, Wa
    Damn Jeff, this may be the ***iest one you have built. Its PURE hotrod.. an I like the blown pontiac in it
    loudbang and 31 B'ville like this.
  26. Rand Man
    Rand Man
    No pics, but I am a fan. Great engines.
    Koz and 31 B'ville like this.
  27. First roll out of the workshop
    IMG_20210828_124523135_HDR.jpg IMG_20210828_124454135_HDR.jpg IMG_20210828_133830356_HDR.jpg
    Stogy and Deuces like this.
  28. 32Stoker
    32Stoker
    Early stages…
    Shadow Creek, loudbang and Deuces like this.
  29. Anderson
    Anderson
    Built a Brookville '32 with a 350 Pontiac because of the car I'll post 2nd. I had a 389 for it but the block was junk and I found a running 350 to put in it's place. I planned to upgrade later but sold the car.
    This car my dad built and handed down to me a couple years ago. He had been a Pontiac guy for a long time, 2nd car was a '65 2+2. He sold a '67 GTO to finish ths '57 so he put a 455 in it. I've made a lot of changes to the car but it'll always be Pontiac powered. Both of these cars have Muncies.
  30. Speed Gems
    Speed Gems
