Projects 30 Model a tudor build first build ever
Discussion in 'The Hokey Ass Message Board' started by Mechman_22, Dec 29, 2014.
  1. Mechman_22
    Mechman_22
    from Nc
    your damn right they do and I have you to thank your bead work to thank for that, wouldn't be anywhere near where it is today with out everyones help
    moparob likes this.
  2. Tim
    Tim
    from KCMO
    Looking good!
    Mechman_22 likes this.
  3. Mechman_22
    Mechman_22
    from Nc
    still knocking away at it. got the steering somewhat figured out. would have like to keep the steering column and box one piece but that damn starter on the nailhead wasn't having it. so still at it haven't gave up yet almost hit 8years next month boy o boy 109794_jpeg.jpg Screenshot_20210916-212653_Message+.jpg 109822_jpeg.jpg
  4. Mechman_22
    Mechman_22
    from Nc
    Still plugging away at the floors one step closer. The ol lady worked on fitting the flipped firewall feet back on and couple cosmetics while i got some welding done to the rear spring hump and rear wheel wells. Also going to use a vw bus steerjng bracket to hold the f1 steering box.
  5. Tim
    Tim
    from KCMO
  6. Mechman_22
    Mechman_22
    from Nc
    Well haven't updated the build for a while. we have flipped the firewall and welded it back into place. got the front floor welded to the new floor. after working on the floor and fire wall we decided to change it up and knock out so other small stuff that needed to be done. So, the girlfriend made the final version of her taillight mounting brackets using fender mounting holes. i notched the front of the frame to keep the front spring from bottoming out on the frame when i jumped on it and tried to mockup where the f1 shock mounts would go. they need to be heated and bent. by no means winning a race but getting some littles
    don colaps, Just Gary, Tim and 3 others like this.
  7. Mechman_22
    Mechman_22
    from Nc
    well back for more. got couple hours while grilling dinner last night. progress is progress. got the f1 shock mounts heated and bent. also snagged some new shocks. 10.jpg 11.jpg 12.jpg 13.jpg 14.5.jpg
  8. Mechman_22
    Mechman_22
    from Nc
    got a little more done so far. finally got the hole drilled for the steering column. so mocked that up to see how it all worked out. while I was knocking that out the column the better half started to make some mounting brackets for the front pan hard bar.
    Tim and AHotRod like this.
  9. Mechman_22
    Mechman_22
    from Nc
    little more knocked out of the way. I'm running the original fuel tank along with a 15gal tank in the rear so had to make filler neck to be able to fill rear. I wanted to mirror the original fuel filler neck but also not have it come off as a big eye sore with a big fuel cap or door. also got the bracket for the other side of the front pan hard bar knocked out. started on getting the seat brackets made for the sliders just in case the ol lady needs to drive it.
    Tim likes this.
  10. Mechman_22
    Mechman_22
    from Nc
    well still knocking stuff out. Got a couple hours in the garage last night so got the f1 steering box mounted up with 60s era VW bus steering box bracket. I would've like to have it sit a little closer to the fire wall, but with the starter being on the driver side this was the best solution I could come up with. Next up we will mount the seat so I can set up final mounting spot for the column and wheel.
    don colaps, HotRod33 and Tim like this.
  11. Tim
    Tim
    from KCMO
    Now that’s a clever trick! Think I’m finally Caught up on this one :) looking good
  12. Mechman_22
    Mechman_22
    from Nc
    Spent Monday making upper rear shock mounts and getting steering column cut down to size and hooked up to steering box. I need the wheel.to come down just a little more.
    don colaps and Just Gary like this.
  13. HotRod33
    HotRod33
    I like that steering box mount.....
  14. Mechman_22
    Mechman_22
    from Nc
    Pitman arm is done now to cut drag link down and get that on there might have to heat and bend steering hoop but we'll see
    IMG_20230222_200639_733.jpg IMG_20230222_200639_767.jpg IMG_20230222_200639_802.jpg received_181081974628770.jpeg
    Tim, Nailhead Jason and HotRod33 like this.
  15. Mechman_22
    Mechman_22
    from Nc
    Well got some more knocked out. tried using a stock column drop ,but was to much drop so had to fab one up for the amount I needed. Just need to shape it alittle better and it will work. Made an easy bottom column mount aswell. got the pedals heated and moved to allow room for gas pedal. Ordered new carb so will be swapping old 2 barrel out for 4 barrel. Took measurements for radiator so if anyone has a shop they know of that does custom radiators please let me know
  16. atch
    atch
    Try Portells; Portell Radiator Shop
    They did a beautiful radiator for Clarence (see avatar).
  17. wheeldog57
    wheeldog57
    Hey Eric, great to see you plugging away on your first hot rod build. Looks like you, your girl, and your friends are doing a fine job.
    I will crack another cold beverage, sit back and enjoy this ride. Good luck
  18. Mechman_22
    Mechman_22
    from Nc
    Well I'll have plenty of room for s**** pedal. got the pedal gasket mount bolted im place. Didn't care for the shifter I made ill try again but for now I just heated and bent the hurst shifter to fit what I needed it feels nice too 196699.jpeg IMG_20230605_214743_611.jpg IMG_20230605_214743_680.jpg 20230606_093003.jpg
    Tim likes this.
  19. Mechman_22
    Mechman_22
    from Nc
    Well battery tray is done for the 30. Just enough room for it and the rear tank. Other holes are where the tank mounts
    Just Gary and Tim like this.
  20. Tim
    Tim
    from KCMO
    Looking good. Did you get the front pan hard installed I don’t recall seeing a photo of it installed
  21. Mechman_22
    Mechman_22
    from Nc
    Not yet but soon
    Tim likes this.
  22. Mechman_22
    Mechman_22
    from Nc
    Well we have pedal action now!!! Swapped out the two barrel intake manifold on the 364 nailhead for a four barrel with new eldabrock carb. Got pedal located and linkage set up. Im still on the search for some tudor drip rails if anyone knows of a set Screenshot_20230710_082822_Video Player.jpg
    Tim likes this.
  23. Tim
    Tim
    from KCMO
    Looks good!
    I’ve had my drip rails from Mac’s on back order for a year and a half. Might try Burt’s in Colorado?
  24. Mechman_22
    Mechman_22
    from Nc
    Been bust couple seam sealer on the floor, put some body filler in some of the parts I had to work on, got the front pan hard bar welded in. Took the old ****py grill shell and cut 5in out of it to make it flow with and not sit down near axle plus never chopped one
    20230904_194301.jpg IMG_20230904_204554_236.jpg IMG_20230904_204554_264.jpg Screenshot_20230904_192954_WhatsApp.jpg
    don colaps, Just Gary and lostone like this.
  25. Mechman_22
    Mechman_22
    from Nc
    Well been a solid push to Get this Damn thing done its only been 10 or 11 years lol but definitely worth the wealth of knowledge learned throughout it. We dis***embled and set up a make shift paint booth. Never painted a day In my life but we have paint being sprayed!!!! Im sure ive missed some pictures and steps along with dis***emble 20230923_220454.jpg IMG_20230923_221730_870.jpg IMG_20230923_221730_927.jpg 209298.jpeg 20230924_184052.jpg IMG_20230924_212255_651.jpg
    Just Gary likes this.
  26. atch
    atch
    @Mechman_22
    Did you get your radiator problem solved?
  27. Mechman_22
    Mechman_22
    from Nc
    Yes sir had a custom radiator made. Believe it's 20in tall, was made by
    independent antique radiator out of illinois very happy with it as it was a complete custom build l. Great communication and kept me up to date on build until I got it at the house
    Tim likes this.
  28. Mechman_22
    Mechman_22
    from Nc
    We did get the frame ***embled and back together. Need to get back in the garage haven't had the motivation but need to lift body to paint under side and then set body back om frame knock out some body stuff then paint and re***emble
    Tim likes this.
  29. atch
    atch
    That's a good lookin' radiator.
    These folks?
    Independent Antique Radiator Manufacturing, Inc. - Algonquin, IL - Automotive Heating Equipment (industrynet.com)
    Looks like there was a lot of communication about dimensions and tab/filler/inlet/outlet locations. How did you do that? Did you have to send them detailed drawings?
  30. Mechman_22
    Mechman_22
    from Nc
    Yeah I believe that's them. Yeah I had pulled measurements and sent him the details. He builds alot of old style so wasn't to bad just really short
    Tim likes this.
