Projects turn signals on a model A
Discussion in 'The Hokey Ass Message Board' started by coody, May 26, 2021.
  1. coody
    coody
    On a original light bar w/a 32 grill. looking for turn signals locations and ideals. Maybe in the bucket?
    Stogy likes this.
  2. DdoubleD
    DdoubleD
    from Michigan
    Bought the kit that puts the bulb in the headlight bucket along with a halogen lamp conversion. Works excellent.
    Stogy and AVater like this.
  3. coody
    coody
    DdoubleD - I was thinking the same.I was saw a kit from speedway.Were did you get yours?
    Stogy likes this.
  4. lake_harley
    lake_harley
    My Model A turned out to have '35 pickup headlights. I finally figured that out based on diameter and that the wires come out through the mount stud. I ordered reflector kits from Mac's that have the turn signal built into the reflector. Car isn't complete and on the road yet to report on how well they light things up, but the parts fit the headlight buckets nicely.
    Lynn
    Stogy likes this.
  5. 2935ford
    2935ford
    I prefer the blinkers to be separate from the bucket.
    5window, Stogy, 26 T Ford RPU and 3 others like this.
  6. jaracer
    jaracer
    I bought a set of motor cycle bullet turn signals. They are very small but have a bright light. I'm thinking of mounting them under the frame horns where they will be almost invisible until they are on. They are about 3 in long and 1 in in diameter. I got them at madhornets.com. TS-007-BLK-BLK-2__78097_1591320220.jpg
  7. Never2low
    Never2low
    Anybody use the cowl lights on a deluxe, for signals?
    Dave Mc, Stogy, clem and 4 others like this.
  8. Hotrodmyk
    Hotrodmyk
    Yes, on my stocker. Makes for a clean installation.
    Joe Blow, Stogy, ramblin dan and 5 others like this.
  9. When I had my A roadster, I mounted some motorcycle turn signals on the side of the frame horns.
    Joe Blow, egads and Stogy like this.
  10. IMG_5297 (1).jpg I like to use era correct driving lights mounted on the bumper.
    Charlie Stephens
    BigDogSS, Joe Blow, Dave Mc and 3 others like this.
  11. Mr48chev
    I've had these saved on my Ebay watch list for quite a while. They should fit/blend in with most traditional rods front ends. Ebay number
    332450022524
    I have never been a fan of the turn lights inside the headlights because to me they just look too street roddy and not traditional. I had bike lights that weren't close to traditional on my T bucket.
    A search through motorcycle turn signal lights can bring up a number of them that look right along with a lot that don't. pANIC CYCLES LIGHTS.jpg
    Kiwi 4d, Stogy, clem and 2 others like this.
  12. Hotrodmyk
    Hotrodmyk
    Using generic motorcycle turn signals on my '34 PU. Very bright. Might be a little low in some states, check local regulations.
  13. 51 mercules
    51 mercules
    I had them in my cowl lights on my 29 Roadster!
    Stogy likes this.
  14. Rocky
    Rocky
    Classified Editor
    I found mine on line.....I think they were made for Yamaha atv's 34signal2.jpg 34atjimmys6_19.jpg
  15. Chicster
    Chicster
    40 Chevy parking lights om my 30 pickup
  16. Hotrodmyk
    Hotrodmyk
    51504bat and Stogy like this.
  17. coody
    coody
    a lot of cool ideals here! I have found out it doesn't matter what question you have you will get answer 10 fold with a lot of other ideals!
    Stogy likes this.
  18. Stogy
    Stogy
    :rolleyes:...Re-positioned Cowl lights attached to L shaped brackets bolted to underside of frame...
    I see your Hotrod in your Avatar which I'm ***uming is the car is full fendered so the cowl lights might not be suitable for this application but they sure as heck are noticable
    Kiwi 4d, 51504bat, unforgiven and 6 others like this.
  19. clem
    clem
    Had to chuckle when I saw @Rocky post above, - for my sedan, I actually pulled the indicators (as we call them) off my Ag 200 farm bike that I was using every day to round the cows up with, and put them under the bumpers.
    E35D37FB-C661-4B19-B92B-D48357033A66.jpeg 128B9BAC-C926-4AFF-9482-C5002975D28A.jpeg
  20. bjinx
    bjinx
    Back up for the day crowd.
    Stogy likes this.
  21. Tim
    Tim
    from KCMO
    Similar to some already posted I’m using these small late 40’s -50’s guide lights on the frame horn under the fenders. I’ll put an 1157 or similar in them and paint the insides white.
    used as an early Harley and Indian motorcycle accessory light I’ve also found them on tractors and the like.
    I like the lense shape and the round bezels/trim
    Rings. Some of the ones a available from truck bike and catalog places have a square-r shape to them and it stuck out to me as looking to new on this car.
    had considered chroming or painting the brake backing plates white to get a little extra glow but I think they’ll be fine 33823E89-D65D-47BC-9B33-D49D468C7E39.jpeg 9CE7DFDA-2182-4861-9E11-9F7EA216B668.jpeg A83CE3B7-80C5-43FC-8084-FF56478A93F2.jpeg 4C49EADE-19BB-422C-BDD8-2DED887FC933.jpeg
  22. Last edited: May 30, 2021
    Stogy likes this.
  23. Canuck
    Canuck
    HD turn signals painted and mounter under headlight bar. Choice of lens color. For those that have to be concerned about it DOT approved.
  24. Tim
    Tim
    from KCMO
    @Canuck that looks sharp! Got a closer shot of how they mount?
    Stogy likes this.
  25. X-cpe
    X-cpe
    Accessories from a long defunct motor cycle shop.
  26. Russ B
    Russ B
    Same as What I used:
    they are pretty well hidden, but visible in use.
    Joe Blow, Dave Mc, Tim and 1 other person like this.
  27. rusty valley
    rusty valley
    On my 34 I went online and searched for dual filament sockets, offset post, for 1157 bulbs. then, rebuilt the original cowl light with the new sockets, and special small globe 1157 bulbs that fit inside. now have cowl lights, and turn signals. I like having cowl lights, would not want to sacrifice them for just signals
    Stogy likes this.
  28. Canuck
    Canuck
    Don't know if you can make anything of it, this was my working drawing. Bracket bolts on under the headlight bar using the headlight nut that is recessed into the bracket. The stud projecting down is the mount for the turn signal. Wiring loops up into the headlight.
    upload_2021-5-30_20-18-51.png You can just see the bracket under the headlight bar.
    Stogy and Tim like this.
  29. Tim
    Tim
    from KCMO
    That’s not only what I thought you did it’s exactly how I would have drawn it up haha. Thanks man. Really clever
    Stogy likes this.
  30. clem
    clem
    Couldn’t follow your drawings until I looked back at your previous post with photos.
    And I was a draughtsman some years ago........
    But the end product looks really good and that’s what matters ........
    Stogy likes this.
