Technical T5 shifter position forward
Discussion in 'Traditional Hot Rods' started by pooch2, Mar 15, 2018.
  1. 6sally6
    6sally6
    Sure would like to see a picture of the part your talking about!
    I wanna move my shift handle BACK some and shorten the throws. (like the Ken Block "M"-word videos on Youtube)
    Shortening the throws will be EZ but......would love to see a picture of the "pivot ball" you spoke of!
    Thanx
    6sally6
    perry parsons likes this.
  2. That was posted here a while back from an NZ or AUS member I believe?
  3. saltflats
    saltflats
    from Missouri
    Something like this.
    Hnstray and perry parsons like this.
  4. Check out post #22, I used a steering rack arm as the pivot point.
    Didn’t run it but it shifted the gears nicely. Just a bit of R&D
  5. perry parsons
    perry parsons
    Hey Pooch, any shifter ideas come to mind after?
  6. X38
    X38
    See post 28.;)
  7. Seems like the OP has disappeared but here in Oz all T5's used had the GM gearbox bolt pattern and the rear shifter.....T5's were used in both the Holden Commodore and Ford Falcons, all with the rear shifter..........Mal Wood Automotive in Qld have all the necessary bits to move the shifter forward or you can do what I did yrs ago and import an S10 T5 gearbox.........andyd
    perry parsons and firstinsteele like this.
