Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. loudbang
  2. loudbang
  3. Phoenix24
    Phoenix24
    Anyone done a mini tub on an early Falcon? Any go to kit or is it something typically fabbed up?
  4. brianf31
    brianf31
    I considered it on my '61 but it didn't look worth the trouble. You can only move the inner wheel well in 1" before you hit the subrail. Radiusing is much easier.
    loudbang and Thor1 like this.
  5. Phoenix24
    Phoenix24
    I honestly keep going back to radiusing the wheel wells, but I just love the stock lines! Is there any go to for some premade ones?
  6. gimpyshotrods
    gimpyshotrods
    Yes, they come from front fenders.
  7. gimpyshotrods
    gimpyshotrods
    I built mini outer tubs. The wheelhouses taper away from the quarter panel as they rise. Depending on how much you lower your Falcon, the tires can strike the wheelhouse.
    Mine are now just inside the outer skin.
    Shown in the previous picture is a 196/60-15 on a 15 x 7, with 4-1/2" backspacing, on an 8.8" axle that is 1/2" wider than stock, overall.
    Brakes have since been upgraded to the biggest ones that will fit in those wheels.
    rod1 and loudbang like this.
  8. gimpyshotrods
    gimpyshotrods
    A few things that made a big difference in handling on mine:
    Shelby drop. This relocates the upper control arms, and creates a negative camber curve when cornering.
    One-inch anti sway bar up front.
    Progressive front coils on roller spring perches.
    CPP lower subframe/tubular control arms (not any old tubular arms) but this:
    That eliminates the radius rods, which go into bind pretty quickly, if you have a lowered car, and I suppose, on a raised one, too.
    There is space behind the coil spring that can be trimmed and plated to make a little more room for a tall Windsor.
    Ford basically did that with the Mustang, when the wedged a Boss 429 in there. Yes, the Mustang engine compartment is wider, but the Boss is freakin' huge.
    Falcons are much the same.
    brEad, Thor1, brianf31 and 1 other person like this.
  9. loudbang
  10. loudbang
  11. loudbang
  12. loudbang
  13. loudbang
  14. loudbang
  15. loudbang
  16. loudbang
  17. Deuces
    Deuces
    Nice!....^^^^:cool:
  18. RmK57
    RmK57
    The red one checks all the boxes, for me anyways.
    Deuces and loudbang like this.
  19. loudbang
  20. loudbang
  21. loudbang
  22. Jalopy Joker
    Jalopy Joker
  23. Phoenix24
    Phoenix24
    I was recently talking with my grandpa who did the same thing with a mustange, and if I remember right a shelby drop should allot for more to be cut as it moves the upper a arm bolts out of the way a small bit.
    I haven't been on here in a while due to the app shutting down, but I'm glad I saw this! do you happen to have the part numbers on that kit? Whenever I call people about suspension parts they get uppity when I ask why it say's it'll fit 61-63 and not 60. I thought the geometry was the same, and whenever I bring it up to the other falcon guys near me in the clubs and at cars and coffee, they say they thought it was the same too...
    Thor1 and loudbang like this.
  24. gimpyshotrods
    gimpyshotrods
    The kit does not exactly fit a '60. I welded my plate crossmember on. There was not enough of a lip to bolt it on.
    The geometry is exactly the same. There are some differences in the sheet metal, and rail construction from 1960 to mid 1961. It just means that several things are not a simple bolt-on, but require a little cutting and welding.
    Part number: 6165TCA-KB
    https://www.cl***icperform.com/Store2/Suspension/6466TCA-UKB.htm
    MUNCIE, Thor1 and loudbang like this.
  25. Phoenix24
    Phoenix24
    AWESOME!! So then would the global west arms bolt up then sense the geometry is the same? This looks like it has allot of bang for the buck as well, but does it help allot of I do not plan on lowering it any?
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    MUNCIE, Thor1, coneman and 2 others like this.
  27. gimpyshotrods
    gimpyshotrods
    The Global West stuff has the same geometry, and arguably the same bind issues the stock stuff does, on a lowered car.
    It helps in any case, but not as much on a stock-height car. For that, just fresh control arms are the best. Those are from the 65-66 Mustang parts bins, but required slotting of the holes on stock radius arms to attach them on. '60-'61.1.
    Thor1, Deuces and loudbang like this.
  28. Phoenix24
    Phoenix24
    Looking into it a bit it seems that I can get a wedge on the ball joint to allow them to not bind up at a 1.5" drop. This would also allow me to cut out more for a 351 swap as well as give me better geometry than a 1' drop. Have you seen any issues with a wedge kit? They seem to give similar/the same geometry to the global west stuff but has the added benefit to me of moving the mounting bolts lower allowing me to cut into the engine bay lower.
  29. gimpyshotrods
    gimpyshotrods
    No issues with a ball joint wedge set.
    I run them on my car. They have been on there for 7-years. I have lowered on my control arms 1-1/2-inches.
    Phoenix24 and loudbang like this.
  30. loudbang
    1 of 7 Canadian 1965 Ford Falcon Hi-Pos
