Hot Rods Let's see your homemade speed equipment
Discussion in 'The Hokey Ass Message Board' started by Robert J. Palmer, Nov 26, 2014.
  1. patsurf
    patsurf
    Deuces and loudbang like this.
  2. Jethro
    Jethro
    Very nice work on the rockers....Bravo!
  3. Six Ball, Lil'Alb, mad mikey and 4 others like this.
  4. Bump for an old thread.
    patmanta and Ned Ludd like this.
  5. Old school racer tricks- WICO Model X magneto for a Chrysler flathead 6 mated to a BlueFlame Chev. 6 drive!
    upload_2020-9-21_0-11-13.png upload_2020-9-21_0-11-54.png upload_2020-9-21_0-12-33.png upload_2020-9-21_0-13-15.png
    Six Ball, Lil'Alb, mad mikey and 9 others like this.
  6. Flat Roy
    Flat Roy
    Ben's Ford 6 - j a.jpg Ben's Ford 6 - 3.jpg Ben's Ford 6 - 4.jpg Here's one I did for my friends bracket Ford
    brEad, Lil'Alb, BigRRR and 12 others like this.
  7. Nothing flash but was on an old Banger powered racer from the 40s , backyard hi-tech long ago. 44F446A1-F1E9-4800-89BD-769960A0FA4E.jpeg
  8. 270ci
    270ci
    A blower intake manifold made from an old Offenhauser 4 barrel intake and the start of a drive snout for the less appealing smaller sister of the popular Detroit 6-71.
  9. rovertenrod
    rovertenrod
    DADD6391-5D5B-418A-A0E1-4FA30FCA6FE4.jpeg DE31589F-C6F4-44ED-8EFB-5D44788CF42E.jpeg
    for my Daimler Hemi
    neilswheels, brEad, Lil'Alb and 13 others like this.
  10. rovertenrod
    rovertenrod
  11. Bump for an old thread
    Deuces, fauj and Ned Ludd like this.
  12. mad mikey
    mad mikey
    Bump again, this stuff is what it is all about!;)
  13. jnaki
    jnaki
    No photos at the time, but an “A” in the Metal Shop Cl*** 2 and an “A” in the Automotive Level 2 Cl*** was well worth the design and effort.
    https://www.jalopyjournal.com/forum...or-an-auto-trans.1213389/page-2#post-13842724
    Hello,
    One of our friends just bought his first car in high school. It was a 1951 Pontiac two door sedan. He wanted to keep the idea of a two door sedan, as all of us that had hot rods or cruisers, drove two door sedans. It was stock and in fairly good condition. After all, it was 1961 and only 10 years old in a covered garage most of its life. He was not much in the automotive mechanical repair and diagnosis way, but his admiration for those that had the skills or at least were willing to experiment was much appreciated.
    He asked us what he should do to make it special. My first thought was a set of screw in Moon Discs for some authenticity. He already turned his white walls to the inside, so the Moon Discs would be on blackwalls. Then after that suggestion, he ran out of money. So, it was just little things like spun plastic knobs and other little things from the local chrome and accessories shop. Also, working on small cl*** projects in high school cl***es, but spending as much as the budget would allow.
    https://www.jalopyjournal.com/forum/threads/no-pontiac-love.1136812/page-3#post-12979953
    The best thing he did was to use his car in our high school metal and auto shops as a means of getting some work done for free. We made his automatic column shifter into a floor mounted shift lever with options for any lever or shape of lever screwed into the base shifter. He selected a tall one so people could see the ball knob from the outside of his car. It looked like an old time hot rod cruising around.
    Jnaki
    Was he happy that his old Pontiac was not the fastest car in our group? Did he care that when he did stomp on the gas pedal that those in his car, plus the other old 6 cylinder Chevy in the next lane were all happy and laughing out loud? It was freedom to go anywhere possible. But to have a cool floor shifter sticking out of the floorboard and up in the air, made it just that much more fun.
    Today, that old 1951 Pontiac would be lowered in Cal Rake stance and have a big motor rumbling at the start up. Turn on the A/C and cruise all over So Cal like we used to do as teenagers, but in cool comfort. Moon Discs? Perhaps, but more than likely, different wheels, possibly American Racing Equipment Torq-Thrust 5 spokes to keep it an authentic 1960 high school hot rod. It was a fun car to ride around in as teenagers and today, the feeling would still be the same, with the upgrades in technology.
  14. ENess
    ENess
    from Illinois
    Intake with Holley 390 and headers in a 230 dodge six.
    Deuces, loudbang and fauj like this.
  15. Home built blower set up
    Note the square tube home built wishbones
    Dead perch and slider
    Six Ball, Lil'Alb, Boneyard51 and 8 others like this.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Flathead Cadillac intake modified for an early 4 bbl. carburetor.
    Robert J. Palmer likes this.
  17. willys36
    willys36
    I recently put truck heads on my long bell housing 331 hemi. Engine is bored 1/8" to 354. Big ports in these heads allowed me to make 2" fender dump headers I always wanted for my g***er cartoon car. Equivalent of a 20" gl*** pack muffler is built into the colletors.
  18. I've seen a bunch of welded up cast iron manifolds in this thread, what is the best way to weld the cast? Braze, nickel rod arc weld, I have heard flux core wire feed works any truth to that? I'm in the beginning stages of building an old school two carb intake out of a stock cast iron flathead manifold. Plan is to weld two sets of pipe to the manifold that go up to some steel plates to mount the carbs, just like the J.C. Whitney kits. So I will be welding steel pipe to the cast manifold, thinking brazing would be best but would like some input from those that have done it.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    '49-'51 MERCURY intake manifold modified for an early four barrel. 20220925_161931.jpg
  20. I have built a could of BlueFlame split manifolds by brazing them and had good results.
    I have welded cast iron before and never had any trouble, but it can be a **** shoot.
  21. Thanks, I think I may try brazing also.
    Boneyard51 likes this.
  22. High test 63
    High test 63
    IMG_20200821_143932489_HDR.jpg brazed the steel pipe for carb risers to cast iron intake. 7018 stick welded the second v-8 exhaust dump to the cast iron manifold. Homemade progressive linkage.
  23. High test 63
    High test 63
    Many miles of trouble-free abuse!
    fauj and 46international like this.
  24. Jethro
    Jethro
    GMC 302 intake
    Six Ball, Gofannon, charleyw and 10 others like this.
  25. willys36
    willys36
    I brazed two pipe stubs on this 354 manifold to install a thermostat housing for my early hemi.
    46international and High test 63 like this.
  26. Boneyard51
    Boneyard51
    What is most important in welding cast iron is preheat and letting it cool,slowly and evenly! I have brazed and stick welded with nickel rod successfully, on various things.
    Bones
  27. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Great thread Robert...............
    You might try Tig Brazing the components to get a nicer finish . Try it on a couple of old cast iron parts and see how you like it. I Tig brazed some pads to an engine block where I wanted to be able to add some studs to hold some parts behind the headers. Easy to do and lots of control of the heat and rod.
  28. uncleandy 65
    uncleandy 65
  29. VOETOM
    VOETOM
    from MO
    Speaking of exhaust. Here is part of what is inside the vacuum operated mufflers I have had the joy of fabricating over the last few years.
    SS327, chevy57dude, fauj and 4 others like this.
