Projects Philly Spcl Coupe
Discussion in 'Traditional Hot Rods' started by RustEE, May 31, 2021.
  1. RustEE
    RustEE
    Hey y’all, I’ve been mum on this site due to unforeseen litigation, however, that fog has lifted and I have H.A.M.B. coupe build story to share…
  2. RustEE
    RustEE
    Built by @Koz and largely sourced from this community, now the truth can be told!
  3. lothiandon1940
    lothiandon1940
    But this is the Gentleman's Coupe!:D IMG_3550.JPG IMG_3513.JPG
    catdad49, Jet96, chevyfordman and 9 others like this.
  4. Koz
    Koz
    Damn! About time for this thread. This one is just too cool. I haven't been posting any pics as I would prefer the owner to tell the story. I know you have a load of pics. Show the HAMB what you've created. I'm sure Rustee is playing on the "Race of Gentlemen" in ***l;ing this thread.
  5. RustEE
    RustEE
    VANDENPLAS and lothiandon1940 like this.
  6. RustEE
    RustEE
    Tremendous fab work by The Maestro of Metal @Koz Fabrication!
  7. sloppy jalopies
    sloppy jalopies
  8. RustEE
    RustEE
    Love at first sight!
    30-31 body/frame
  9. RustEE
    RustEE
    Sourced an eBay 8ba Flatty out near Pittsburgh…so many people have helped me locate vintage parts for this build it is humbling.
  10. RustEE
    RustEE
    The parts pile grew thanks to the H.A.M.B.
  11. RustEE
    RustEE
    Dropped off on the way to TROG
  12. RustEE
    RustEE
    One piece at a time
  13. RustEE
    RustEE
    I’ve made plenty of mistakes along the way. Buying expensive parts that didn’t really fit the direction I wanted to go. But I was excited (and naive) and set aside other long term projects to focus on building something that could potentially race at TROG and other vintage drags. I wanted to build it myself and there is a strong desire to build vs. buy. But this sort of thinking was actually holding up the project. It sort of hurts the industry surrounding this hobby when there are so many more folks who are so much more capable than I am, for me to selfishly want to build it myself. People who’s livelihood is dependent on the continuation of the scene. That’s when I made the best decision of all. Find some help! That’s when I met @Koz :) and learned just how much I didn’t know!
  14. RustEE
    RustEE
    Sourcing vintage speed parts from the H.A.M.B. is one thing, but finding someone with his depth of knowledge and experience was priceless. @Koz can pick up the story from here, but I just recall unloading parts at his shop and he immediately rejected some of my poor choices in parts. This left me a little confused, but I respected his recommendations and ultimately relented and he was able to use his network of connections built over a lifetime to help me get some of the period correct hop up parts that fit the criteria perfectly. He immediately got to work and I witnessed a true master in his element, soaking up as much knowledge that I could. This was the greatest benefit of all and I would encourage anyone who, like me, was slowly collecting one part at a time for an “eventual” build, to take the plunge and find a reputable fab shop. The stories you’ll hear, the connections you make, the techniques you’ll learn are indeed truly priceless.
  15. Koz
    Koz
    I am humbled Rustee! You're the best kind of client in that you really knew what you wanted up front. You made the build easy and it is totally in HAMB character to boot. I know you've been holding back on the shots of the car so far but it is really a real hot rod. Done with a load of vintage parts and a couple of upgrades for everyday use. I'd have no problem jumping in this one for an across country run.
    I'll let you post the pics but I feel the ch***is is perfect, (vintage model "A" frame stretched 3" to deuce dimensions), boxed and sweep Z following Doane Spencers iconic lead, with a 6" rear Z to put the 1960's era cheater slicks, (for street use), right in the arc of the wheelwells.
    The Henry issued Model "A" axle was dropped old style by Andy Kohler and holes milled in a pattern my Dad used in the fifties. A pair of '48 Merc 'bones located everything up front and a sweet '40 banjo brings up the rear. Stopping gets taken care of by '48 Ford p***enger brakes and a 1960's Chevy truck master and clutch cylinder combo. Been done a million times but oh so traditional. Everything just goes together so well it is hard to tell when it was built. All this is coated in a vintage cream that perfectly matches a set of front backing plates Rustee provided that were painted who knows when. Painted covered shocks and '48 pickup shock mounts. Lots of hunted down parts here.
    The 8ba is basically stock intrnally with a 2x2 Fenton and some Holley 94's. A very vintage but mint Mallory dual point makes the sparks and a pair of Speedway headers with the tapered tube replaced with a '36 driveshaft and a pair of reworked Cherry Bomb cores to keep the racket under control. T-5 and the stick from a '36 makes it work.
    What did I miss?
  16. RustEE
    RustEE
    In addition to the beautiful frame work, the split wishbones, the chop! The gorgeous custom dash, fabbed from the original gas tank, the replacement tank, and plenty more!
    lothiandon1940 and VANDENPLAS like this.
  17. RustEE
    RustEE
    That 3” frame stretch made a big difference in the stance and the 8ba fit pretty nicely.
  18. RustEE
    RustEE
    Here’s a good shot of the master cylinder @Koz mentioned. And another couple showing the Mallory dual point.
  19. RustEE
    RustEE
    Earlier in the build…you can see Andy Kohler’s sweet drop axle, drilled w/the @Koz pattern. And the banjo rear located via Koznet.
  20. RustEE
    RustEE
    I again have to thank all those who contributed to this project. I am forever grateful.
    lothiandon1940 likes this.
  21. 6sally6
    6sally6
    That 3" stretch is also kicked up too, right?!
    Does that move the body back 3" or give more room inside the body?
    Will the kick UP give a little rake to the body also?!
    Thanx
    6sally6
    RustEE likes this.
  22. RustEE
    RustEE
    D16AEABC-9761-4A68-AD0A-8A220B92EC65.jpeg 61B0293E-90D0-41C8-8AE0-C8D16ED56072.jpeg A view of the dash in process and the custom built pedal ***embly
  23. RustEE
    RustEE
    Some of the trunk work, tank and filler neck and an old Kennedy clamshell toolbox/battery compartment
  24. RustEE
    RustEE
    Pushed the body back 3” It does kick up slightly and with the Z rear gives a perfect stance. IMHO.
  25. RustEE
    RustEE
    You can see the subtle rake in some of these shots
  26. lothiandon1940
    lothiandon1940
    You know if you hit that "full image" ****on before you hit the "post reply" ****on your pics will automatically be larger.:) 5F9BDE0C-65D2-492C-B712-EF424E266E5C.jpeg
  27. lothiandon1940
    lothiandon1940
    ^^^Like this^^^;)
    VANDENPLAS and RustEE like this.
  28. RustEE
    RustEE
  29. RustEE
    RustEE
  30. RustEE
    RustEE
