Technical Lowering a 1952 Pontiac
Discussion in 'The Hokey Ass Message Board' started by Terrible Tom, May 31, 2021.
  1. Terrible Tom
    Terrible Tom
    Trying to do this project with limited resources, but want to do it right. I would like to drop my Pontiac 3" front and rear. I'm o.k with blocks in the rear but am hesitating cutting the coils in the front. JAMCO has coils and shorter shocks available for around $400. Is it a better way to go and can I expect a much better ride than if I cut the coils? 20210419_114720.jpg 20210419_114655.jpg
  2. Dangerousdan
    Dangerousdan
    from Arizona
    Sure, Dropped spindles.
  3. 38Chevy454
    38Chevy454
    Why the resistance to cut coils? It's basically free cost. The spring rate does increase some since you have less coils. But that is usually a good thing on lowered cars. Sure there's a limit how much lowering can be accomplished by just cutting coils alone.
    302GMC and Special Ed like this.
  4. evintho
    evintho
    Aerostar coils? We use 'em on our '52-'59 Fords all the time. Drops the front about 2-1/2". May want to look into that.
  5. Terrible Tom
    Terrible Tom
    I cut the coils on a 52 Olds that I had and it seemed to stiffen it up too much, but you're right, it's free. I may try it again. Thanks.
  6. Terrible Tom
    Terrible Tom
    Haven't seen any available.
  7. Terrible Tom
    Terrible Tom
    That's a possibility.
  8. fyrffytr1
    fyrffytr1
  9. fyrffytr1
    fyrffytr1
  10. Malibu406
    Malibu406
    I ***ume the 52 suspension is the same as my 50. Cutting the old tired front springs can be a little tricky because they likely are already sagging and not at the original height they were supposed to be. I cut 1 coil off, and it didnt seem to do much more than 1”, so I cut another off and it dropped almost 2” more??? (too much for 29” tires), but probably near the three inches you want. Since its the old threaded bushing style it takes a couple of hrs each time. Since I went too far I ordered 2” drop springs from Jamco. That was just about right not to hit tires when turning and compressing. Stock wheels pull the tires in more so you could go lower and probably be ok. However I put front disc conversion on and couldnt get deep back spacing without custom ordering.
    I went with 2” drop leaf springs from a local shop and two” taller rear saddles I made from 2” x 4” x 5/16” wall that I welded on so I have no loose blocks.
    I used koni adjustable rear drag shocks for a 70-74 dodge challenger.
    With the new springs in it has about an inch more rake than I like, but not bad. F283A010-41E7-43A2-8C16-41A8B3374C80.jpeg 554B2092-6573-4082-8831-8A80B884AECC.jpeg FF30C195-EC7D-4916-BBE0-AD9AF44AC31E.jpeg
    Terrible Tom likes this.
